      01-17-2025, 01:22 AM   #1
afrancis269
Drives: 2025 BMW X5 M
S68 X5Mc Tune Capabilities
Thoughts and opinions on JB4 Dyno Tune and RK Catless Downpipes and Eventuri Intake install for my 2025 X5Mc with less than 10,000 Miles. Already have catback Fi Exhaust
Are there any whp output numbers with these bolt ons tuned?
Any concerns with piggy back tunes for S68?
Should i be worried about voiding my warranty this early with this s68 engine?
Any 0-60 times for these added mods?
Should i even do it?
Very on edge and wanted some BMW veteran opinions to pursued me.
I'm new to BMW, always had Audi's but their quality has dropped significantly.
Thank you
      01-17-2025, 01:37 PM   #2
GT500R
Drives: BMW X5M
Thank you
An actual tune is your best and safest bet as long as you have a sound tuner. If you don't want to send out both ECU's to get unlocked and then have someone tune it then I would suggest JB4 as that piggyback has the best capabilities to meet your power goals vs. Dinan or Racechip.
The whole void warranty thing is tricky as if it IS indeed a factory defect, BMW will cover the replacement (I had a tune on my previous car with E50, etc. and need the entire head to be replaced... BMW found a defect in the head and replaced everything)
0-60 with a good JB4 / Downpipes, Etc. should be ~3.0
I like the Audi/VW group tuning options better because you have a lot of good companies to choose from (APR, IE, etc.) that don't require to send an ECU and is tried and true tuning hours into the platform.
25’ X5M Brooklyn Grey
Former - X3M Alpine White
10.84@127.43 / +1912 DA NH Dragway
      01-17-2025, 10:01 PM   #3
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
857
Drives: 2020 X5 M Competition
Thank you
JB4 is great but BMW can detect piggybacks if there's an engine failure. There dozens of ECU's logging everything from boost pressure to rate of acceleration. BMW knows how fast these should go and when something exceeds reasonable parameters for a stock vehicle. 3.0 sec 0-60 is very doable with JB4. Yes, you should be worried about warranty. There are folks in the 3 series forum that have failed turbos on and some dealers have denied warranty because of aftermarket catback saying it change back pressure. The dealer and BMW can do whatever they want if you mod it. Folks can quote Magnuson-Moss Warranty Act until they are blue in the face but unless you have the funds to go up against BMW in a lawsuit they'll likely drag out for years, just accept the fact you're warranty is at risk with any mods.
      01-17-2025, 10:16 PM   #4
Tejas1836
Tejas1836's Avatar
1210
Drives: 2023 X5MC Workmaster 75
My advice, fwiw, max out using the stock performance using whatever parameters you choose- 1/4 mile, 0-60, Gs pulled... then decide if you want anything additional- HP, torque, braking Gs, acceleration Gs, cornering Gs
Two is One and One is None
      01-21-2025, 01:52 AM   #5
afrancis269
Thanks for the info fellas, really helpful in deciding whether I JB4 tune and add downpipes to my 2025 X5m cs with 3000miles.
Been really trying to gauge whether or not to do it due to any unforeseen issues that might surface.
But with the information i've received from numerous forum post, the s68 engine is very robust and won't have issues that i should be concerned with. I'ma just chalk up the money and get those RK Catless race downpipes, and enenturi black carbon intake system in + JB4 dyno tune.
      01-21-2025, 07:49 PM   #6
JustAnothaM4
JustAnothaM4's Avatar
Drives: 2016 M4 GTS
2016 BMW M4 GTS  [0.00]
Femto unlock those ECUs!
2021 X5M Comp Marina Bay Blue
2016 M4 GTS Alpine White
2005 M3 Comp Interlagos Blue
Instagram: https://www.instagram.com/justanotham4/
      01-23-2025, 12:55 AM   #7
afrancis269
what do you mean FEMTO unlocks these?
      01-23-2025, 01:11 AM   #8
X5MnM3comp
Drives: 2025 M3 competition xdrive
The dmes are locked on these newer generations of BMWs. The only company who’s able to unlock them as of today is in Finland and fetmo is the name of the company. Many of bmw owners especially the m3 owners have gone through the process to remove the dmes (x5m has 2) and send them to femto for them to unlock and send back to owner. My understanding the fee they charge is somewhere around 1500 per dme. So for this car would be 3k plus the risk of losing dmes during transit or any other possibilities to go wrong. Turn around time for US is around 10 days or so. Only with them unlocked you are able to install flash tunes. I personally would not go through the process because of the risk factor though a proper tune is enticing. Instead, I live with plug in piggyback tune. It has it’s limitations but it’s enough for me
