      09-22-2024, 07:38 AM   #1
Murf the Surf
Murf the Surf's Avatar
22139
Drives: Porsche 993
Porsche applies for patent of 6 stroke engine
Interesting: I cam across this on line.
Porsche has filed a patent for a strange (and possibly brilliant) idea of a six-stroke combustion engine.
Right now, most ICE are 4 stoke: intake, compression, power, and exhaust.
Porsche reckon they can add another compression and power stroke to this process. The patent describe this as "six individual strokes that can be divided into two three-stroke sequences." The added steps would occur between the traditional power and exhaust stroke. The first sequence, then, would be intake-compression-power, followed by compression-power-exhaust.
Porsche's patent shows a crankshaft spinning on a ring with two concentric circles—an annulus. This alternates the center point of rotation, effectively lowering the piston's travel (bottom dead center) slightly for the added strokes. That in turn changes the compression, since the piston isn't traveling as far up (top-dead-center) in the cylinder. And that also means this engine has two top and bottom dead centers.
This design has the potential to generate more power with better efficiency. In a typical ICE, only one stroke in four actually makes power. This changes the formula to one stroke in three, and it also burns up the mixture more thoroughly. The downside is added complexity. Whether the gains are enough to justify the design remains to be seen.
As with many patents, it's possible this could never see the light of day. It's certainly an interesting idea and I guess shows Porsche is trying really hard to keep the internal combustion engine alive.
Appreciate 5
David701754.00
NYG12565.00
gblansten2587.50
ShocknAwe3686.00
PhaceN52179.00
      09-22-2024, 09:00 AM   #2
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
I would think the additional friction of the annulus ring would offset any efficiency gains? Thoughts?
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
M5Rick71689.00
      09-22-2024, 10:07 AM   #3
Murf the Surf
22139
Drives: Porsche 993
I'm not an engineer and generally live by a few simple rules and mostly common sense. I would think that adding this much complexity might defeat any advantage. Having said that I suspect the engineers at Porsche have done some maths on this thus the patent application.
Efthreeoh19714.50
M5Rick71689.00
      09-22-2024, 11:13 AM   #4
DrVenture
DrVenture's Avatar
1454
Drives: M550i 2022
2022 BMW  [0.00]
You said "annulus", heh, heh!
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Premium Pkg|Luxury Seating|M668 w/ DSW06+
      09-22-2024, 07:02 PM   #5
RM7
RM7's Avatar
3057
Drives: Camaro SS 1LE
It's also not uncommon for companies in certain segments to patent every and anything under the sun they can. It's not so much about future production plans, but more about winning the "patent war". Often times they will patent stuff they are not serious at all about. But every once and a while one of those ideas will be fruitful in the future with further development.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
David701754.00
      09-25-2024, 10:58 AM   #6
Chihuahua
Chihuahua's Avatar
4582
Drives: E30 329iS, E65 Alpina B7
That was cool. uh huh huh huh huh.
DrVenture1453.50
      09-27-2024, 03:47 PM   #7
Dégoûté
547
Drives: Cars
So would revs get really high or really low?
      09-29-2024, 09:23 AM   #8
Efthreeoh
I would think lower revs. Interesting question though, how the design would affect the harmonics of the flat-6 architecture.
      10-06-2024, 12:00 PM   #9
Murf the Surf
22139
Drives: Porsche 993
Porsche witchcraft.
      10-06-2024, 02:04 PM   #10
Efthreeoh
Not the lightest connecting rod made... and that annulus is on the wrist pin side. Hummm...
      10-15-2024, 05:41 AM   #11
Murf the Surf
22139
Drives: Porsche 993
Illustration/animation
https://www.facebook.com/reel/1103697478215401
      10-15-2024, 07:12 AM   #12
freakystyly
Drives: F22 B58 6MT
It has 2 min and 2 max positions on the stroke... Looks like those are exhaust ports at the bottom of the stroke at UT' UT"? Pretty interesting stuff.
      10-15-2024, 10:49 AM   #13
BlkGS
BlkGS's Avatar
3700
Drives: BMW X5 M50i
Let's think this through.
After the first "power" stroke, instead of.opening the exhaust valve, they're pushing down to the lower limit, which exposes another set of intakes (possiblly not valved) which is somehow going to force its way into the combustion chamber, and then be reignited. So really, what they're doing is skipping an exhaust stroke.
That lower air intake is gonna get NASTY carbon build up. It's never going to experience anything other than dirty air, intake air, and likely oil. Unless they put an additional injector in for cleaning those passageways.
