BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Driver seat back panel /cover removal??
      07-27-2023, 08:53 PM   #1
Dirollin
Drives: 2020 BMW M5 F90
Exclamation Driver seat back panel /cover removal??
I've scoured the internet trying to find the way to remove this particular back panel (M5 F90 driver seat back panel/cover). I can get the lower portion of the top panel off but I cannot figure out how it disconnects from the upper part. Seems like a strong bond and didn't want to pull to hard on it and break something. Does anybody have any idea?? I guess this isn't a common thing to remove.
Thank you for your help!!
(Don't know why the images are rotating...)
      07-28-2023, 04:24 AM   #2
AHall
982
Drives: 1993 Nissan 240sx
Why are you taking the seat apart?
      07-28-2023, 01:39 PM   #3
Dirollin
Upper backrest motor is screeching, want to see if it's something I can access without removing the entire seat. BMW says they will need the car for a week or more.
      07-29-2023, 12:57 PM   #4
Dirollin
Here's a video. If anyone has any idea if this upper backrest motor screech can be fixed or the motor replaced without full seat removal please let me know what you think! I would much rather do it myself than be without my car for so long...
Also this screech only happens when its warm outside. If it's cold or morning time no noise is made. Why would that happen??
https://youtu.be/b96j2L9-YB0
      07-29-2023, 01:21 PM   #5
jm490
519
Drives: 21' F90 M5c
My car just started recently doing this also. Let me know if you figure out a solution as it is annoying. It only happens randomly for me though.
      07-29-2023, 05:51 PM   #6
Dirollin
I absolutely will! At least the motor works. Just annoying and a little embarrassing haha.
jm490519.00
      07-29-2023, 05:53 PM   #7
jm490
519
Drives: 21' F90 M5c
Hahah yeah that’s very true. Luckily I’m usually in my car alone. But a car like this shouldn’t do that that’s for sure.
      08-08-2023, 01:15 PM   #8
Dirollin
I find it hard to believe nobody has the knowledge to help with this but time has run out and M5 goes to shop tomorrow. I guess the forums aren't as useful as they once used to be. Thanks anyways.
      08-08-2023, 09:19 PM   #9
AHall
982
You probably looking for help with something no one here has had to address. Hopefully the shop can solve the issue for minimum cost.
      09-09-2023, 07:41 PM   #10
EPTXM5
Drives: 2018 BMW M5
My 2018 did the same thing every time bc of the easy entry. Dealer greased the track and it noise came back in a week. They had to order a new seat frame or something and that worked for a year. My noise came back about a month ago. No more warranty on car. I wish I could just turn off the function of the easy entry and leave my seat where I leave it. I only drive my car.
      09-12-2023, 02:06 PM   #11
smbsocal
Drives: '21 M5, '59 C1, '23 X6
My seat squeaks as well from time to time, it seems to happen more when it is hot in the car, ie sitting in the sun. I have brought it to the dealer but since it is random they haven't been able to recreate it.
      09-15-2023, 11:10 AM   #12
Alan l.
Alan l.'s Avatar
5453
Drives: 2020 F95 X5M Competition
Ive been trying to figure this out for my X5M for over a year. If i apply anymore force i'll surely break something.
I saw a bmw document awhile back showing you need to squeeze the sides together (towards the middle) to remove but that still didn't work for me.
      01-31-2024, 04:20 PM   #13
Tizze_G31_530e
Drives: BMW G31 530e 2022
I have the same issue, can’t seem to find a way on how to remove the back panels.
Did anyone figure it out yet?
      03-27-2024, 01:26 PM   #14
elkonurbaev
Drives: F90
Hello, did anyone find a way on this screeching noise issue?
I need help on that. Thx
      04-11-2024, 08:29 AM   #15
Funlovincriminals
Funlovincriminals's Avatar
Drives: BMW M5 F90
Hello. I have the same problem. First, the BMW dealer disassembled the seat and lubricated the mechanisms. A few days later the creaking returned. Now we have ordered the seat frame. new. they will rearrange the casing on it. I'm attaching a photo. First the upper part is disassembled. then the bottom one
m5post
