11-19-2023, 11:13 AM | #1 |
Rep 129
Augmented view switch to right side display ?
My augmented view is in my instrument cluster behind steering wheel I’ve tried everything to move it to the right display , how ?
Thank you |
11-19-2023, 11:16 AM | #2 |
Rep 5,796
Drives: 2024 BMW XM Label
You can’t do both at the same time. It’s one or the other. In order for it to show up on the main screen, you’ll have to change your view on your instrument cluster to something else first, then change the navigation display preferences within iDrive.
11-19-2023, 12:02 PM | #3 |
Rep 129
Thanks I’ll try this today
Not really sure how Settings on navigation then guidance them change augmented to not instrument cluster |
VirtualGuitars7860.50 |
11-19-2023, 12:12 PM | #4 | |
Rep 5,796
Also note that unlike the version on the instrument cluster, it will disappear after you get to a certain speed which I think is around 25 mph; however, it will pop back on automatically for an approaching turn or to show you what lane you need to be in for an upcoming exit This is the way it was on my iX M60. It will also only appear on the main display when you’re navigating to a destination. |
11-19-2023, 03:50 PM | #5 |
Rep 566
Drives: XM/XB7
On steering wheel, right side, middle button between phone and microphone buttons. Press it (3 dots 3 lines) then in instrument cluster move augmented reality to another choice. I use asssisted view.
Then push map button next to home button. Select settings on right side, then guidance, select augmented view to be control display. |
11-19-2023, 04:30 PM | #6 | |
Rep 5,796
XM Label904.50 |
