2010 2011 BMW 5 Series Forum F10 Knock from the front left wheel when accelerating. |
11-05-2023, 09:47 PM | #1 |
Rep 1
I have a stock 2011 535i xdrive. Both front CV axles were changed 2 weeks ago along with the lower control arms. Today the front left wheel made a metal knock when i let off the gas at about 100mph(wasn't accelerating too hard). Then, i got off the highway, drove around a bit and the noise wasn't appearing anymore. Went to a parking lot and drove in full lock to the right, then to the left, and a rubbing noise appeared with more knocking. Looked around the suspension a bit, nothing seems to be loose, although there is a bit of oil to the side of the axle boot on the new axle. Now the front left wheel makes a knock and a vibration that i can feel through the floor if I suddenly accelerate. Under smooth acceleration it's good. Also, the sway bar is very rusty, but seems solid as I couldn't move it a bit with my hand. Any ideas what could it be?
11-06-2023, 12:11 AM | #2 |
Rep 2,591
Probably one of the control arm bushings completely went bad.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
