**Autobahn Exotics Exhaust Review**
01-20-2009, 06:23 PM | #1 |
Modder Raider
756
Rep 8,633
Drives: M3
First off, this review is a little long, but IMO, worth it. Grab a beverage and enjoy!
There are many exhausts on the market and many choices. The question that one needs to ask before purchasing is, “What does one want from an exhaust?” Is the only concern the noise and the sound? Is the concern about the increase in power and torque? What about the ease of installation and the fitment. Should that be a concern? If you care about all of the above then I would highly suggest the Autobahn Exotics (AE) exhaust. I am seriously blown away with how well this exhaust is made and how straight through it is, yet it does such a good job making it sound as good as it does. AE makes the exhaust with the quad tips as well, and if I had the appropriate bumper, I would have definitely chosen the quad tips. I’ve seen the quad tips in person and they are beautiful! Installation and Quality Since this exhaust is in 3 sections, it’s very easy to install each part. The best thing I like about the installation is that each piece is flanged and doesn’t require a slip fit and clamps. I have had my share with exhausts that are slip fitted, and it was alright for the install, but a PITA to take off. Clamps get over tightened and pipes become crimped. I’ve found that there’s a fine line between too loose and leaking to over tightening and crimping. Then again, maybe it’s a personal issue. The flanged sections prove a point. It proves that AE took their time and did a lot of research with the fitment of this exhaust because there is no room for error. It’s obvious that they didn’t cut any corners whatsoever. The gaskets that are included are top notch, and the bolts are of perfect size. I also noticed that AE thought about the way the section 1 pipes connect to the Downpipes. It’s easier to access the bolts. Since I’ve gone through so many arrangements of exhausts, I’ve found that these bolts were usually a pain to get to, but it was quite easy with the AE exhaust. They mandrel bent the pipes in a way where it was easy to get to the bolts. The pipes are T304 Stainless and all of the sections are mandrel bent. I also really like how the pipes aren’t polished and shiny. Seriously, who cares about the pipes being shiny when you’re never going to see them? I guess the point that I'm trying to make is that I believe that some companies focus too much on how nice and polished their piping is when they should have spent the money in other areas instead of the polishing. The mufflers are polished and so are the tips. IMO, I could go without polished mufflers as well, but the mufflers do look pretty good from behind. The 3.5” polished stainless steel tips are my favorite, they are resonated so they also play a role with the sound. They just look so fricken cool! Sound First off, I have the Ultimate Racing (UR) catless Downpipes (DPs), so by adding the AE exhaust, I went completely catless. I was expecting this exhaust to be unbelievably and unbearably loud. I mean, think about this…I’m going from high flow cats, X pipe, Borla muffler to no cats, no X pipe, no resonators, and just mufflers with resonated tips. I started it up, and it was a deep mellow sound. It sounded soooo good! I revved it up and it was perfect! I let it idle for a bit and then took it for a spin. This exhaust does exactly what exhausts should do. It’s quiet when you want it to be, and it’s quiet when cruising, but when you get on it, watch out—It screams! There’s absolutely no rasp! Seriously now, there’s no resonators and no cats, and there’s no rasp? Truly amazing! The only thing that was bothering me was the emissions. I’m constantly driving the family around and I could smell the CO2 when I would stop for a red light. If I could smell it, I knew that my daughter would be able to smell it, so I opted to install the High Flow Cats (HFCs). I talked to Nick at AE, and he was saying that the cats that they offer in their HFC version are close to identical to mine. The insides are metallic and configured exactly the same way. So what changed after I added the cats? Besides the no smell--not a whole lot. The sound dropped a tad and I seriously can’t even tell between power. It feels exactly the same. IMO, if you are already running catless DPs, I would highly recommend the HFC version of the AE