11-13-2008, 03:21 PM | #1 |
Rep 536
Let's remove the steering wheel trim
I am moving to a new host for my site and do not want to go through all my posts to keep images. As a result, I have converted this post into a PDF you can download.
If you use this guide, please take the time to post a thank you. Last edited by AndyM; 06-23-2016 at 03:06 PM.. |
12-31-2008, 08:39 PM | #4 |
12
Rep 308
I just finished following this DIY to install the Bimmian Carbon Fiber steering wheel insert. Hardest part was finding the mysterious "springy" clip when inserting a screwdriver into the holes in the back of the steering wheel to release the airbag. WHAT A BITCH!
One tip: when sitting in the car, insert screwdriver into the hole at an angle that is closer to parallel with the steering wheel than it is perpendicular. Imagine a steering wheel locking device that clamps across your steering wheel. I was fishing around with the screwdriver pointed back at me (handle at front of car, tip of screwdriver towards back of car). I was getting no where. |
12-27-2011, 06:49 PM | #7 |
Rep 272
Drives: 2008 128i
Used this to put on my new Performance steering wheel. Worked great, thanks!!
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
05-22-2012, 01:54 PM | #8 | |
Rep 13
EDIT: I now get it. You don't have to remove the airbag, and im glad. Because it's a pain. -Use Interior trim tools on the piece, at the top there is a clip on each side, near to the airbag. Use your trim tool to pry it open, after loosening the torx screws (obviously). Then pry it open, jam your fingers between and use your pry tool once again but now on the clip. The trim is actually pretty solid, I used quite alot of force and it didn't break. Last edited by pjueern; 05-22-2012 at 03:55 PM.. |
11-22-2012, 04:18 PM | #9 |
Rep 1,198
So if you want to remove the steering wheel itself after the airbag and trim is off is the only thing holding it on that bolt/nut in the center? Just loosen and pull off and slip the new one on? Just askin because I just bought a m3 Tri color stitch wheel that I'm swapping on at the same time I put my alcantera trim piece on.
2013 BMW 135i Alpine white/coral red JB4 stage 2/ AFE stage 2 sealed intake box/ VRSF 3.5 inch catless dp/ Dinan exhaust/ Alpine V3 6000k HID angel eyes/ JB speed AW rear lip spoiler/ OEM mud flaps. ER charge pipe/ VRSF 7 inch FMIC forge star CF5s 19x8.5 and 19x9 |
11-30-2012, 09:40 AM | #10 | |
European Editor
10528
Rep 22,992
11-30-2012, 11:40 AM | #11 |
Rep 837
Drives: 2009 BMW 135i Sport package
AndyM, Thanks for the tutorial! I was able to install my carbon fiber steering wheel trim piece with the use of your info. Even though I could only get the right side air bag clip to release I was still able to install the trim piece with ease! Thanks!!!
12-13-2012, 02:30 PM | #13 | |
Rep 5
12-13-2012, 11:06 PM | #14 |
Rep 961
12-19-2012, 05:14 AM | #15 |
Rep 1,198
Once you've removed the airbag once it's easy. I swapped my wheel last night and first quick release I was fishing for about ten min getting frustrated but once I got I we t to the other side and just like that. Once u do it once its so easy. This DIY was great but the video helped alot too. Thanks for this OP
01-06-2013, 10:12 PM | #16 |
Rep 5
I ended up taking the trim off without having to take the airbag off. I was having a very hard time taking off the airbag, I just couldn't get the angle right to disengage the spring holding the airbag in place. So instead just unscrewed the 3 T-20 bolts holding the trim piece on and slid the trim off, was very easy to do!
04-22-2013, 04:35 PM | #17 |
Rep 277
I don't have the airbag release tunnels in my car
I only have the 3 torx bolts holding on the trim. Did I just get lucky? Or unlucky that they are somewhere harder to get to...? Is it imperative that I disconnect the battery as well? FOUND the answer: Keep the battery disconnected until you replace the steering wheel/airbag. If the battery is reconnected without the airbag the car will throw a code (and warning light on the dash). The code has to be cleared by either a dealer or someone who has access to NCS Expert / INPA (diagnostic software). My battery terminal has a black 'cap' on it where even when I loosened the 10mm bolt it would not come off. I didn't want to pull and do something irreversible. Should I just pull harder?
2010 N54 135i - Alpine White - 6MT - M-Sport - LCI Blacklines - 1M Mirrors - PSS - Powdercoated Black 261M
SELLING MY CAR |
04-22-2013, 04:43 PM | #18 |
European Editor
10528
Rep 22,992
You want to disconnect the battery not just so you don't throw an air bag code but so that you do not DEPLOY the airbag(s) by accident! When ever working on air bags - its always a good idea to disconnect the battery AND THEN wait 30 minutes before working on the car. Most SRS(air bag) systems can still deploy the bags even with the battery disconnected for teh first few minutes. That is why you want to wait a bit.
04-22-2013, 04:51 PM | #19 | |
Rep 277
SELLING MY CAR |
04-22-2013, 04:54 PM | #20 |
European Editor
10528
Rep 22,992
You only have to remove the ground cable. By breaking the battery's connection all electronics won't have power. Its also a good idea to turn off all electrical items before removing the ground cable. And when you reinstall the ground cable... don't be scared of a few sparks that's normal. IF you make it spark too much, you can damage some of the electrical items in a car.
04-22-2013, 06:14 PM | #21 |
Rep 277
Holy hell, how do you torque the nut off that holds the wheel to the car!?
I got everything off and had to reassemble the old steering wheel due to not having the tools capable of removing that nut.
SELLING MY CAR |
04-22-2013, 06:59 PM | #22 |
Rep 961
Put a cheater bar on the ratchet. A second person might help too.
