BMW M3 and M4 - The Icons
home
G80 BMW M3 and M4 General Topics Regional Forums UK
      10-10-2023, 04:28 PM   #1
G80_Bob
57
Drives: 23 M3 Xdrive
Secondary Cats removed and BMW service
For those of you running a midpipe or catback with the secondary cats removed, has it been an issue when you take the car into BMW for an Oil Change?
      10-11-2023, 04:17 AM   #2
LeighD
Drives: BMW M4 2016 F82
No they wont care however this will invalidate any warranty and will be an MOT failure, but for an oil change wont be any issue at all.
G80_Bob57.00
      10-11-2023, 10:17 AM   #3
beachBmmr
beachBmmr's Avatar
Drives: 2023 F90 M5 SG/AB
I got tons of positive comments about how the car sounded with my psi midpipe from service team at Classic (now sewell) in Plano.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10
G80_Bob57.00
      10-11-2023, 10:35 AM   #4
Info@mad-us.com
BimmerPost Supporting Vendor
Info@mad-us.com's Avatar
1952
Drives: bmw
Haven't heard of anyone having a warranty issue with any of our midpipes.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
G80_Bob57.00
      10-12-2023, 02:33 AM   #5
LeighD
Any modification to stock parts in the UK will invalidate bmw warranty im afraid
G80_Bob57.00
      10-12-2023, 02:06 PM   #6
G80_Bob
57
Thanks for the replys, having a US Spec car in the UK, and not being entirely familiar with the process, I did not want to get hit with an MOT failure during an oil change. Im thinking of taking it to a BMW Service center and not a dealer instead.
      10-27-2023, 02:53 AM   #7
worsy
Wales
43
Drives: BSM G80 due Sept 1st!
You can only fail an MOT if the car is being MOT tested. in the UK it is an annual test following it's 3rd anniversary of registration.
Although there is an emissions test, the vast majority of testing around the exhaust system is a visual check. You can for example gut the OPFs but leave them in place and it will pass.
Of course gutting the OPFs would invalidate your warranty but at 3 years old, you may not care anyway.
G80_Bob57.00
      11-08-2023, 02:49 AM   #8
The Lum
Drives: G20 M340i LCI
Just watch out as this is partially true. Any fault found on the car to be a direct result of the modification would not be covered under warranty. For example a remap on the engine causing an injector to fail would not be covered however a strut top failing and you having changed mid pipes would still be covered as the modification was not the root cause of the fault.
Its all a bit of a grey area but that's as good an example I can think to give.
G80_Bob57.00
Tubes2334.00
g80
