F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > 3 and 4 Series Ordering / Pricing / Order Tracking Forum (and European Delivery) > Starter/Ignition fault after changing the battery, starter and repaired alternator
Studio RSR
      12-30-2023, 01:31 AM   #1
georgerazvan
Drives: BMW F34
Exclamation Starter/Ignition fault after changing the battery, starter and repaired alternator
Hi everyone!
My car model: BMW F34 xDrive
A few weeks ago I saw for the first time “Starter/Ignition fault” error. I changed the starter. After a while I repaired the alternator because I got “Battery is not being charged” error. From time to time there was a wire burnt smell inside the car, but only for a second. I think that smell is from the alternator(if that will be a wire that should smell all the time isn’t it?).
Now after a few weeks my car is not starting. I got the “Starter Ignition fault” error but it starts if I get a boost for the battery from another car. Trying to start it again and again, now the battery is drained. I changed my battery 2 days ago with a new one, I registered it and the problem persists, it works only a few hours but started only helped by another car boost.
What should I do? could be the alternator not charging the battery while driving even that was repaired? but if yes, why I get the “Battery not being charged” more than one second and that’s it? I measured and the voltage was right when started, then 14V+.
My model does not have a fuse for start stop, so I eliminated the possibility that can be the fuse itself.
      01-03-2024, 07:43 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Search 'parasitic power drain'.
      01-23-2024, 10:47 AM   #3
Merlino31
Merlino31's Avatar
Italy
Drives: BMW f31 320 modern
Try to disconnect IBS sensor, it could be faulty
BMW f31 320d Modern 6MT
      01-31-2024, 10:39 AM   #4
Donnydarko1
Drives: Bmw 320d 2013
Having same issue, did you get sorted?
f30post