exhaust. You aren’t going to add that much power if anything at all, and you’ll be at least helping a bit with the environment. Power I didn’t have the time to do before and after dynos or any before and after ¼ mile runs, but it feels more responsive. I honestly can’t tell between no cats and the high flow cats, so I believe the high flow cats are the way to go. Why not go with HFC DPs? I had HFC DPs in the past but I read a very informative brief that was written by a Development Engineer from Garrett Turbochargers. In a nut shell, relieving pressure closest to the turbos will create a quicker spool. X pipes or any combination of the exhaust pipes down stream only creates more back pressure. X pipes are great for naturally aspirated engines since there is more of a scavenging affect that is taking place. Unlike Forced Inducted engines, NA cars rely on some back pressure to keep the scavenging going. (For those who are interested in the complete write up by the Garrett Engineer, you can click here) So, why was I running an X pipe with my previous system? I did it strictly for sound and I have always mentioned that if I didn’t run an X pipe, I would most likely get more power, but it didn’t bother me since I was getting the sound that I desired. Well now, I can have my cake and eat it too. I have an unbelievably sounding exhaust, and it flows much better than the previous exhaust. Conclusion Sorry if this was too long but there was too much to say. I could go on and on with this exhaust, but the only way for you guys to realize how well it’s made, how good it sounds, and how good it feels—well, you’ll just have to get one for yourself now huh? AE, thanks for making such a great product! JPSimon posted movie clips a while back with his completely catless system, but I will be posting what it will sound like with catless DPs and the AE exhaust with HFCs. JPSimon's clips and other AE movie clips can be found here I’ll take some clips this weekend. If anyone wants to help film or see/hear the exhaust in person that lives in Orange County, let me know. The movie clips will be updated in this post. I also added the pictures of the quads for you guys to drool over! Thanks for reading!
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
01-20-2009, 06:34 PM | #2 |
83
Rep 1,861
Drives: 2008 E92 335i
Excellent write up...if I could afford it, I'd already have this mod a long long time ago
01-20-2009, 06:57 PM | #6 |
Professional Moose Racer
316
Rep 7,509
Sound clips asap, more tunnel runs please
Visit my blog anytime: http://www.sfpayments.com
BMW Dream Team PNW Chapter, member #1 |HP Autowerks | AR DESIGN | BMW PERFORMANCE | STOP TECH | Volk Racing| AMS | ARKYM |
01-20-2009, 07:34 PM | #9 |
Team Zissou
135
Rep 1,426
Great writeup! Wow! I'm glad youre liking it and like everyone else, I cant wait to see the tunnel runs on video!
01-20-2009, 09:06 PM | #11 |
Team Zissou
3077
Rep 10,198
Great review Mr. 5, I couldn't have put any of it better myself (except maybe the smell, it doesn't mother me)! People really need to see/hear this exhaust in person.
01-20-2009, 09:18 PM | #12 | ||
Modder Raider
756
Rep 8,633
Drives: M3
I'm sure there's plenty I could have talked about. Quote:
If someone were to hook me up with an M tech rear for the quad exhaust then I'll just march back to AE and get the quads!
01-20-2009, 09:20 PM | #13 | |
Modder Raider
756
Rep 8,633
Drives: M3
Welding is the way to go man.
01-20-2009, 09:22 PM | #14 | |
Modder Raider
756
Rep 8,633
Drives: M3
You didn't say it was the "best exhaust yet" for nothing.
01-20-2009, 09:35 PM | #15 |
Team Zissou
3077
Rep 10,198
01-20-2009, 09:42 PM | #16 |
Rep 986
Great review and congrats on the new exhaust!
I find myself driving around with the windows down in sub-freezing temps wearing layered clothing and the heat cranked just so I can hear it. The sound is truly addicting!
2008 E92 MT | VTT Stage 2+ 20T | VTT Inlets | JB4 MHD E85 | Fuel-It Stage 3 LPFP w/FPR and Return | BMS PI | AR DP | AE Quad Exhaust | Helix FMIC | ER CP | Tial BOV | DCI | AR OCC | Spec Stage 3+ | SMFW
01-20-2009, 09:46 PM | #17 |
Rep 8,091
Very nice write up!
I second everything Mr. 5 has said The exhaust is top of the line The sound, fit and finish, EVERYTHING about this exhaust is great. Im a very happy AE customer! |
01-21-2009, 08:47 AM | #22 |
Modder Raider
756
Rep 8,633
Drives: M3
Awesome man! You're gonna love it!
