      08-26-2024, 03:01 AM   #1
iCARMIX
iCARMIX's Avatar
Hong Kong
534
Drives: BMW
X5 M Performance brakes upgrade
BIMMERPOST
     Featured on BIMMERPOST.com
The upgrade features front 4-piston and rear single-piston red calipers, paired with 395mm front and 398mm rear semi-floating brake discs.
Beyond the performance benefits, the M Performance braking system has been designed and manufactured by BMW specifically for their vehicles.
This means the components are a direct fit, ensuring seamless integration and compliance with local vehicle inspection standards.
Remember to drop by my iCARMIX website for more info:
https://icarmix.com/?s=g05&post_type=product
Appreciate 14
      09-10-2024, 06:39 AM   #2
wxllxr
Founder, Co owner BMW
wxllxr's Avatar
United Kingdom
37
Drives: X3 M40d 2020
2020 X3 M40d  [10.00]
2020 X3 M40d  [0.00]
Will these warp after one drive like Mine did
      09-10-2024, 06:40 AM   #3
NathObeaN
NathObeaN's Avatar
United Kingdom
1636
Drives: M2 Competition (MY2021)
Not to be cynical, but does anyone actually care about brake upgrades on an SUV (beyond pub bragging rights?). It’s not as if anyone takes these to the track or exceeds the factory braking capabilities?
Appreciate 10
Blue87416.50
Dom147141.50
Scrapula5239.50
davchr215.50
Kingpin4388.00
Autobacs1468.50
AllaVodka661.00
Logical279.50
F32Fleet3998.00
      09-10-2024, 06:43 AM   #4
DocWeatherington
DocWeatherington's Avatar
Drives: F90 CP
2024 XM  [10.00]
Hmm... you can kill a set of brand new consumer brakes in 20mins.
Did you properly install them
      09-10-2024, 06:44 AM   #5
wxllxr
wxllxr's Avatar
United Kingdom
37
2020 X3 M40d  [0.00]
It was my main dealer, so I’d like to think yes.
      09-10-2024, 06:44 AM   #6
JK479
JK479's Avatar
1352
Drives: I6-> iX
Sure when you are braking in some terrible traffic and can avoid an accident.
I also want an x5 M for that reason alone.
Appreciate 6
      09-10-2024, 06:46 AM   #7
David Kunitz
Mr OEM
David Kunitz's Avatar
929
Drives: BMW 335i Sport Line
The size of those front calipers is seriously impressive!
Appreciate 3
      09-10-2024, 06:49 AM   #8
NathObeaN
NathObeaN's Avatar
United Kingdom
1636
But these will not stop the vehicle in any shorter distance? By law (internationally applicable), factory-fitted brake systems must be capable of triggering ABS (locking the wheels). In other words, these won’t provide any benefit. Not unless ‘traffic’ = ‘repeated 0-60 runs, followed by hard braking’, in which case heat soak becomes a factor .
Appreciate 5
      09-10-2024, 06:50 AM   #9
DocWeatherington
Drives: F90 CP
2024 XM  [10.00]
Either you had a defective set, bad install or user issues as warp rotors tend to be from excessive heat put into them.
      09-10-2024, 06:55 AM   #10
wxllxr
wxllxr's Avatar
United Kingdom
37
2020 X3 M40d  [0.00]
What defines excessive heat?
      09-10-2024, 06:56 AM   #11
beattiecj
beattiecj's Avatar
153
Drives: 2012 135i 2017 x5 35i 1988 e30
Aside from bragging rights it’ll come down to the tire or if you’re repeatedly doing 100mph to 20mph stops and even then the pad type is more crucial for performance.
That said I think we all need to upgrade to the 6-pistons or carbon ceramics because looking cool while stopping is cool.
Thanks for sharing the details, I will say the msport brakes have been a massive improvement from feel and perceived stopping power than the F15 brakes.
