Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Pop on cold start and rough idle + vibrations - N54
      10-01-2023, 06:17 AM   #1
Sauryy
Drives: E92 335i N54 DCT
Hello there !
I have E92 335i N54 with DCT, modded to stage 2+ with all supporting mods ( over 5 years).
Month ago i was traveled with car to long trip vacation with my 335i, so after we went back from vacation.
- My car start to misfiring on idle, so i put new sparks NGK 97968 with gap.
The vibrations have stopped a bit, but they was still there, so i get angry and changed to Stage 2 LPFP, with EKPM3 module, all of index 9 and mis-mas-ch set of injectors, to brand new index 12 injectors, properly coded.
And im still not getting on bank 2 AFR 234.94 after Index 12.. can you please somebody check out my logs? I will be very happy, because i cant find anybody near me, who know N54 problems.
I will post Datazap logs from MHD.
a) Cold start with Index 12
b) MHD Stage 2+ Index 12 - 2500rpm 3. gear WOT
c) MHD Stage 2+ Index 12 - 2700rpm 3. Gear WOT
d) MHD Stage 2+ Index 9 and mix of injectors 4. Gear WOT
Can somebody checkout the new index 12 logs please?
- Why im not reaching a 234 AFR? and why i get drop when i start cruise from idle to 500rpm please?
THX So much for everybody!
https://datazap.me/u/sauryy/index-12...25-26-27-28-29
      10-02-2023, 01:27 PM   #2
SlowE92
112
Drives: E92 2007 335i, E60 2008 535xi
Originally Posted by Sauryy View Post
Hello there !
Did you get any codes when you started misfiring? That would help narrow the problem down.
      10-02-2023, 02:28 PM   #3
Sauryy
Good night, no there is no Active codes in MHD application. Only shadow codes, they message about Catalytic converter ( 29F4, 29F5) , and Fuel pump, plausibility.
This error codes is doing nothing, if im right.
the LPFP is Stage 2 Fuel-IT! Walbro 525.
- Can wastegates cause a vibrations to engine in low rpms like 1500-1700?
If my turbo´s WG are blown?
      10-06-2023, 03:46 AM   #4
Sauryy
Yes, im catless, connect is okay.
- Yesterday i test it again and i found specific think
- when i cruise and have like 5. gear 60km/h and 1400rpm and start to accelerate --> engine have vibrations to 2000rpm and after these rpms everythinks ok.
- WHEN i set cruise control in 5. gear 60km/h and 1400rpm and cruise control starting to acceleration to 180km/h --> there is no vibration and misfire in pull.. so whats wrong..
      10-06-2023, 07:23 AM   #5
Mrmigs2011
Drives: 2006 E92 335i
Same issue here,
Light missfire between 1400 rpm to 2000.
You can hear it when trying to hold revs in neutral.
No closer to finding it. Suspect either injectors or potentially wastegates but I'm not sure car actuates them so low?
      10-06-2023, 09:08 AM   #6
whyzee125
Drives: Dinan stage 2 335i
I would be suspicious of your O2's
      10-06-2023, 01:13 PM   #7
SlowE92
112
I had something very similar to this where light throttle and 2000 RPM id have vibration, and anything after 2k RPM it would stop vibrating. It was my 02 sensors on the downpipes. 29F4 and 29F5 are normal shadow codes however if youre catless because I have them as well, MHD just suppresses them.
      10-12-2023, 04:06 PM   #8
Sauryy
Thanks all for your replys, which O2 sensors should i buy? If im catless, did i need change all 4 lambdas or just change O2 on downpipes and secondary o2 let them be?
Next code which popped on MHD in active codes Is 2DED - Power Management, closed-circuit, current violation
      10-13-2023, 09:30 AM   #9
Jaronbwall
Driving cars and riding bikes really fast
Jaronbwall's Avatar
Drives: 2009 335i
I would only replace the O2 sensors on the downpipes. Those suckers are pricey. You can also try cleaning them over night by hanging the tips in a cup of gasoline. I cleaned mine when I went cat-less. Low chance but worth a try.
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads.
https://www.strava.com/athletes/8309149 Follow me on Strava
      10-13-2023, 10:31 AM   #10
SlowE92
112
Your rail pressure at Idle is 2k?? that ain't right should be 750. HPFP?
2007 E92 335i - MHD, Turbo Technics 19T's
2008 E60 535XI - JB4
2010 E92 335i - JB4, Borg Warner EFR 8374
      10-15-2023, 07:19 AM   #11
Sauryy
Yes, idle hpfp pressure on first cold is 2K+ psi, after warming up process ( 90 seconds ? ), hpfp will drop to 400-700 --> its normal
Maybe u just didnt look into mine logs properly. U will saw it in other ones
      10-16-2023, 12:53 PM   #12
SlowE92
112
When was the last time you had an intake cleaning done?
      10-16-2023, 11:19 PM   #13
Sauryy
Hello, never been done before. Car have 220 000 kms
Which lambdas should i order ?
      10-17-2023, 07:28 AM   #14
Jaronbwall
Jaronbwall's Avatar
Drives: 2009 335i
"never been done before" - wtf, no offense this is basic maintenance on an n54. If the intake nasty it's choking out the air/fuel ratio on start up. It's probably affecting your performance as well.
      10-17-2023, 09:06 AM   #15
Sauryy
Yes, never been before - because nobody in Czech Republic know wallnut blasting technology, in our country is only known only Hydrogen decarbonization.
Thats why i didnt IT.
      10-17-2023, 01:03 PM   #16
SlowE92
112
And they would be the 02 sensors after catalytic converters.
      10-18-2023, 01:51 PM   #17
Sauryy
I will change all 4. Because is stupid job. My question is which o2 sensors i should order?
The part ID for regulating lambda is - 11787558055(L=1400mm);11787558087(L=1200mm)
for monitoring lambda is -
11787545074(L=560mm); 11787545075(L=490mm)
My question is = should i order Bosch or GENUINE o2 sensors?
Thanks for question.
      10-18-2023, 02:59 PM   #18
SlowE92
112
Before you order anything can you post a log for when the car is warmed up and at idle?
      10-19-2023, 02:57 PM   #19
Sauryy
I got two logs
1)warmed up idle
2)warmed Up idle + drive home And parking process
https://datazap.me/u/sauryy/warmed-i...12-mhd-stage-2
Thanks you.
      10-19-2023, 04:43 PM   #20
SlowE92
112
I got two logs
1)warmed up idle
Thanks you.
Scratch what I said about AFR during idle, your AFR are fine during idle.
      10-19-2023, 04:47 PM   #21
SlowE92
112
I got two logs
1)warmed up idle
Thanks you.
Your LTFT 2 is slightly high after youre warm and during idling, usually indicates a small boost leak of some sort.
      10-23-2023, 09:44 AM   #22
Sauryy
Hi, i will check out all hoses, it should be vacuum and intake hoses?
- I got two new log
a) one is WOT on 4. gear
b) Warm up idle
- All of logs were made on DocVu custom flash. Can you please check again?
- My decision is the DocVu flash make car slower, stage 2+ from MHD feels more powerful for me, because its have more low-end torque, turbos have high mileage they might not be capable of reaching target boost?
https://datazap.me/u/sauryy/index-12...24-25-27-28-29
