07-18-2023, 12:26 PM | #1 |
Rep 199
Windshield spotting that won't wash off
I noticed that the windshield of our month-old 2024 X5M has what appears to be hard water spots on the lower right side. Whatever it is seems to be the result of a single large drip. It's left something that can be felt with a fingernail, and has not yielded to my usual windshield cleaning products.
The vehicle is barely a month old, is garaged most of the time, and has only been exposed to rain once (and was washed promptly thereafter). No bird droppings or other major soils encountered so far. I'm assuming it's something that happened since I bought the car - I don't recall seeing this at delivery, though it's really only visible when light hits it a particular way (hence the poor quality photos). Any thoughts on what I'm dealing with and how to get rid of it? |
07-18-2023, 01:29 PM | #2 |
13708
Rep 20,381
Give vinegar a try if you haven't already.
07-18-2023, 02:25 PM | #3 |
Rep 6,946
When I want to really clean my glass, I'll use McGuirer's polish with a foam pad on a random orbital buffer.
3M makes a really good glass cleaner spray as well and I use that the other times. |
07-18-2023, 02:27 PM | #4 | |
184
Rep 337
07-18-2023, 03:10 PM | #5 |
Rep 596
If it were mine, I would soak a paper towel in vinegar, let it sit on the spot for a bit, and then scrape with a fresh razor blade.
07-18-2023, 05:14 PM | #7 |
Rep 1,022
Got a old heating pad around.....
I would try with some things you might have at home. Paper towel with vinegar. Maybe fold it to be 3X thick and soak more vinegar... Blow Dryer, Heat Gun, propane torch...get that area warm. Then Apply the Paper Towel... Some localized heat for a bit as it dwells. As crazy as this may sound, but all materials, metal, glass, etc - things do absorb when hot. So reheating the surface may help in -lifting- it out. |
07-18-2023, 10:19 PM | #10 |
Rep 6,946
Sounds like it's a mineral deposit, i.e., water spot. You either scrape it off, buff it off, or dissolve it. If it's pitted, though, it's from something else, and you may be able to buff it to minimize the defect.
07-18-2023, 10:21 PM | #11 |
Rep 199
I alternately applied vinegar, goo-gone (citric acid lifts a lot of things!), and a razor blade tonight and made some amount of progress. It's definitely not gone, but there's an improvement. I'm a little shy with the blade, as I obviously don't want to scratch the glass, but it's definitely finding and lifting something from the window.
Still no idea what the root cause might have been, though, especially after so little time out of the garage. |
07-19-2023, 05:28 AM | #13 |
Rep 1,301
Try a little clr on a towel. Let it soak for a few minutes. Scrape off with a plastic razor blade.
07-19-2023, 01:32 PM | #14 |
Rep 52
Funny that you posted this my new LCI needs a new windshield. There is a smudge sanwiched inside the glass right near the hud arount 8 inches long. Dealer looked at it today and its a factory defect and will need to be inspected by BMW to authorize a replacement windshield...Make sure that it is not inside the glass.
07-20-2023, 02:04 PM | #15 |
Rep 764
Chemical guys water spot remover removes any and every water spot on any vehicle surface. It works in about 10 seconds with minimal effort. It’s the best investment I’ve made when it comes to car detailing materials. If you haven’t used this product it is game changing. It’s a miracle product. No I do not work for chemical guys, just the best water spot remover ever invented.
LuvMyE923009.50 |
07-20-2023, 10:20 PM | #18 | |
Rep 199
I might have to try that Chemical Guys product that's been mentioned a couple of times, just to have on hand for the future, though... |
07-21-2023, 07:18 AM | #19 | ||
Occasionally frequent poster
3010
Rep 2,746
I hope you get this resolved. Worse case, you can get the windshield replaced, but that may be a bit extreme unless you're like me and you fixate on the defect every time you drive.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
07-21-2023, 12:34 PM | #20 | |
Rep 62
sharkymcpeterson642.50 |
07-21-2023, 12:36 PM | #21 |
Rep 764
07-21-2023, 02:04 PM | #22 |
Rep 62
