04-10-2024, 03:09 AM | #1 |
Rep 21
2013 F31 lower grille bird strike
My wife's 2013 F31 touring M Sport took a bird strike the other day when a young pheasant decided it wanted to go to work with her. Hopefully you can see from the attached pictures that the grille doesn't appear damaged but has popped off from the clips. I have no idea what's involved in putting this back in place. Any help and advice would be much appreciated.
Thanks. Last edited by Bazza; 04-10-2024 at 04:16 AM.. |
04-12-2024, 08:18 AM | #4 |
8300
Rep 16,188
04-12-2024, 09:29 AM | #6 |
Rep 538
If you want access to the back of that you can get there through the wheel well cover. You may even just go through the access panel even. Depends on how small and flexible your arms are.
04-20-2024, 05:41 AM | #8 |
Rep 21
Update.
There was a lot more damage inside than could be seen from an external view. The fog light mounts had broken and I had to replace it with a new one. The grille went back in no problem. |
Tags |
bird strike, f31 3 series touring m sport, lower grille |
