      01-23-2024, 11:05 PM   #1
arRod1981
arRod1981's Avatar
Drives: 2022 BMW X5 45e M-Sport
New BimmerCode Automatic Seat Heating Option?
Anyone else see that there are new automatic seat heating options in BimmerCode and actually code it? If so, do they work?
I miss that on my '21 X3 with ID7 "lite" you were also able to have the front passenger seat come on automatically at a set temperature as well just like the driver's seat. Not sure why that feature isn't available on the G05.
      09-27-2024, 11:26 PM   #2
thepianist1
45
Drives: BMW X3 G01
After coding this, under Seat and Steering Wheel Heating, I see checkboxes for both driver and passenger, however the passenger checkbox and temp selector does not work, so I don't think the hardware is there.
Now I can set two driver seat heating rule, one under Climate Control Rules and the other under Seat and Steering Wheel Heating, i.e.
below 60F turn on lowest heat
below 50F turn on highest heat
      09-28-2024, 12:09 AM   #3
arRod1981
arRod1981's Avatar
The driver side seat and steering wheel automatic heat activation was always there for me on my 45e, but the passenger and rear seats wasn't. I had to get my TCB replaced yesterday and they updated my iDrive to 07/2024.55 along with the replacement, and the coding for automatic heat activation works on all 4 seats now.
      10-02-2024, 05:14 PM   #4
R34L15T
Drives: 2019 BMW X5 30d M Sport
I’ve always had the automatic heating on steering and seat at set temperature.
This is through the climate rules on idrive.
BMW X5 30d M Sport
      10-25-2024, 03:04 PM   #5
thepianist1
45
Drives: BMW X3 G01
Yes on my 2022 LCI G01 X3 climate rules does not auto turn on seat heating for passenger, but coding the seat and steering wheel heating menu enabled that and, for driver, two seat setting temperatures. There's probably another code to have the seat heating turn off when it increases above the set temp.
      11-03-2024, 06:02 AM   #6
Stephen bennett
Drives: Bmw go5 m50d
Hill decent control question
Does anyone know which fuse controls the HDC switch?
Had to replace the parking brake centre control switch . This failed i installed a new one reconnected the unit but HDC doesn’t light up or operate.
Any ideas
