04-03-2008, 08:54 AM | #1 |
Rep 536
Let's install the BMW Stainless Pedal Kit
I am moving to a new host for my site and do not want to go through all my posts to keep images. As a result, I have converted this post into a PDF you can download.
04-03-2008, 09:26 AM | #3 |
Rep 536
04-04-2008, 04:17 AM | #4 | |
Michelin Man
384
Rep 739
these pedals look fantastic, too! |
04-04-2008, 04:34 AM | #5 |
NRA Life Member, BMW CCA 30 year member
179
Rep 2,614
What he said. The 135i is indeed a hot-rod, quite possibly hotter than a stock E46 M3, however, BMW has not badged the 135i as an 'M'-car, it is offered with 'M' improvements.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason |
04-04-2008, 08:14 AM | #6 |
Rep 536
Here is a pic of the M dead pedal.
Let me know if you would be interested in one. The dead pedal is not too expensive, $61 retail. BMW does ask for an interior code though which may mean it is more than just an overlay. I am not sure if it would work in the 1 either. The M thing is my own personal preference. The one on the shift knob is already gone from my car and I will wait a bit to deal with the one on the steering wheel. It is just not my thing. An M on the dead pedal is much better than slapping an M on the back of the car though. |
04-04-2008, 01:11 PM | #8 |
37
Rep 1,680
Thanks Andy! They look great. I just placed an order.
e90 M3, Space Gray / Extended Black, ZCP, ZCV, ZP2, DCT
sold: 2008 BS 135i 6MT |
04-04-2008, 02:45 PM | #9 |
Rep 536
04-12-2008, 11:58 AM | #10 |
37
Rep 1,680
I installed the pedals this morning (after having them sitting in my house for a few days). The throttle is a piece of cake compared to the other two pedals. The clutch and brake were a PITA. However, if you install them as you suggest here and in the included instructions it goes pretty quickly.
They look great. Pleasure doing business with you. :w00t:
04-21-2008, 05:29 PM | #11 | |
Rep 536
I spent a while figuring out the best method and then it just clicked. |
04-21-2008, 07:30 PM | #12 |
BMW ONE
15
Rep 630
Drives: 93 RX-7 R1, 135i
great DIY's Andy ...thanks
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
04-22-2008, 08:40 AM | #13 |
Rep 3
02-27-2010, 02:50 PM | #14 |
Rep 215
Recently installed stainless pedals, I have an auto, so brake and throttle only. I struggled with the brake for longer that I like to admit, the stainless cover kept coming off and was difficult to reinstall on the rubber pad itself. I than decided to use soapy water (dish soap) and it slipped right on. When it dries it leaves behind no residue.
BTW, I have the M-sport package with the above dead pedal and they match very well. |
09-04-2010, 04:59 PM | #15 |
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
if your car has the m sport the foot rest already has the M on it
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
01-12-2011, 01:57 AM | #16 |
Rep 2
Hi all!
I want to install pedals kit on my 135i Do you know if for the accelerator pedal it's necessary to disconnect the battery? (My 135i is in automatic, only 2 pedals for information...) Thank you |
01-14-2011, 04:45 AM | #17 |
Rep 2
Anyone to help me?
I have see here: http://www.e90post.com/forums/showth...ainless&page=2 They said that the accelerator pedal required coding Do you confirm? |
01-14-2011, 09:34 AM | #18 | |
Rep 536
02-14-2011, 09:05 AM | #20 |
Rep 761
Over here on this side of the pond allot of euro bimmers that have some type of M bits and pieces will have some sort of M badging. Just like the "M" sport (bits and pieces) on the 135i. I've actually seen it in the normal spot it's just usually a sticker not a actual "badge". Good DIY by the way, I may have to look into adding these pedals myself.
03-29-2011, 02:02 PM | #21 |
Rep 423
I know it is an old thread, but I am looking to get these pedals for my 335i. The car is an AT. Can anyone tell me if the kickdown mode would still work with the new pedals?
Thanks a lot for the DIY! |
03-29-2011, 04:07 PM | #22 |
Rep 2,926
I am assuming kick down is the small button after you depress the pedal all the way to go into overdrive? Yes it still works. I have a 3rd party aluminum pedal set and it works just fine. No problems.
