      04-21-2026, 01:29 AM   #1
logan21
Drives: E87
E87 120d Help
Hello everyone, dear experts.
Initial situation
For quite some time, I had planned to replace the timing chain. I have now done that, but a problem occurred that I cannot resolve.
The timing chain was replaced, all timing marks were set correctly and checked multiple times. Everything was aligned properly. After that, I fully reassembled the engine: all sensors connected, everything mounted correctly.
Nevertheless, the engine no longer starts.
First diagnosis
After the unsuccessful start attempt, I connected ISTA to check for faults. My first thought was an air-bleeding issue or something similar.
Yes, bleeding is generally required, but according to ISTA, 0 diesel pressure is reaching the fuel rail.
Step-by-step troubleshooting
I then continued checking systematically:
Checked the high-pressure fuel pump
Checked the pressure control valve / IMV
Inspected everything related to the fuel system
After that, I also checked all fuses, because an incident had occurred earlier:
During reassembly, a battery charger was connected. I wanted to tighten an engine mount nut using a long wrench, and the wrench accidentally touched something and caused a short circuit.
The vehicle was switched off at the time, so I initially assumed it could not cause any issues. Nevertheless, to be safe, I checked all fuses — no faults found.
Low-pressure (pre-supply) fuel pump check
Next, I checked whether diesel was being delivered at all.
Normally, during bleeding via ISTA or when switching on the ignition, you can hear the low-pressure fuel pump at the rear of the vehicle.
However, it was completely silent.
So I supplied the low-pressure pump directly with 12 volts — and it ran perfectly.
After that, I checked the hose at the outlet of the fuel filter:
➡️ Absolutely no fuel came out, not even a small flow.
This made it clear:
The low-pressure pump is mechanically fine, but it is not receiving a control signal to activate.
EKPM check
My next suspicion was the EKPM (fuel pump control module). I thought it might have been damaged by the short circuit.
Ordered a new EKPM
Installed it
➡️ No change — still no fuel delivery.
Sensors / Crankshaft position sensor
The crankshaft position sensor (CKP) is connected. I even removed and checked it again.
Installed correctly
Properly secured with the bolt
Installation depth appears correct
So far, everything I can think of has been checked.
Current status & open questions
The only remaining assumption from others is the following:
The DDE is not sending a signal to the EKPM to activate the low-pressure fuel pump.
My questions are:
What could be blocking the DDE?
Why is the signal not being released?
What might I have overlooked?
Has anyone experienced a similar situation after a timing chain replacement?
I have reached a point where everything seems to be checked, but the issue remains unresolved.
Thank you in advance for any helpful ideas.
      04-21-2026, 02:21 AM   #2
ptpending
ptpending's Avatar
908
Drives: e81
so you dont have any faults in ista ?
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      04-21-2026, 07:46 AM   #3
logan21
Drives: E87
Hi, Yeah, but not direct errors—I guess maybe JBE
      04-21-2026, 08:07 AM   #4
ptpending
ptpending's Avatar
908
Drives: e81
you have comfort access option and your comfort access module is not available
do you insert key in slot ?
