      01-06-2009, 12:46 AM   #1
Morock'N
Morock'N's Avatar
Drives: '06 Evo 9 SE, '11 E90 M3
How wide of a tire I can put on stock rims for a 135i?
I keep getting mixed answers on how wide of a tire I can put on the stock rims front and rear. Please let me know if you are 100% sure. Just want to get some good tires for street use and don't want to risk spending money for something that will no fit. BMW's are new to me, I was able to stuff a 255 on an 8" wide rim on my STI.
Thank you all!!
      01-06-2009, 05:28 AM   #2
Joey_T
That's me...
Joey_T's Avatar
17
Drives: 135i
335i's standard 18'' wheels:
- front 8Jx18: 225/40/18
- rear 8.5Jx18: 255/35/18
Since 135i's rims have the same width (8J front, 8.5J rear), no problem putting those dimensions on. Anything larger - someone else will have to answer.
Hope this helps.
      01-06-2009, 06:37 AM   #3
Lester
Drives:
http://www.rims-n-tires.com
This configurator will let you check out various combinations. The ones shown by Joey will work, they are slightly higher and wider but not by an excessive amount.
      01-06-2009, 10:31 AM   #4
adc
Drives: 2018 F80 M3 ED
Actually the 135i has narrower rims up front: 7.5". 225 will work for sure in the front, 235 might also work depending on the actual tire - for example a runflat might not work because it has a different sidewall construction.
If you want to try 235 up front, contact Gill at Tirerack (a board sponsor) and ask him about specific tires you have in mind - he'll tell you right away what will work and what not.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
      01-06-2009, 10:38 AM   #5
Morock'N
Morock'N's Avatar
Thank you so much! that helps alot . 225/255 it is.
      01-06-2009, 12:22 PM   #6
adrean8j
adrean8j's Avatar
121
Drives: SGM 135I
2008 135i  [10.00]
I sent them an email and they updated the configurator to include the 1-series now...:w00t:
Originally Posted by ptack View Post
SGM was God's color and has been recalled to heaven.
      01-06-2009, 04:43 PM   #7
Cooldaddygroove
12
Drives:
Thanks for that update adrean8j...they even show a 20" wheel is possible
1addicts
