      11-20-2008, 11:21 AM   #1
Cooldaddygroove
12
Drives:
DIY - Installing Mud Flaps
Tools:
Drill
Pick tool
Small hammer
Strong cleaner to clean your metal and plastic.
Pliers
Ratchet and socket
Allen keys
Alright, when you call the dealer and say "How long to put 4 mud flaps on" and they say 90mins, you tend to be skeptical. Sh*t man, its only like 10 fasteners.
You read the forums here and everyone says "you gotta take the wheels off as well as jack up the car"
Well, you don't. I did all four corners in about 90mins with the car on the ground and all four wheels secure.
The rears are actually harder than the fronts, as there is limited space between the wheel and the fender, you need to use a shorty screw driver to remove/install some screws.
TIPS:
Make sure to super-clean the body panels where the mud flaps will cover before installing.
Use a pick tool to peel back the paper from the two sided tape (if you use your fingers, you will just mangle it).
When you put the fender in place, jam it on their quick and hard. (These things fit super snug and you only get one chance with the sticky two sided tape)
On the front's, when you go to put the long ribbed fastener into the rocker panel (pushing up) DON'T USE YOUR HAND/FINGERS. It will just bend on you. It requires alot of pressure to insert it. What worked really well is an allen key. There is a hole in the head of the fastener, and it runs almost the length of the fastener. Stick the long end of the allen key as far as it will go, position the fastener, lay on your back and push hard and fast. That thing is in so tight it's not even funny.
To install the single fastener inside the wheel well, just turn the wheels to full lock. You will need to drill a hole in the fender behind where the mounting hole is on the mud flap. Lets use the driver's side for example. Turn the wheels all the way to the right. You now have enough room to lay on your back and get a drill on the inside of the wheel to drill this hole. It's "just enough room" for your drill. I actually had to hold the drill upside down in order to use it as it would hit the suspension bits.
I like the look of the mud flaps on my AW. I was getting sick of road fling along my side skirts minutes after washing and detailing my car.
They fit extremely snug, and once in place there are no gaps at all. Very well made parts by BMW.
SEE POST BELOW FOR PICS!
      11-20-2008, 11:52 AM   #2
Northernstar
Drives:
Thanks for the tips -- I'm going to install them this weekend and was wondering if I really needed to remove the wheels.
One quick question: what did you use as a cleaner?
      11-20-2008, 11:59 AM   #3
Cooldaddygroove
12
Drives:
I used a bug and tar cleaner. Then soap and water, then rinse, then wipe. I really didn't want any dirt between the flap and the body.
One other tip for the rear mud flaps. You only get one square clip in your package. I found it belonged to the left rear wheel well. You will see inside teh wheel well an existing hole. It does not line up with the mud flap when you test fit it (but its close). The hole is too big anyways for a screw, but guess what? Its perfect for the clip.
Push the clip into the hole, then slide it (position it) away from you and at about a 45 degree angle from the floor. Check to see that it lines up with the hole in the mud flap, then use a pick tool to poke a hole in the centre of the clip so the mounting screw has something to start grabbing on to.
Install this screw last after everything else is tight.
      11-20-2008, 12:11 PM   #4
My135
85
Drives:
I had mud flaps installed on my 135 and it looks good. I think that it is a good investment to protect the under body paint against rock chip.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
      11-20-2008, 12:17 PM   #5
Northernstar
Drives:
Excellent, thanks again for the tips!
BTW, we moved here to Boston from Vancouver -- it's freezing here today and I miss the moderate temps (makes the rain tolerable).
      11-20-2008, 02:48 PM   #6
sethchan
sethchan's Avatar
Sweden
12
Drives: 2008 135i
I'd love to know what they look like on the car.
      11-20-2008, 02:49 PM   #7
lamini
Drives:
pics?
      11-20-2008, 03:23 PM   #8
marvenmassey
12
Drives: '2011 AW CR DCT 135
Originally Posted by lamini View Post
pics?
Ditto
      11-20-2008, 04:13 PM   #9
Cooldaddygroove
12
Drives:
Its raining outside and I just detailed the car, so pics will have to wait guys, sorry.
      11-21-2008, 11:04 AM   #10
Cooldaddygroove
12
Drives:
Here are some pics of the finished project. I actually find they add to the look (flared) of the car.
      11-21-2008, 11:05 AM   #11
Cooldaddygroove
12
Drives:
And a couple more.....
      11-21-2008, 12:55 PM   #12
Upgrade+
Good life
Upgrade+'s Avatar
130
Drives: 2008 E90 M3 AW
looks good. Can you take side shots of the car to see the whole profile? Also would like to see the stripe better too.
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
      12-13-2008, 03:52 AM   #13
Si-M240i
United Kingdom
137
Drives: M240i LCI
do you have the part numbers as BMW in the UK say they don't do them for the 135i
Please PM me
SI
      12-13-2008, 03:55 AM   #14
135iUSN
19 X5 1998 M Roadster
135iUSN's Avatar
64
Drives: 135i Alpine White / Terra
1998 BMW M Roadster  [0.00]
2009 135i  [0.00]
and. what are the stock #'s for those rims? love them.. I really don't care for the stock 135i US spec ones. Once the summer tires return the will with a new set of shoes!
'09 135i Dinan In BMW heaven 09.28.2022 - Stage 2/Alpine White w/Terracotta /High Gloss Black Trim/ZCW/ZPP/ZSP w/313's /CA/PDC/Steptronic/
      12-13-2008, 10:15 AM   #15
Lester
Drives:
Please PM me
SI
Check with United BMW - those are the BMW part numbers listed as item number.
82160309650 Each$24.75$18.56 1 Series Mud Flaps [ Front ]
82160430733 Each$29.25$21.94 1 Series Mud Flaps [ Rear ]
http://www.trademotion.com/partlocat...subcat1=133774
      12-13-2008, 10:28 AM   #16
Lester
Drives:
Those are the 261M Sport Wheels, they come standard with the Sport Package everywhere except the USA.
      01-01-2009, 05:15 PM   #17
Smac355
Drives:
do those rims come in black? and can u get them in the states through BMW? Thanks!
      01-01-2009, 08:17 PM   #18
Lester
Drives:
They don't come from BMW in black (I don't think BMW sells any black rims). However you could pay to have them powder coated any color you want.
They are indeed orderable from any BMW Dealer, or Dan at United BMW.
      01-01-2009, 10:22 PM   #19
Smac355
Drives:
Thanks... btw BMW does sell black rims in some models ive seen them at the dealership. Was hoping you could get these in black cause i think they would look sick, i wish the US didn't suck so much and leave out all the cool stuff on our cars lol.
      01-02-2009, 11:17 AM   #20
Smac355
Drives:
so has anyone seen the 261M rims powder coated in black/have pics/can photoshop? Happy new years everyone... having a new 1er is a bad addiction lol
Black Sapphire Metallic 135i/Coral Leather Interior/ Gloss Black Grills/20% tint/M door sills/Black 135i badge, smoked LED side marker, Dinan stage II , DINAN Exhaust, performance side skirts, performance shift boot/e-brake, pedals, carbon fiber wrapped interior
      01-02-2009, 12:36 PM   #21
Cooldaddygroove
12
Drives:
I think there are a few pics of 261's powdercoated. Just do a search
      01-06-2009, 08:03 AM   #22
Si-M240i
United Kingdom
137
Drives: M240i LCI
My UK dealers says they don't do mud flaps that fit the front on the 135i MSport as it has different bumpers (fenders) to the normal Coupe.
They can only supply / fit rears (
1addicts
