12-02-2024, 07:36 AM | #1 |
Rep 1
Electronics won't turn off
The electronics won't shut off when I open the door. The engine is turned off. I have checked the box in the "doors" that specifies to do this but it's not working.
12-02-2024, 08:14 AM | #2 | |
5527
Rep 10,055
Drives: eVeRyOnE mAD!
you need to press the Stop button before you open the door (even if the engine has already been turned off by ASS). this takes the vehicle out of the drive-ready state Last edited by nZtiZia; 12-02-2024 at 08:15 AM.. |
12-02-2024, 08:22 AM | #3 |
Rep 615
Drives: ‘25 X5 40i
If by "electronics" you mean the radio, check this thread - https://g05.bimmerpost.com/forums/sh....php?t=2148252
'25 X5 M40i Carbon Black Metallic / Silverstone
12-02-2024, 06:17 PM | #4 |
Rep 7,763
The key to this is to use the start/stop button prior to opening the door while have the off upon exit option checked. If you try that and it doesn't work, then something weird is going on. You can also shut things off if you lock the vehicle.