      09-10-2024, 07:00 AM   #12
ledphut
ledphut's Avatar
Drives: Alpina XB7
2022 Alpina XB7  [8.30]
Will they coat my freshly cleaned wheels in dust after a 30 minute drive like current MSport brakes?
Appreciate 5
      09-10-2024, 07:12 AM   #13
MiamiFan13
Drives: i4-e40 335i 03 Cobra,Jeep SRT8
On a heavy vehicle like an SUV....it makes a HUGE difference IMO. Better brakes are always better anyway.
Appreciate 8
aps343.00
Edwardsc1312.50
Mr.blue255.00
LENBMW2.00
Vervain493.50
2srsman97.50
      09-10-2024, 07:16 AM   #14
BlkGS
BlkGS's Avatar
4335
Drives: BMW X5 M50i
People who tow, people who drive in the mountains, people who like the aesthetics, people who prefer to have things over built... Lots of good reasons to do it b
Appreciate 9
Edwardsc1312.50
Mr.blue255.00
LENBMW2.00
Vervain493.50
beattiecj153.00
2srsman97.50
swainbmw698.00
ekaz93.50
      09-10-2024, 07:47 AM   #15
forcefed
forcefed's Avatar
3870
Drives: .
Those front pads are tiny...
      09-10-2024, 08:06 AM   #16
DocWeatherington
Drives: F90 CP
2024 XM  [10.00]
Depends on the rotor material, I will also add going from hot to cold..aka hot rotors into a puddle of water or car wash can also be a cause of warping.
Smoking, glowing red, tons of heavy duty stops back to back with no cool down period and or shock from major temp changes in super short periods of time.
LENBMW2.00
      09-10-2024, 08:14 AM   #17
BlkGS
BlkGS's Avatar
4335
Drives: BMW X5 M50i
They're taller than "normal" pads, so they likely have similar surface area, just in a different form factor.
My C6 Corvette uses "padlets" that are like literally 1.5"x1.5", and it just uses a bunch of them. The idea was they could be replaced individually or something. I still prefer the one piece designs.
      09-10-2024, 08:14 AM   #18
mose121
Humanist
mose121's Avatar
Drives: F80 M3 ZCP/F31 330i M Sport
The size of those rear calipers is pathetic. BMW should be ashamed to call those an upgrade. Should have done stock with at least 6 piston fronts and 4 piston rears. They came up short on this one right out of the gate. Still an amazing vehicle.
'19 F31 M Sport Estoril Blue : '16 F80 M3 ZCP Mineral Grey : '15 E84 X1 M Sport Le Mans Blue : '13 E92 M3 ZCP Alpine White
'10 E82 135i M Sport Le Mans Blue : '99 E46 328i Sport Fern Green : '95 E36 M3 Cosmos Schwartz : '95 E36/5 318ti Clubsport Jet Black
forcefed3870.00
co_440i229.00
      09-10-2024, 08:16 AM   #19
BlkGS
BlkGS's Avatar
4335
Drives: BMW X5 M50i
Rear calipers don't really need to be big to do their limited job. I love a big giant caliper as much as anyone, but they're just extra unsprung weight in the back.
LENBMW2.00
Autobacs1468.50
      09-10-2024, 08:22 AM   #20
rabith007_b58
Software Engineer VII | Lockheed•M
rabith007_b58's Avatar
Drives: F30 340i
Ceramic life
      09-10-2024, 08:51 AM   #21
Alan l.
Alan l.'s Avatar
6033
Drives: 2020 F95 X5M Competition
Having more brakes is never a bad thing but why the hell are the front pads half the size of my X5M pads? seems strange to have a massive caliper and rotor to then use a tiny pad.
forcefed3870.00
The_Werm215.00
      09-10-2024, 09:36 AM   #22
MPower10s
MPower10s's Avatar
Drives: X7 M50i
I think it’s important for family safety. Stopping distance on highway in emergency. I want the best brakes I can get.
Tags
4 pot brake, bmw x5, hong kong, icarmix, m performance brake, x5 g05
