      05-18-2008, 10:57 PM   #1
Kris
123
Drives: m3
We can beat the M3 V8...
hehe
      05-18-2008, 11:03 PM   #2
taiheung
Drives: Mini Cooper S
You ever get the feeling these videos are bias? :iono:
      05-18-2008, 11:04 PM   #3
Kris
123
Drives: m3
Do I? not really. It's the japanese testing them...The I6TT puts out alot more than the 225kw they state officially.
Check this out:
http://www.1addicts.com/forums/showthread.php?t=9250
Just just did a 13.8 stock on 91 octane... Imagine what a good driver on 100ron octane can do here...
      05-18-2008, 11:06 PM   #4
DTNJNQ
DTNJNQ's Avatar
Australia
110
Drives: M2, 135i, Xclass
2008 BMW 135i  [8.66]
Why? BMW had the fastest time not the japanese cars.
      05-19-2008, 01:45 AM   #5
Carlos
Drives:
Mate, when I get my car, I'll go straight and put the highest fuel I can find 101 ron, right
      05-19-2008, 01:49 AM   #6
Kris
123
Drives: m3
Dunno, V Racing is 100 isn't it?
      05-19-2008, 01:54 AM   #7
aus_buster
Drives:
didn't know we could use ethanol based fuels...?
135i M, LeMans Blue, Step, Pro Hifi, Business Nav
      05-19-2008, 02:10 AM   #8
Carlos
Drives:
Shell, right, is the only one that sell something more than 98ron? I reckon BP and Mobil just sell the standard 98ron
      05-19-2008, 02:14 AM   #9
aus_buster
Drives:
yup, Shell V-power racing is 100RON. BP ultimate and Mobil are 98 RON.
      05-19-2008, 02:20 AM   #10
Carlos
Drives:
So, one question, how much better will the car perform (perhaps on the track) if you use 100 instad on 98?
Another question: If you put one fuel, do you have to wait for tank to almost empty before you put the different one or not (98 to 100 or 100 to 98)?
      05-19-2008, 02:20 AM   #11
Kris
123
Drives: m3
Ill be using BP Ultimate in my car, found all my previous cars run better on it. It's also cleaner with less benzine and sulpher from memory...
Best way to tell the diff in fuels is to dyno the cars. Same dyno, same temp, same operator and see how it goes....
I also think a tune will take better advantage of the higher Ron rating fuels..
      05-19-2008, 03:25 AM   #12
harpoon
Drives: e92 M3
Yeh many cars aren't compatible with the V racing (ethanol based). I used it in my 350z when it first came out and noticed quite a big difference in throttle response. But then I rang Nissan Australia and they said it would damage the engine if used on a long term basis.
I use BP ulitmate now. Found it to be the best for perfomance and economy.
      05-19-2008, 04:33 AM   #13
DTNJNQ
DTNJNQ's Avatar
Australia
110
Check this out
http://www.racefuels.com.au/dynoDetail.asp?ID=59
      05-19-2008, 05:11 AM   #14
Swift135
Australia
23
Drives: 330d, M3 DCT E92
Originally Posted by DTNJNQ View Post
Too much too read this time of night, what's the short take on it?
      05-19-2008, 05:46 AM   #15
Alext
138
Drives: B M W
On the stock ECU I doubt 100 octane will do any better than 98 octane as 95(?) octane is what the ECU is programmed to use optimally. Perhaps on a very hot day 100 octane will be superior as the ECU will then retard the timing less.
      05-19-2008, 07:55 AM   #16
Carlos
Drives:
OK, thanks Alext, but the 135 you have to put at least 98 right? or can you put 95?
      05-19-2008, 08:39 AM   #17
Alext
138
Drives: B M W
You can actually put in 91 octane if you want quite safely as long as you are not boosting it heavily on a hot day and dont mind loosing a little power as the ECU will adapt. Normal premium (95 octane) will be fine.
When I was tuning an '01 MX5 turbo several years ago I found that on anything less than 98 octane @ 12psi boost the engine would detonate audibly. And so I had to retard timing a few degrees, especially around the torque peak. @ 8 psi 95 octane could be used when ambient temps were cold. Sometimes I would encounter a bad batch of 98 octane fuel (usually from BP) and would have to switch timing maps immediately because of bad (v.audible) detonation from the engine.
BTW the difference in feel of power between 12 & 8psi was massive.
      05-19-2008, 09:40 AM   #18
d3syd
d3syd's Avatar
Australia
50
Drives: 135i MT, LMB, ProNav
2008 135i Coupe  [0.00]
Interesting video. I think the M3 lost because the driver bogged the car down a bit at the start. You can see the revs drop down a lot on the footage in the M3. The M3 was catching up at the end.
I'm guessing with the 135's low down torque, it would be easier to have good launches than the M3.:iono: Just guessing.
At the end of the day, at the price the 135 is, it's one hell of a car to be able to do what it did.:headbang:
Fun Car: 135i Manual LeMans Blue / Beige Leather / Grey Poplar / pro nav / euro plates. Delivered 24 June 08
Family Car: Land Rover Discovery 4 SDV6
Spare Car:
Volvo V70 Sydney Car: MB 420SEL
      05-19-2008, 04:32 PM   #19
professor
Drives: Z4 M40i
the 135 beat the m3 right, so where's the bias?! :smile:
      05-19-2008, 05:07 PM   #20
Kris
123
Drives: m3
d3syd: it does appear like that. I have no doubt in my mind the V8 is quicker over the quarter. Up to 100 though I think the 135i might be pretty neck and neck with the V8
1addicts
