      10-16-2025, 12:28 PM   #1
m1ka
m1ka's Avatar
39
Drives: 335i
X5 high/strange idle on cold start - video attached
2016 X5 - N55
On a cold start, idle instantly drops (for >5 seconds), then idles higher than normal (approx. 5 seconds), then idles normally. Everything else seems normal.
I replaced the Crankcase Vent Hose and it seemed to help for a couple days (maybe it was my imagination, idk).
Any thoughts? This has been happening for many months and not getting better, or worse.
Any help would be greatly appreciated!
X5 Idle - YouTube
      10-16-2025, 03:42 PM   #2
No one
1273
Drives: F21 118i
A dashboard take would look better.
Don't overlook the model's dedicated forum.
Have errors read.
Check/replace the spark plugs.
      10-16-2025, 04:43 PM   #3
SwankPeRFection
Drives: S4, Macan Turbo w/PP
Have you checked the actual PCV? A failed PCV can cause this as well as a vacuum leak and also issues with the SAI system, if that car has it.
      10-21-2025, 02:22 PM   #4
m1ka
m1ka's Avatar
39
Drives: 335i
Have errors read.
Spark plugs were replaced. I’ll get a dash video. Thanks
      10-21-2025, 02:26 PM   #5
m1ka
m1ka's Avatar
39
Drives: 335i
I was thinking the PCV….. I believe the problem started around the time when I changed the valve cover gasket…… maybe its just a coincidence. I’ll read codes and post. Hopefully someone has ran across this issue. Thanks!
