      08-18-2008, 10:35 PM   #1
looking
Drives: 135
washer fluid indicator???
went to the track and during a session the washer fluid indicator came on - despite not using the washer fluid and having it toped up (I think, I just picked up the car). Is this a problem with the car's computer or is there an other explanation for this???
      08-18-2008, 10:51 PM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
If it continues to occur with full fluid you may have a bad sensor.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      08-19-2008, 01:22 AM   #3
looking
Drives: 135
A bad sensor already? I hope not - I guess I should try to fill the reservoir, just to make sure. This might seem far fetched but would the heat of the engine cause the washer fluid to evaporate?
      08-19-2008, 08:17 AM   #4
mikeo
Santa Fe Concorso
mikeo's Avatar
Originally Posted by excel View Post
...This might seem far fetched but would the heat of the engine cause the washer fluid to evaporate?
I've not heard of anyone having that issue, I know I don't.
      08-19-2008, 11:55 AM   #5
looking
Drives: 135
I've never heard of it happening before but, was just wondering - anyone else?
I'm actually thinking it's a sensor because, the warning seems to come and go - when I do a "check" for the car, it some times says low while other times it indicates that it's fine.
      08-19-2008, 01:57 PM   #6
JME
Drives:
2008 135i  [0.00]
I have had it trigger twice during an autocross. It was during a continuous turn where I was on and off the throttle pretty hardcore; I think it was just the fore-aft transfer coupled with the heavy roll that triggered the sensor.
What were you doing when it went off?
Along the same lines: any way to tone down the warning signal? Man, the first time that went off I about went off course with soggy britches.
      08-19-2008, 08:45 PM   #7
looking
Drives: 135
I was on a "tighter" track when it went off - just coming out of a corner. I looked under the hood today (don't ask me why I didn't pop the hood at the track) and noticed that the washer cap popped off. Is it possible that fluid was lost out the top opening?
Anyways - I filled up the reservoir a bit and will see what happens. I really hope that it's not a bad sensor.
      08-19-2008, 09:18 PM   #8
atr_hugo
No longer moderate
atr_hugo's Avatar
325
Drives: '13 135i
Pull a fuse?
1addicts
