      08-18-2008, 07:49 PM   #1
TT1351
TT1351's Avatar
508
Drives: 135, GTS, E30 M3+
Noticed this during my UUC Shortshift install
This was my 5th UUC Shortshift install, 1 on an E30 M3, 2 on E36 M3's and one on an E46 M3 and now my 135i. It appears with each newer model the installation gets more challanging due to tighter spaces to work in and BMW design changes. The instructions supplied with the kit are for the 335i and are straight forward as the always have been.
Everything is going great, until I got to this point, I removed the two clips, (one on either side of the transmission) to remove the aluminum carrier, went to slide the carrier forward per instructions and noticed it did not travel enough to clear the rear part of the carrier from the rubber bush.
It turns out BMW in their infinite wisdom has added a leg which extends downward on the right side of the carrier which based on my experience prevents you from removing the carrier with the transmission in place, I did lower the transmission by removing the 4 bolts holding the transmission in place on the transmission support as per instructions, which does provide a little bit of extra room, all bolts can be removed without catastrophic results.
So without the carrier removed I had to figure how to secure the adapter held in place by the six tiny screws, three on each side. I was finally able to install them by turning the carrier slightly and moving it to the opposing side to install these screws, important to not do not tighten the screws untill all six are started. This method cannot be done unless you remove the two previously mentioned clips. Once this is done the rest of the installation goes as outlined in the directions.
Just thought I'd share.
Fran
      08-19-2008, 12:34 PM   #2
wu2x
wu2x's Avatar
35
Drives: 2011 E90 M3 6MT
Thanks! I'm looking to install the UUC short shifter soon and this definitely helps me prepare for what's ahead.
      08-20-2008, 12:22 PM   #3
Justin(OKC)
Justin(OKC)'s Avatar
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
I installed the carrier with the 6 supplied screws from within the car. I modified the allen wrench to shorten it so that it could fit in there. It did take some time and patience, but it was much quicker and less labor intensive to install it that way. I guess I should add that I'm an orthodontist and am very used to working with much smaller pieces of precision fit hardware. I would install it this way again in a heartbeat. I do still have a problem with my shifter twisting that UUC is still working on a fix for. I have had two different levers in the car and both of them twist, but I am very confident that UUC will resolve the issue as they are an AWESOME company!!
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      09-07-2008, 07:21 PM   #4
FreeBMW.net
Drives: 2008 BMW 135i
During my UUC install I removed the two bolts that held the rear carrier in and then removed the whole thing. just dont drop the two bolts or you are going to be removing a LOT of heat shields and the exhaust.
1addicts
