      06-18-2024, 04:32 PM   #1
R34L15T
Drives: 2019 BMW X5 30d M Sport
EML Light On - Bimmerlink Log
So today after a drive and stopping off somewhere - i started the car up again and noticed the EML light on.
Nothing on the iDrive for any messages etc.
Just purchased Bimmerlink and tried to clear messages - but EML is still there. See the bimmerlink log attached.
Any idea how i can completely clear the EML to see if the light comes up again? Not sure what most these codes are!
Any help welcome!
BMW X5 30d M Sport
      06-23-2024, 06:05 PM   #2
R34L15T
This morning while driving had the light turn on again. I reset via Bimmerlink and it's off now - i realised the only error that stayed on that wouldn't clear was the following;
804415: ID Transmitter (IDG): Battery undervoltage.
Would this have anything to do with the EML keep on coming on? Any help welcome. Log from this morning below;
Originally Posted by R34L15T View Post
0B Selective Catalytic Reduction
2 errors
80537E: Engine shutdown time, implausible to DDE engine shutdown time. 80537A: Engine shutdown time, total error for plausibility checks.
12 Digital Diesel Electronics
3 errors
CD9767: Message (RQ_RPM_FTAX, 45.1.2 69.3.4, FX), timeout: Message (request front axle speed) from DSC failed
CD9763: Message (RQ_RPM_BAX, 45.1.2 69.3.4, FX), timeout: Message (request rear axle speed) from DSC failed
2BB100: Particle filter system, plausibility with particle sensor: Particle filter efficiency too low
19 Transfer box
1 error
021924: Flexray, external cause (group error)
37 Receiver audio module
1 error
B7F500: Driver's microphone not calibrated
39 Virtual integration system
1 error
D75611: Signal (status system parking 2, ID: ST_SY_PKG_2) invalid
40 Body Domain Controller
6 errors
804081: Production readiness to drive: faulty
8040C3: KL30F: Request for shutdown due to closed-circuit current violation 8040C6: KL30F: Reset request due to closed-circuit current violation 8040D2: PWF status activation: Parking BN not ok
804123: DAYS Driver's door / side (FT): Continuous operation
804415: ID transmitter (IDG): Battery undervoltage
5D Camera-based driver assist system
2 errors
800AC5: KAFAS window heating: Short circuit to positive or interruption 800ABF: KAFAS camera: field of view temporarily disturbed
61 Telematic Communication Box
1 error
03178A: SIF: General Mobile Network Errors
63 Headunit High
4 errors
031793: SIF: connection WLAN 031791: SIF: connection BT 031798: SIF: BT Audio Browsing 03179A: SIF: CarPlay connection
78 Integrated automatic heating / air conditioning system
1 error
801230: Ionizer: Internal module fault
BMW X5 30d M Sport
      06-25-2024, 02:19 AM   #3
gtx2010
Drives: BMW X5 G05 30d
I think you have Adblue system fault and hence the eml light is on.
Where are you based? You need ISTA scan as bimmerlink shows lots of unnecessary errors which are really not a problem. I have had similar experience
DSC errors only shows in bimmerlink not in ista you can ignore those not really a problem
What is the permanent error in bimmerlink? There is a tab to check permanent error
      06-25-2024, 05:44 AM   #4
R34L15T
This was the one that stayed on after i cleared it all.
However apparently that’s the keys battery?
I did clear all faults and light hasn’t come back on.. yet.
BMW X5 30d M Sport
      07-01-2024, 03:07 PM   #5
R34L15T
Sorry forgot to mention earlier - Based in London.
BMW X5 30d M Sport
      08-30-2024, 01:43 PM   #6
MT530d
Drives: BMW 530d
Hi, did the errors ever came back after you changed your key fobs battery?
I also have error 2BB100, and I have forced regen several times but no luck.
Thank you in advance!
      09-18-2024, 11:25 AM   #7
R34L15T
Yes, error is back for past two days.
Had the EGR recall done and now I have a DPF issue which i'm trying to resolve.
BMW X5 30d M Sport
