      01-24-2024, 03:03 PM   #1
ady.adrianu
Drives: g05 45e
air suspension squeaky
My g05 45E 2020 has around 80k km, the warranty just ended and they changed 2 suspensions on warranty, they were making squeaky sounds.
Problem is now 1 month later out of warranty i started noticing the exact same sound from another unchanged suspension , the OEM part is like 1500 euro each just the part and likely that I will have to change both remaining suspension since clearly they won't last much longer.
The suspensions work fine, no air leaks, etc is just the squeaky sound which i've red that in the cold temperatures is worst and it only happen from time to time at low speeds and not as bad the ones that got changed.
My question is, does it really need to be entirely changed ?
Can I just maybe change the air strut only? Maybe some lubrication can be put to avoid the squeaky sound?
What would be the cheapest and best solution to keep me going for another 10-20k km. Thanks
      01-25-2024, 09:22 AM   #2
bloom
bloom's Avatar
41
Drives: none
i have 80k on my g05 and its never squeeked.
now that i think about it i dont want to know or ill be listening for it...
      11-16-2024, 11:01 AM   #3
theflash5646
Drives: BMW g05
Did you found a fix?.i have the same problem
