      10-01-2023, 08:50 AM   #1
IFlyX5
IFlyX5's Avatar
Drives: '21 X5 s40i, '22 X5 x45e
iPhone 15 issue with BMW wireless charger
According to Macrumors:
"Over the past week, some BMW owners have complained that their iPhone 15's NFC chip no longer works after charging the device with their vehicle's wireless charging pad, according to comments shared on the MacRumors Forums and X, formerly known as Twitter. Affected customers say the iPhone goes into a data recovery mode with a white screen, and the NFC chip is no longer functional after the device reboots."
https://www.macrumors.com/2023/10/01...e-15-nfc-chip/
2021 G05 X5 s40i Phytonic Blue | Ivory White Vernasca | Anthracite-Brown Poplar Matte Trim
2015 F10 535i M-Sport Space Gray | Black Nappa (Gone)
      10-01-2023, 09:26 AM   #2
Boardmember
Drives: BMW X5 xDrive40i
‘Rushed to release’ much?
      10-01-2023, 09:29 AM   #3
Heavyd
Heavyd's Avatar
909
Drives: 2024 X5 50e
So the NFC chip is fried after charging it in the charging tray?
It would be nice if they mention in which BMW models.
      10-01-2023, 09:50 AM   #4
M42
Drives: X5
I’d assume all wireless chargers in BMW for now.. but that’s pretty crazy!
      10-01-2023, 09:57 AM   #5
cobramite
1274
Drives: '24 X6 M60i, '22 Macan GTS
Wireless charger problems are nothing new or unique to BMW.
      10-01-2023, 10:06 AM   #6
LDT
LDT's Avatar
2804
Drives: 2024 X5 M60i
Charging pad issues do not shock me at all. I never use it except for storage. Never have I had a in-car charger that was worth a hoot. Plug it in and hit the road. No big deal.
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^
2017 X5 35d--still in my diesel phase
2015 GL350--diesel burner and highway Queen
2013 Audi S6--yr. 1 of switch from V10 to V8
bandersen924.50
cdhowell129.00
      10-01-2023, 10:18 AM   #7
gadgetfreak2024
240
Drives: 2024 X5 50e, 2011 X5 50i M-Sp.
Why would you jump to that conclusion?
Anyway, I've used the pad in my 50e with my 15 Pro Max. It worked as well as it did with my 14 Pro Max and so far has done nothing untoward to the phone.
That being said, the location and design of the pad is just silly, given the fact that wireless charging always creates heat -- and that heat should have a better path for dissipation than the little unventilated phone cave that that BMW created.
So if I really need to charge, I'm more typically using a USB-C cable now. To me, the pad is really a novelty rather than a tool, based on BMW's design decisions.
      10-01-2023, 10:31 AM   #8
Heavyd
Heavyd's Avatar
909
Drives: 2024 X5 50e
Can the charging pad be disabled in idrive?
      10-01-2023, 11:14 AM   #9
pixelate
pixelate's Avatar
72
Drives: X5 M60i
I have noticed that my iPhone 14 Pro Max gets very hot on my 2024 X5's charging pad. So I avoid using it unless I really need to charge it in the car. A related weird thing I've noticed but not really diagnosed or proven, is that when I instead plug it into the USB-C charging port in the center console storage bin, to charge it, it seems like CarPlay won't connect to the phone. That doesn't make much sense, and I need to see what's going on there.
2024 BMW X5 M60i manhattan green
1998 Porsche Boxster arena red (race car since '11)
--previous bmws--
2008 BMW X5 xDrive48i mineral green
1972 BMW 2002 agave green
      10-01-2023, 11:37 AM   #10
LDT
LDT's Avatar
2804
FWIW, CarPlay works when my iPhone 12 is plugged in.
      10-01-2023, 12:39 PM   #11
Gdwheel
Drives: 2022 X7 40i
I have the 15 PM and have used my wireless charger all the time, including 6 hours of driving last weekend. I used Apple play today without issue. '21 X5.
      10-01-2023, 01:07 PM   #12
cobramite
1274
^^^^^^^This.
      10-01-2023, 03:52 PM   #13
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
917
Drives: 2020 X5 M Competition
Not in the user interface natively that I'm aware of. Folks were previously retrofitting their BMW's with wireless chargers during the shortages and then coding it on. I suppose you could just do the opposite with BimmerCode or similar.
