blow off valves BOV for the e92?
06-01-2006, 01:43 AM | #1 |
Rep 804
what do u guys think about putting blow off valves on the e92
i like the sound. Last edited by sillygoat; 06-01-2006 at 02:01 AM.. |
06-01-2006, 01:46 AM | #2 |
Rep 108
you mean... a blowoff valve?
It sounds cool... I guess - I've had a turboed car before, and I always see Audi's with BOV's, but BMW's? I suppose we'll need to get used to it. |
06-01-2006, 02:01 AM | #3 | |
Rep 804
06-01-2006, 07:56 AM | #5 |
Rep 6,664
Blow-off valves do not just exist for the sound effects. They have a real purpose, and the sound effect is a result. The purpose of a blow-off valve is to relieve excess turbo pressure that results from reducing the throttle rapidly under boost conditions. If this excess high pressure is not released, it will try to release itselft, back through the turbo (causing the turbo to stop). Then when the throttle is applied again, the turbo needs to re-spool. Having the blow-off valve can save the life of your turbo, and its response..
(Had an A4 1.8Turbo before this car)
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER. |
06-01-2006, 02:03 PM | #7 |
Rep 840
Modern turbo cars these days do not expel the excess pressure into the atmosphere. Rather it is recirculated back into the system so as to maintain proper pressure so when you get back on the throttle it minimizes the “lag” that’s inherent w/ turbo cars. There are some companies that now manufacture “hybrid” BOV where it will recirc as well as sneeze the air out so the people that want the sound can have it without compromising the performance of the car.
Just bare in mind that if you install a non-hybrid BOV you will eventually throw a code as most Audi owners were experiencing initially when they just went ahead and installed a normal BOV into their cars. I cant recall but I think it eventually made the car run rich which triggered the CEL. Our cars these days are very very sensitive to changes in emission gasses and will trip off CEL if it detects anything weird. So just be forewarned. Personally, I think the noise from the BOV gets a bit old after awhile. |
06-15-2006, 12:41 PM | #9 | |
there is no spoon
243
Rep 867
Regardless of recirc or vent-to-atmosphere, you will hear the bov sound, it's just a matter of how loud it is. The type of bov will also determine the type of sound you get. Some gets a clean swoooshh sound, others gets a nice valve flopping sound. Personally, I love the sound of the bov, I miss it. I had a greddy Type-S bov on my last car venting to atmosphere, and I can't get enought of it.
The thing about venting to atmosphere is that the car's map/mas sensor that reads volume of incoming air will be "confused". The sensor reads a certain amount of air traveling through the intake and sends the signal to the ECU to allow it to calculate the amount of fuel to mix in. When the bov releases that air into the atmosphere all of sudden, you'll run very rich as the ecu is injecting the amount of fuel that was suppose to mix with the air you just vented. This means you'll probably stall your engine. The way I went around it was replacing the OE ECU with an aftermarket standalone racing ecu that doesn't utilize the same type of air volume sensor. I switched to GM 2 BAR MAP sensor and GM Air Intake Temp sensor. This allowed the VTA mode. Quote:
[SIGPIC][/SIGPIC]
06-15-2006, 07:44 PM | #11 | |
Bruin
293
Rep 539
-Mike-
06-16-2006, 12:59 AM | #12 | |
there is no spoon
243
Rep 867
AEM EMS standalone ecu and the beautiful sounding greddy type s bov.
[SIGPIC][/SIGPIC]
06-16-2006, 01:24 AM | #14 |
Bruin
293
Rep 539
*shrug* Maybe you guys just have better ears than me. I can't hear it at all on my Forester XT, and I drive it almost everyday. The Legacy, on the other hand, has a K&N Typhoon and an AVO BOV (50% recirc/50% vent) so I hear everything.
D, where is the bpv on the A4 motor? I'm wondering if location differences might account for me not hearing the S4's. -Mike-
06-16-2006, 11:50 AM | #15 |
there is no spoon
243
Rep 867
Its a combination of the turbo spooling sound and the "closure" the sound of the bov gives you that makes it so satisfying and addicting. "tsssssssssssssssssssshhhhhh~~~ PSSSSSST!"
[SIGPIC][/SIGPIC]
11-08-2006, 05:20 PM | #16 | |
Rep 13
11-09-2006, 05:28 PM | #18 |
Rep 13
I've seen a few $300K+ Ferrari's not re-routed into the system, thats enough for me to give it the ok as a mod thats "good enough" for the entry level BMW chassis.
Click Here for a lil youtube video of the turbo F40
11-09-2006, 06:16 PM | #19 |
Rep 963
That's an F50. It doesn't come stock with turbos, meaning they were added later on. The F40 did come with turbos, but doesn't have a BOV. In my mind, BOVs are more for HP beasts.
11-09-2006, 06:31 PM | #20 | |
Rep 13
You're correct!
