      07-09-2008, 03:18 AM   #1
WAY
Australia
458
Drives: Fast ones
Has anyone installed the BMW Performance Part gear knob?
I have the knob but no instruction. Is it just a case of pulling off the M gear knob and putting these on, or are there clips and things. I am too afraid to pull it!
      07-09-2008, 11:21 AM   #2
driftdriven
Drives: BMW 135i
It's easy. Look in the DIY section on changing knobs as the performance one is the same.
      07-09-2008, 11:53 AM   #3
PA135i
PA135i's Avatar
Drives: 08 135i 08 CR-V
Most of them just pull off. Pull straight up, but move your face away or you'll punch youself in the chin.
      07-10-2008, 04:28 AM   #4
CDR_UK
Drives: AW 1M
I installed the BMW SSK, and when removing the M knob, I found it was attached to the shift boot with some small metals tabs/clips. I unclipped the boot, then just pulled up on the knob - it came straight off along with the boot still attached to it. Then to re-install, I just installed the alcantara boot, and pushed on the performance knob - bobs your uncle.
      07-11-2008, 12:50 AM   #5
Bullitt
Bullitt's Avatar
91
Drives: 135i
2008 135i  [0.00]
Some say it's easier to put the knob into second gear and then pull straight up. Mine took a lot of force to remove. I almost hit the roof when it finally came off.
      07-17-2008, 12:07 AM   #6
Qube
Drives: E39 540 :: 09 STi
Does the standard silver/black toned knob just pull off as is?
      07-17-2008, 09:16 AM   #7
Qube
The stock boot doesn't work with the weighted knob :| Unless you are supposed to break the retaining ring which allows it to mate with the original knob... !
      07-17-2008, 09:34 PM   #8
Qube
There. I made my own DIY
      07-20-2008, 09:51 PM   #9
HPADDICT
Drives:
I accidently pulled mine off shifting into second the other day. Guess I should lay off the weights.
1addicts
