BMW E46 M3 - Legend Eternal
home
Technical Sections Engine / Transmission / Exhaust / Drivetrain
      02-09-2024, 12:07 PM   #1
jeday973
Drives: E46 M3 Vert 6MT & E90 328i
e46 M3 won't start - DME Codes HELP
My M3 won't start, the battery is full functional, car cranks strong but wont fire up.
Scanned using Foxwell nt510elite scan tool.
Codes:
01 - DME Driver/Fuel-pump relay (idk why is this was replaced 2k miles ago ;fuel pump fuse is good).
0A - DME Signal camshaft sensor exhaust
0E - DME Heating for tank-leak diagnosis module (DMTL)
0F - DME camshaft sensor synchronization to crankshaft
13 - DME Relay, Secondary-air pump
1B - DME Changeover valve, tank-leak diagnosis module (DMTL)
30 - DME Interface, air conditioning (E46) / relay A/C Compressor(E36/7)
B9 - DME Function, exhaust VANOS
A few days ago I literally had 0 DME codes and these all hit at once.
More about my vehicle...'03 E46 M3 Vert 6MT 133k miles 05/2003 Production.
Recent repairs include:
New genuine BMW fuel pump and fuel relay 2k miles ago
Full VANOS overhaul 500 miles ago
Beisan Vanos Seal Kit, Beisan Sealing Plate O-rings, Beisan Anti Rattle Kit, Re-Drilled S54 Oil Pump Disc, Beisan S54 Nylon Chain Guide, BMW Vanos Gasket, BMW Upgraded Cam Hub Bolts, BMW Vanos Gearbox Hex Bolts, Vanos Oil Pressure Line & Seal Rings, Carry out S54 Engine Timing using Genuine BMW S54 Tools.
New Genuine BMW fuel cap 500 miles ago
Any insight/advice would be much appreciated. Located in SoCal.
Tags
e46m3
e46m3
