      11-01-2008, 12:39 AM   #1
Johnnyr135
Johnnyr135's Avatar
73
Drives: BMW 135i
DIY Rear Sway Help?
Hi guys I read through all 6 pages of posts for a DIY for the rear sway bar. I read countless post that it is a PITA but I did not find a DIY. Did I over look one? If some one could just posts a few hints I am going to give this a shot tomorrow I have a Blackberry and will try to take photos as I go. Wish me luck guys I hope it is not as hard as I have read.
2008 BMW 135i, DINAN / Riss Racing / BMS
      10-18-2010, 09:30 AM   #2
RaceTime
Auto X'er
Drives: 2009 Space Gray 135i
+1.... I would like to know as well. Any DIY's out there?
2009 135i SGM, Premium, Sports, Nav.
Dinan Stage 2 software, Injen intake, RR Oil Catch Can, H&R Pro-coilovers and springs, H&R front sway bar, Vorshlag camber plates, Vorshlag comp studs, BMW strut brace, BMW performance pedals, G-Force harneses, BMP tow hooks, Breyton GTS-R wheels with 255-35R18 (square set up) and custom axel back exhaust with muffler delete.
      06-22-2011, 09:34 AM   #3
shemeld_135
shemeld_135's Avatar
Drives: 2020 SO - M2C
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
found a site not sure if its accurate or not..maybe someone who did the install could confirm?
http://www.eurotuner.com/techarticle...ate/index.html
      06-22-2011, 09:37 AM   #4
Focusedintntions
Drives: 2011 135i M-Sport :D
to do the rear sway you need to drop the rear subframe. Look for the DIY for the rear diff as it's on there.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
      06-22-2011, 09:42 AM   #5
shemeld_135
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
That is noted on that site w/ pics ! thanks
      06-25-2011, 02:46 AM   #6
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
You don't need to drop the subframe for a diff. Drop the exhaust to get it out of the way, there are 4 bolts for the subframe. Before you lower, you'll have to get some slack in the wheel speed sensor wires by removing them from the body mounting points. Also the brakes lines will need to be taken apart near the drivers front side of the subframe. Then you can lower the subframe. About 6" of drop will get you what you need to unbolt the bar and slide it out either side. But really a pia, but time consuming. You'll need a good jack to support the subframe and the car on jack stands unless you have lift access. Lift access is money in your project....
      07-07-2011, 09:44 PM   #7
Randall41
Randall41's Avatar
Mexico
12
Drives: 2008 BMW 135i Alpine White
from the BMW TIS...
http://tis.spaghetticoder.org
      07-07-2011, 10:15 PM   #8
cpt97m3
AutoXer
34
Drives: 2009 135i
I followed the Eurotuner link when I did the rear bar. Those instructions worked fine, as well as the note above. Time consuming for sure. Send me a PM if you have specific questions.
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
      08-26-2011, 05:32 AM   #9
Lambobimmer
Drives: 2022 X3 M40i, 2018 TTRS
I have a lift so this doesn't seem too difficult. However, I am wondering what type of jack you used to hold the rear axle?
      08-26-2011, 10:07 AM   #10
Xaeryan
Xaeryan's Avatar
38
Drives: Sideways mostly
A transmission jack works well for this, as they are designed to reach high for transmission removal while on a lift. Most shops with lifts also have these. Seen in pic 13 of that article. If you can't get one, you'll have to use a floor jack and keep the car low on the lift, making access a little trickier.
BTW - the article describes everything required for the rear bar install, notably:
Crimp and disconnect two rear rubber brake lines (rear left)
Unclip ABS wires running down the subframe
Disconnect rear section of exhaust (allows you to drop subframe further, otherwise it stops when it rests on the exhaust, which might not be enough for you)
Disconnect lower cross brace rear section (requires removal of the plastic mudflap trim to get at one of the bolts)
Remove four subframe bolts with transmission jack in place
      08-26-2011, 11:57 AM   #11
Lambobimmer
I figured that a tranny jack would work but I want not sure if they would reach that high. I will probably give this a go when it cools down some.
I am not really intersted in completing this on my back so I will try to find something that reaches high enough.
1addicts
