      03-23-2008, 03:50 PM   #1
Templedogg
Drives: 135i, Trailblazer SS, 1934 PU
Performance Pedals DIY
This is a pretty easy mod and all you need is a small torx screwdriver, a 7mm wrench and 3/32, 7/64, and 11/64 drill bits. There are only two hard parts....putting the rubber inserts into the aluminum pedals and drilling the last two holes on the footrest...but still they are no big deal.
1. You peel off the rubber pads on the clutch and brake pedals.
2. The new pedals come with sticker templates, but they are off. So only match up the top two holes on the clutch and brake with the template and drill. The clutch is plastic, so you can easily just use the 11/64th bit and insert the screws and nuts. The brake is ridged metal and will require a pilot hole with the 3/32 bit or something smaller to avoid slipping of the ridge. Once the top two are bolted down and slightly tighted. Push on the bottom and drill in place with the 11/64th and bolt them down. Tighten all in a star pattern with a 7mm wrench and torx screwdriver.
3. The gas pedal is drilled and screwed directly to the plastic. No need for the template here. Just line it up nicely with the left edge of the pedal (it will actually overhang slighty to the right, but it looks better and no one will know), hold it in place and drill a hole with the 7/64th bit. Screw it down, and pivot the pedal if needed for a perfect line up and drill and screw the remaining holes.
4. The footrest is the same as the gas pedal. Line up to an edge of your liking and drill and screw the middle hole first. Sit back and pivot as needed until it looks straight, then drill and screw the remaining. The hardest part of this whole job is getting the last two top holes on the footrest. A drill will not fit, so you will either need a Dremel style flex drill hose or like me have to drill it by hand by just twisting the 7/64th bit around and around for 10 minutes. I was then able to screw the top two down with torx bit and a wrench.
This is a very easy mod and immediately makes a huge first impression the second you open the door. The pedals feel great and worth every penny.
      03-23-2008, 03:52 PM   #2
Templedogg
More pics
      03-23-2008, 04:51 PM   #3
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Nice first additions to the DIY section. Thanks.
      03-23-2008, 04:57 PM   #4
coco_m3
coco_m3's Avatar
Drives: Supercharged E90 M3
2008 BMW M3  [0.00]
2010 BMW E90 335i  [0.00]
that looks really good!
gonna have to do this to mine...
      03-23-2008, 05:15 PM   #5
reo5001
Drives:
Thanks for the instructions! This makes me really want to buy those pedals!
      03-23-2008, 07:35 PM   #6
InsaneSkippy
InsaneSkippy's Avatar
79
Drives: 135i
Great job! Thanks for this article. After seeing your car I'm definitely doing this mod.
      03-23-2008, 09:18 PM   #7
sadu77
sadu77's Avatar
Drives:
where can i order the pedals from?
Titanium Silver
6 speed man
Black Boston Leather
Gray Poplar Trim
Nav system
Comfort access
Power/Heated seats
Sattelite radio
Ipod
Production number 398****
      03-23-2008, 09:26 PM   #8
Templedogg
Just tell your CA you want the 1-Series Performance Parts Aluminum pedals.
      03-23-2008, 09:53 PM   #9
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
You sold me. Did you do the cdv while you were under there by any chance?
      03-23-2008, 10:06 PM   #10
Templedogg
Nope, not yet.
      03-24-2008, 08:02 AM   #11
ChrisK
ChrisK's Avatar
Drives: '19 M2C
For this application...even with lock nuts, I used Loctite on all of the machine screws.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      03-24-2008, 08:04 AM   #12
joelk
joelk's Avatar
Drives: Space Gray E90 M3
thanks for a great write-up and posting those nice photos. I'll be doing this as soon as I can deal with the idea of drilling into my new baby.
e90 M3, Space Gray / Extended Black, ZCP, ZCV, ZP2, DCT
sold: 2008 BS 135i 6MT
      03-24-2008, 08:25 AM   #13
Sherifftruman
Drives:
Nice writeup. The pedals look great. There is no excuse for these not being on the car to begin with.
      03-24-2008, 09:20 AM   #14
Lester
Drives:
Was there a BMW part number on the bag or on your receipt?
      03-24-2008, 09:27 AM   #15
Templedogg
Loctite is great advice Chris, I take the time in a few day to apply some.
Lester the part numbers from my receipt are below.
35-00-0-304-642 Pedals - List $88.40 - Net $71.83 (my price)
51-47-0-027-792 Alum. Footrest - List $78.00 - Net $58.50
      03-24-2008, 11:06 AM   #16
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Better to be safe than sorry.
      03-25-2008, 02:26 AM   #17
Motorsports_3
E30 Addict
Drives: 2008 135, 1988 325
The CDV has to be done under the car.
      03-25-2008, 03:54 AM   #18
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
^^ CDV?
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      03-25-2008, 04:01 AM   #19
Oregon
NRA Life Member, BMW CCA 30 year member
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Originally Posted by Balls View Post
^^ CDV?
Clutch delay valve, delays engagement to facilitate smoother shifts, or, so I'm told.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason
      03-25-2008, 04:11 PM   #20
Motorsports_3
E30 Addict
Actually it makes for rougher shifts. It makes it almost impossible to shift from first to second smoothly. BMW engineered it to add more wear to the clutch than the diff under hard shifts. They do this so there is less, or ideally no damage to the diff. BMW started adding this piece before the offered maint on thier cars, and currently dont offer it in other parts of the world. So it is there to add clutch wear instead of diff wear, because clutches are cheaper, and not covered all over the world.
      03-26-2008, 01:18 AM   #21
Oregon
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Interesting. Additional motivation to perform the CDV mod.
      03-26-2008, 06:58 AM   #22
MastaMind
I like beer
32
Drives: AW 135
Templedogg, although this is a fairly straightforward install, thanks for taking the time to take pics and outline the process.
1addicts
