      03-05-2024, 05:33 AM   #1
iCARMIX
iCARMIX's Avatar
Hong Kong
487
Drives: BMW
X6 genuine brake upgrade. Holy 6 Pots!
We all know that the braking systems in most of these SUV models straight from the factory are a bit "meh." I mean, for heavy rides like the X series, the braking performance is just so-so. But hey, if you're looking to kick things up a notch and get yourself a more powerful braking system, you've got options. You can go for the factory M Performance 4 POT version with in the front and 1 POT in the rear, which would be enough. But before doing that, check out this picture, check out this BMW X6 (G06) owner. They took it to the next level, man, with the factory M Power version, rocking a high-performance 6 POT braking system.
The system comes with these eye-catching red M Series brake calipers, paired with bigger and better heat-dissipating semi-floating discs, measuring a beefy 395mm in the front and 380mm in the rear. Look, don't get me wrong, the 4 POT brake calipers in the M Performance version already deliver some serious stopping power. But these 6 POT brake calipers in the M Power version, man, the best of the best. With their pistons arranged from small to large, they not only provide some impressive braking performance but also give you a smoother and more controlled braking experience. No sudden surprises there.
Here is more on this in my shop:
https://icarmix.com/product/genuine-...-g05-x5-g06-x/
Here's how the process went:
cncmastr1631.00
Tags
g06 x6, hong kong, icarmix, m performance brake
