F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > 3 and 4 Series Ordering / Pricing / Order Tracking Forum (and European Delivery) > Instrument Cluster Replacement with New Original BMW
GetBMWParts
      08-05-2023, 07:03 AM   #1
diver94
Drives: 2016 BMW 428i Xdrive conv
Hello All,
I recently bought a 2016 428i xDRIVE Convertible (F33) and I need to replace the cluster. A local BMW mechanic told me that he can program it/code it but that it has to be a new/original part (not used).
I just ordered the part from Braman BMW (hard to find the correct cluster) so many versions. Anyway, I ended up buying this cluster - BMW (62-10-5-A03-A26) because that one is compatible with the HUD.
Here is my question:
Can I install the cluster myself and then drive it (like that) to the mechanic? Will the car run Ok with the new cluster? I know some features might not work properly, but its only a 5 mins drive and that can save me some money on labor.
I already removed the old one to clean it (not too hard to do).
Thanks!
Lou
      08-14-2023, 05:38 PM   #2
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Yes, you can drive there without a coded gauge cluster, just expect and ignore the myriad of warning lights.
Also, If I were you I'd return the cluster you bought and use this opportunity to upgrade to a 6WB digital cluster.
Any coder can set it up for you remotely, you don't have to involve a shop at all if you're able to physically install it yourself.
f30post
