03-21-2024, 08:29 PM | #1 |
Rep 143
Can 12V outlets be turned off?
Can the 12V outlets be turned off when the engine is not running? I have a 12 V cooler that I plug into a 12 V outlet when we go on trips. I see that it does not turn off when the ignition is off and the car is locked. I know that at some point I will forget to unplug the cooler and have a dead battery when I come back to the car.
thanks |
03-21-2024, 09:03 PM | #2 |
Rep 862
Drives: BMW Z4 M40i, BMW X5x40i
I haven't tested the rear ports, but the port up front shuts off when the car goes to sleep - so about 10-15 minutes after you shut down and leave the car. Are you sure they don't shut off?
To test it, use an accessory that has an indicator or display that remains lit when power is applied. You want to be able to check it from outside the vehicle so as to not wake the car up (which restores power to the port.).
2023 Z4 ///M40i Thundernight Metallic/Cognac Vernasca/Moonlight/Shadowline/19" Black 799M/PP/DAP/ACC/HK
2022 X5 xDrive40i Phytonic Blue/Cognac Vernasca/DAPP/LSP/PP/CCP/PAP/20" Style 738/Spare Tire/Trailer Hitch |
davchr85.00 LuckyBrand1363.50 |
03-22-2024, 07:30 AM | #4 | |
Rep 8,767
Drives: eVeRyOnE mAD!
that said, I keep my dash cam plugged in at all times because I’m OCD when it comes to exiting and can reliably trust my vehicle goes into standby MY21 45e |
LuckyBrand1363.50 doctorwizz28.50 |
