DCT transmission stuck in park 335is
07-12-2023, 04:57 PM | #1 |
9
Rep 53
I ran over a cone on highway and it caused coolant and power steering to leak but no transmission fluid, checked the flywheel nothing is there or got up into it, I can’t find any info online or any reason why the parking lock is just locked and I can’t unlock it, I also have INPA and ISTA if I can use that to diagnose deeper. Car will run and idle perfectly fine but won’t go into gear (reverse or drive) I can only set it in nuetral by going under the car and pushing this lever up as seen in the attachment.
09-02-2023, 04:50 PM | #2 |
Rep 3
Sorry to hear whats happened. I’ve got the same issue with my n55 dct 335i. It happened after similar circumstances.
My radiator got a crack and a fair bit of coolant had spilled everywhere. I got the radiator replaced at a garage that gave me the car back with a boost leak, which I got fixed at a more qualified mechanic. After that it would be stuck in park on startup, giving a gearbox malfunction error on idrive but I managed to drive it for a week by turning it off and on once or multiple times, however that troubleshooting method stopped working. Funnily enough after I parked it on a curb on which the bottom scraped for a second but didn’t seem too bad so I don’t think it has anything to do with it. Did you manage to fix the problem or figure out what caused it? I gave the car to the mechanic and he told me it’s an electric fault. A car electrician checked it out and told me I need a new shifter mechanism. I’ve left the car with him to sort it out as I’m not in a rush due to health reasons. I’ll attach a screenshot of the fault codes I got from bimmerlink if they are of any help. I was however told to ignore them by the technicians. EDIT: You might not need to go under the car to get into neutral. On mine if you lift the trim around the shift lever you’ll see a red button and next to it a hole. If you put a alan key in there and twist it anti clockwise, the car will go into neutral and then the red button puts it back into park. Last edited by BrunoE9X; 10-13-2023 at 08:08 PM.. |
10-05-2023, 02:24 PM | #3 | |
9
Rep 53
TheMidnightNarwhal2672.50 BrunoE9X0.00 |
10-05-2023, 03:10 PM | #4 | |
Rep 6,302
