08-18-2023, 01:27 PM | #1 |
Rep 73
2019 X5 XDrive40i - Creaking Sound, Dealer Unable to Diagnose
Need some help diagnosing a creaking sound, getting pissed off with my dealer. Bought my X5 MSport back in May, it has the air suspension, odometer just hit 50,000km, built Oct 2019. A few weeks after purchase in June, I started to hear what sounded like a faint "knocking/creaking" noise at slow speed, going over bumps etc. You can also hear it when accelerating or decelerating, where the vehicle moves forward or backwards and the weight shifts. It’s been into the dealer twice, two months apart, and they could hear the sound. On both occasions while up on the ramp, they found mechanical items needing replaced: two front tension struts which were corroded and leaking and on the second visit they found both front lower control arms needing replaced. The most recent visit was two weeks ago. The sound has come back again and is really loud this morning, so much so I’ve been able to record it on my cell phone. The scenario here is me driving around an empty cinema car park at 10km/h, no speed bumps, mainly flat ground. You can hear the creaking sound as the vehicle accelerates and decelerates and when turning or goes over a bump. It’s booked to go back in again on Monday. It goes out of warranty October 30th so I’m crapping myself that the air suspension is damaged or something expensive is at fault. I’ve posted the audio clip (1m 45s) – if you guys have any ideas what would make this sound, please let me know your thoughts. I’m going to refuse to take the vehicle back until it’s fixed this time. Thanks for reading
I can't upload MP3s - here's a link to the file on my OneDrive cloud share: https://1drv.ms/u/s!AmIoZuJAOxlnhawG...0JBbw?e=V47H3e
2011 335 xDrive - retired
2019 X5 xDrive40i MSport |
08-18-2023, 01:34 PM | #2 |
242
Rep 319
Drives: 2024 X5 M60i, 2020 RRS SE, 201
This sounds like the issue I had with my 2020 X5 m50i when it was new. I have posted about this in the past. My vehicle was at the dealer and body shop for a total of 6 weeks before it got taken care. The car was missing a spot weld, and would creak over bumps, and when accelerating and decelerating as you had stated.
Search in the threads for “creaking sound” and you should find it. Dealer paperwork was uploaded as well.
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic 2020 Range Rover Sport SE White 2017 BMW 530i xDrive Black 2005 BMW Z4 2.5i Jet Black |
08-18-2023, 06:16 PM | #3 | |
Rep 73
08-18-2023, 07:31 PM | #4 |
242
Rep 319
Here is the link. Kinda lengthy and others had chimed in with related and unrelated issues.
https://g05.bimmerpost.com/forums/sh...creaking+sound
RADMJK
2024 BMW X5 M60i Brooklyn Gray Metallic 2020 Range Rover Sport SE White 2017 BMW 530i xDrive Black 2005 BMW Z4 2.5i Jet Black Last edited by radmjk; 08-18-2023 at 07:36 PM.. |
Stuabroad16.50 |
08-19-2023, 04:56 AM | #6 |
242
Rep 319
No I just surmised it was under passenger side rear seat bench because that was the location of the sound and I know they removed the seat. I think they had it nailed down earlier on but did not do a strong enough weld which is why it would come back. On that final visit though they did ultimately correct it for good.
RADMJK
Stuabroad16.50 |
08-19-2023, 10:31 PM | #7 | |
Rep 73
08-20-2023, 12:54 AM | #8 |
Rep 3,757
Is it possible to isolate between the chassis issue (miss spot weld, damn), or suspension issue? This would be my first step.
Before seeing your spot weld post, I was thing check ball joints and bushings. As they wore out, there will be play between suspension component and the subframe, when you compress the suspension, they will make noise. 50km seems to bit early for that, but it should be very simple check by any mechanics with a lift As for the spot weld missing, I found it very hard to believe. Spot weld are done by robots these days, if they miss, they will miss for the entire batch of production. And fixing spot weld, I am not sure this is what dealer can fix easily without some case from BMW. After all, it is chassis defect, safety related. The person who can do it needs to be an experience welder for cars, meaning they need to do this often. A random tech at BMW dealer, probably never done one before, won't do a proper job. But then let me also back up a big, how the hack dealer is able to find it is also a puzzle. They cannot see it easily, they must open some panels, grind off paints, adhesive .. in order to even examine the weld. This also mean they should leave visual evident behind. Can you ask for picture of where the problem is, and picture of the post welding?
2022 G05 B58/PHEV
+ a few very old BMWs |
08-20-2023, 07:53 AM | #9 | |
242
Rep 319
RADMJK
08-20-2023, 08:20 AM | #10 |
Rep 596
We had a very slight knock or clunk sound when going over mild bumps. The SIB the dealer referenced (attached) does mention creaks too, so perhaps the symptoms manifest themselves differently from car to car. They replaced both tie rods for us, and the sound is gone. Good luck!
08-21-2023, 01:41 PM | #11 | |
Rep 73