      10-01-2023, 04:42 PM   #14
realdah
Drives: 2024 X5
I am the first batch of victim on this issue... got iphone 15 plus on Sept 22nd, then went with my LCI, suddenly apple pay not working at all.
Tried many things did not work, then decided to return it back to apple store.
From the original macrumor thread, looks like it is nothing to do with BMW wireless charging, at least it is not a hardware problem. (but TBH, I always use wireless charging even at home without issue, only happened after using X5 charing, so it is still part of triggering)
BTW, my iphone 12 pro has no issue so far regardless.
      10-01-2023, 04:56 PM   #15
jad03060
Drives: X5 45e
A few points...
- the iPhone pro Max exceeds the BMW size requirements for the charging pad
- there are some known issues with overheating on the 15 series related to a bug they've identified in the firmware, and three programs that are causing the phones to overheat: Instagram, UBER, and one game
- there's a lot of background setup being done for the first few days at least on a new phone that will cause it to run warmer than normal
- if the phone is not properly centered indicated by the status LED (in a crappy position, so hard to notice IMHO), it will not properly charge potentially running warmer
- iOS version 17.1 is expected soon to address the firmware bug, but look for the app updates to resolve their issues.
- note, there is a case maximum thickness listed in the manual, so that could be an issue, too. A case's existence can act like an insulator, making the phone warmer
- if the phone detects it is running too hot, it can shut down some functions to help preserve itself
I've not had issues with my older iPhone with a case on it, but a new 15Pro should be delivered on Monday, then I'll see what my particular situation is. I do not use Apple CarPlay, or normally run apps on my phone, so the only loads on it are background stuff and charging. I put it in the tray when I'm expecting to go through marginal cellular coverage to take advantage of the LTE compensator.
X3_Alaska232.50
      10-01-2023, 05:35 PM   #16
gadgetfreak2024
240
As it does for me as well on my 14 and 15 Pro Max
      10-01-2023, 11:11 PM   #17
cat3dual
Drives: X5 50e
FWIW: My 15 Pro Max was replaced under warranty on Saturday at the Apple Store. Apple Pay and the digital key were not working. Remote Support and Genius Bar diagnostics showed two failures with the NFC sensor. As far as they could tell, the flaw was present at delivery of the original phone. They said it was a hardware issue and immediately replaced the phone with a brand new 15 Pro Max updated to 17.0.2 software and it has worked flawlessly since. Additionally, it’s been on the wireless charger pad of my ‘24 50e multiple times since with no issues. At only 1130 am, mine was the third iPhone 15 warranty replacement my tech had processed that day! The other two were supposedly overheating issues.
      10-02-2023, 12:10 AM   #18
apw2607
Drives: 2024 X5 50e M-Sport
The cable is providing power only to the phone. CarPlay data connection still works wirelessly.
tooloud101054.00
      10-02-2023, 06:34 AM   #19
nZtiZia
nZtiZia's Avatar
Drives: eVeRyOnE mAD!
CarPlay has been an issue with 2024 X5, but most don’t have problems. it seemed to be related to iDrive 8 then resolved with iDrive 8.5, but I haven’t really been following the timeline. TurtleBoy is more abreast
that said, CarPlay is wireless. whether the phone is charging wirelessly or plugged in, it should work unless you have preexisting CarPlay connection issues because it doesn’t make sense it would stop working while being plugged in. I have an iPhone 14 Pro and it works (note I do have a 2021 X5 in iDrive 7 which has had solid CarPlay performance since I bought it)
      10-02-2023, 06:52 AM   #20
SwissBeemer
311
Drives: '24 X5 50e
No coding on LCI's anymore.
      10-02-2023, 07:11 AM   #21
LDT
LDT's Avatar
2804
Understood but earlier someone said CarPlay doesn’t work when the phone is plugged in.
      10-02-2023, 07:21 AM   #22
njfoses
Drives: 20 M850i, 22 X6 M50i
This thread should be locked. BMW wireless chargers are not causing iPhone 15 failures specifically.
Appreciate 3
nZtiZia5773.50
ddavtian221.00
