10-17-2023, 08:02 PM | #1 |
Rep 16
2024 X5 Engine Pinging/Knocking Noise
Hello everyone,
I recently leased a 2024 X5 xDrive40i, that I picked up about 2 months ago. Almost immediately I noticed a pinging/knocking sound coming from the engine, usually upon acceleration from a stop or low speed. It is also more pronounced on uphills. The sound is not very loud, but it is noticeable and not normal. I've brought the car in to my dealer twice so far. The technician at my BMW dealer drove with me and confirmed the pinging noise. But while they had my car, a BMW test engineer checked the car himself and made a determination that “the car is operating as designed” (but acknowledged the noise!). They refuse to do anything, because according to BMW, there is nothing wrong with the car. I had a good local non-BMW mechanic drive my car and he immediately heard the knocking and said the engine has an ignition timing problem and should be repaired. He was amazed that they wouldn't do so btw. I know that my only recourse is through legal channels now, but after talking to an attorney, I've learned that the Lemon Laws in my state are very much in favor of the manufacturers. It's going to be tough. My question to the forum is this: are there any other new owners of the 2024 model who are experiencing this problem? I'm wondering if BMW is aware that they have a manufacturing defect on their hands and fixing my car would be an admission of that. It's just so crazy that they wouldn't honor their warranty for an obvious engine problem. Thanks. |
10-17-2023, 09:35 PM | #2 |
Rep 4,777
Possible to share a sound track?
In B58, ignition timing is all software. I wonder what could throw ignition timing off. Maybe software itself? Cam position sensor?
2022 G05 B58/PHEV
+ a few very old BMWs |
10-17-2023, 09:39 PM | #3 |
Rep 176
I've heard of lawyers just saying things to get out of taking a case they don't want. Research the lemon law in NY closely, but you will probably need statements from three mechanics that the sounds are abnormal, especially for that engine and that diagnosing could result in engine disassembly or replacement.
10-18-2023, 09:47 AM | #5 |
Rep 16
10-18-2023, 09:50 AM | #6 | |
Rep 16
10-18-2023, 09:56 AM | #7 |
Rep 16
If that's true then I would think this would be a simple adjustment, rather than a major repair (or replacement) that BMW clearly wants to avoid. I will try to record it when I'm in a quiet area. Thanks for your response.
10-18-2023, 02:08 PM | #9 |
Rep 96
Drives: 2020 G05 40i M-Sport 2023 330i
Could be something basic as a bad coil or plug.
F10 M5 AlpineWhite/SakhirOrange[DCT]
10-19-2023, 11:03 PM | #10 |
Rep 212
If the car is pinging, it isn't going to be a "software adjustment". OEM's dont develop customer ECU calibrations. All calibrations will be the same for the model or even multiple model years, unless BMW made mid or year to year adjustments.
There is probably a mechanical or electrical issue that is causing the issue, but it isn't the calibration. It should be addressed as soon as possible as ongoing pinging is doing a small bit of damage continuously or at least causing some degree of overpressure and wear on the engine. |
10-20-2023, 03:34 AM | #12 | |
Rep 63
Already been to service once and they also acknowledged but tech said they thought it was normal. When I sent this video today (a month later) they said to bring it back in for them to take another look. Definitely doesn’t sound like a $104k V8 to me but luckily the cabin in so well isolated sound-wise I don’t hear much inside the car! My partner thinks it may be a “lifter tick” which there are some videos about on YouTube. Here’s my video recording |
10-20-2023, 03:45 AM | #13 |
Rep 1,460
I know the B58 engine has a rattle sound to it. It happened on two Z4 and an M340i that I had owned. The rattle is louder on acceleration.
https://www.youtube.com/shorts/IsFYg9dP_S8 Rob |
10-21-2023, 04:54 PM | #15 |
413
Rep 333
My car doesn’t make any pinging/knocking sounds on initial acceleration. Injector clicking can be heard at idle from outside the car with the hood open, but you shouldn’t be able to hear anything from inside the cabin while accelerating. What is your fuel economy like? Is it exceptionally poor despite conservative driving? The B58TU2 in the 2024 models has an electronically controlled Vanos and they also overhauled the ignition system and there are now dual injectors…. In short, all these optimizations introduce opportunities for engine faults. I would try to elevate your complaint to BMW corporate (go over your dealership’s head) because I’m sure their engineers really would like to know if there’s an engine fault. Keep us updated!
10-21-2023, 05:22 PM | #16 |
Rep 4,777
I am with your thought process. Electric vano, so cam phase is now software instead of oil pressure. Ignition timing is definitely software. Port injection meaning air + fuel are being suck into cylinders instead of just air as in DI. But still, there are 2 dedicated knock sensors listening the “ping”, and make adjustments accordingly. If “ping”s are detected and presist, I would expect a CEL. All of these cannot go unnoticed to most basic sensory of any modern engine, not to mention German luxury high precision variations.
Also, from the video posted above, the sound isn’t ping. Ping generation doesn’t happen at idle either, it happens in high engine load, say high gear low engine rpm and large input of throttle.
2022 G05 B58/PHEV
10-22-2023, 07:45 AM | #17 |
Rep 16
Thanks for everyone's replies to my original post.
There is no question that the sound is engine knocking. This was verified by my BMW dealer's technician, a BMW-NA test engineer, and an independent auto mechanic. The problem is that the test engineer is claiming that the knocking/pinging is acceptable ("car operating as designed"). The noise isn't extremely loud, but it is very noticeable during acceleration, and not normal. The CEL is not on btw. The dealer's tech told me (verbally of course--would never put it in writing) that the test engineer acknowledged "an ignition timing problem." Which is why they refuse to fix the car. I was curious if other owners of the 2024 model were having a similar issue, as I am aware that there were some changes made to the engine (as people on the forum pointed out, and also the dealer's technician). I wonder if BMW is concerned they have a bigger problem on their hands than just me. Anyway, after multiple exchanges, my case was escalated to a new customer service area at BMW-NA. We'll see what happens. But either way: a brand new BMW engine has a problem, and they should have honored their warranty from the beginning. Again, thanks for everyone's input. |
eelnoraa2864.50 |
10-22-2023, 07:59 AM | #18 | |
Rep 16
Thanks for your reply. BMW corporate IS the problem here. They acknowledge the noise but are saying the "car is operating as designed." Maybe you're right that their engineers would want to know about an engine fault. But I can tell you that BMW isn't willing to do anything about it (so far). |
10-22-2023, 04:56 PM | #20 |
Rep 16
10-22-2023, 05:00 PM | #21 |
Rep 942
I would try using another tier 1 brand for a couple of tanks then if no change, try an octane booster just as a definitive confirmation test
Two is One and One is None
10-22-2023, 06:01 PM | #22 | |
Rep 63
Before long drive, high revs After long drive, high revs |
Tags |
pinging knocking |
