Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Charcoal filter removal
      06-04-2006, 06:10 PM   #1
adr
Handy Armani
adr's Avatar
Drives: Honds Element
2006 325i  [0.00]
I have been reading the discussion in this thread (http://e90post.com/forums/showthread...=carbon+filter) for a while. Since no one post DIY yet, I decided to do it myself.
Here you go.
      06-04-2006, 06:11 PM   #2
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 1
First, open the door.
      06-04-2006, 06:11 PM   #3
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 2
Open the hood
      06-04-2006, 06:12 PM   #4
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 3
And pull the yellow handle to open the hood
      06-04-2006, 06:13 PM   #5
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 4
release the clip on both side of the intake chamber as indicated
      06-04-2006, 06:14 PM   #6
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 5
Use a small flat head screw driver to release intake sensor from the intake box
and loosen the clamp screw on the flexible tubing
      06-04-2006, 06:14 PM   #7
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 6
Loosen the bolts with 10mm socket
      06-04-2006, 06:16 PM   #8
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 7
pull out the air box and loosen all 5 screws with a T-25 Torx screwdriver.
      06-04-2006, 06:17 PM   #9
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 8
Open the air box.
Cut the carbon filter.
The result is like this.
      06-04-2006, 06:17 PM   #10
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 9
Use sandpaper to smooth the surface on the cut area
      06-04-2006, 06:18 PM   #11
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 10
Take a break. Repeat as many times as needed
      06-04-2006, 06:19 PM   #12
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 11
Carefully clean the air box. You don’t want any particle sucked into the engine. And assemble the air box.
      06-04-2006, 06:20 PM   #13
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Step 12
Reverse the step 1-6 and you are done.
      06-04-2006, 06:26 PM   #14
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
Post removal:
I found the engine runs smoother and revs faster. The hesitation between 1500 to 3000rpm is greatly reduced to none. The engine sounds a bit more clear and (just a bit) louder under heavy acceleration.
      06-04-2006, 06:51 PM   #15
EOE90
EOE90's Avatar
Drives: F15
2006 3  [0.00]
is that k&n air filter?
if so should i go pick one up before doing this
E90 M3 -> F15 X5 M-Sport
      06-04-2006, 07:02 PM   #16
adr
Handy Armani
adr's Avatar
2006 325i  [0.00]
It's up tp you. You can stay with stock filter. I use K&N because it is easier to clean and save money in the long run.
      06-06-2006, 06:48 PM   #17
EOE90
EOE90's Avatar
Drives: F15
2006 3  [0.00]
hey does this void the warrenty or anything?
      06-06-2006, 09:40 PM   #18
windnsea00
Drives: M2 CS
If you happen to have an issue that relates to the air flow I could see BMW stating that the air filter setup had been modified in a way not approved by them. Not sure but it's a possibility. I think euro BMW's may not use these filters (at least the E60 M5).
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides.
      06-06-2006, 10:28 PM   #19
RGRAY
Drives: 330xi SG/TERRA/STEP/SP/HS/CA
2006 BMW 330xi  [0.00]
Here you go.
Thank you very very much.
330xi/Sparkling Graphite/Terra/Walnut Burl/Steptronic/Sports Package/Heated Seats/Comfort Access...(blacklines, tint and a black grill).
http://www.e90post.com/forums/e90gar...20TINT%20A.jpg
      06-06-2006, 10:40 PM   #20
Asiann
Got Seoul?
Drives: 2012 535i MSport
2012 BMW 535i  [0.00]
2008 750Li  [0.00]
2006 BMW  [0.00]
You have to clean it based on where you live. If you live in a dusty area you will have to clean it more. Maybe inspect every 7-10k. The oil solution used to trap particles can and will get dirty so clean or inspect every now and then. Your filter should look pink and if it is no longer pink, then you need to go and get a recharge kit from any auto store and clean it. Just make sure not to over spray the final solution or you can damage the MAP sensor. People have this problem all the time so be careful.
Can you say Alooooha?
[SIGPIC][/SIGPIC]
      10-05-2006, 08:31 AM   #21
JIMD1709
JIMD1709's Avatar
31
Drives: 2007 328 Coupe Alpine White
After doing this DIY, I have added an observation. Once you cut the filter out there is a very rough syrface, and it's COVERED in black charcaol dust.
I removed the MAF sensor from the airbox.( Just two #20 tork screws) BE CAREFUL with this part, it's fragile!! Then I used a dremel to smooth all the rough edges. Sandpaper will work too, but a dremel is faster.
Whether using sandaper or dremel it will create a TON of dust. I then washed the entire airbox, and let it dry completely. (this is why I removed the MAF sensor)
It's an easy mod, and the combination of adding a K&N filter, plus this mod, added a very noticeable improvement in throttle response, trust me. As for HP, probably not much, but it's still worth doing since down the road having that stupid charcoal filter in there will definitely cause airflow restriction since it's not replaceable!! It's almost like having two air filters, a poor design IMO. But, I guess a few states (CA for example) were concerned with vapors escaping into their precious atmosphere when the vehicle is turned off!? We have greater air concerns, believe me! OK, off my soap-box.
      10-06-2006, 12:12 AM   #22
tiga901
tiga901's Avatar
Drives: e90 330i, mt pp sp
Thanks for DIY....very detailed and straight forward!!!
CDV mod, OEM BMW Strut Bar, OEM Aluminum Pedals, OEM Short Shift Knob, OEM Alarm, Rear Fog Lights, Rear Power Outlets
Next mod...Intake(Dinan or Gruppe M), Rogue SSK
