      04-24-2026, 07:31 AM   #1
fe7565
fe7565's Avatar
Drives: 2012 BMW 328i N26
Using AI...solving your BMW and your daily life issues
Bottom line first: AI can help solve problems for the average person that even a year ago lead to a dead-stop/dead end in finding a solution. And this apples to BMW diagnostics/repair too.
I have prided myself to be able to diagnose and fix my own BMW issues that came up (luckily not many) during the last 13 years of my current aging F30. Without the help of this Forum I would have not been able to accomplish 90% of the retrofitting that I have done. I learned so much from these threads and so many people helped along the way. This is the part that I may be missing the most, if AI takes over as the "authoritative authority" on diagnosis and repair guides.
A warning with AI! You have to know some basics about the subject you are searching about, as based on the complexity of the topic, AI will make mistakes. And if you are clueless about your topic, you will go down some time-wasting and expensive rabbit holes. Guess how I know it...
However, let me illustrate what AI can do for you: I am an electronics hobbyist with no formal background other then some basics. For about 6 years 2018-2024 I was working in my spare time on some basic electrical/mechanical stuff that were closely related gadgets. I spent a lot of time on Google searching for answers, in various forums asking for assistance, etc I was never able to complete what I wanted, because of my lacking knowledge (regardless how much I learned online and from my mistakes...and I am not dumb). And it was not worth to pay someone to help, because that is no fun and defeats the purpose of the hobby.
About a month ago I dusted off my old projects and used Claude AI, Gemini AI, Grok AI, and couple of other more restrictive ones. In a couple of weeks of intense "work" I was able to get near the finishing line with projects that took me 6 years to get to 70%. A warning: you need to know enough to recognize when the AI makes a mistake, but you do not need to know as much a real professional engineer. However, the final work can be professional quality/level work with AI help.
How does this tie in with BMW and this Forum? I have increasingly used AI to help diagnose and validate error codes and potential solutions. Some of these with problems that I was able to solve previously in the old-fashioned way: first-hand experience, online research, with forum members help. And since I already knew the answer/solution to the problem at hand...I was able to evaluate the AI's response. Astonishingly accurate and comprehensive.
If you use AI, do not forget that often "garbage in...is...garbage out". Although AI can detect and re-interpret most misspellings, grammatical or syntax errors, you have to able to get your request into the ballpark. The more specific and comprehensive you are, the more accurate and focused answer you will receive from the AI.
I do not know if the AI will replace the awesome members of this Forum who give regular good advice (I hope not), but it certainly does provide a very useful option for DIY work.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
Appreciate 6
jefe20001423.00
25 V8 IS3143.00
eugenebmw2494.50
      04-24-2026, 02:09 PM   #2
25 V8 IS
25 V8 IS's Avatar
3143
Drives: 2025 Lexus IS 500
I use AI for all my automotive inquiries and it is usually right on the money with suggestions. Saves a ton of time looking it up. Gemini also knows my preferences so it's easy peasy.
2025 Lexus IS500
Infrared/Ultra White
fe75651141.00
      04-24-2026, 06:46 PM   #3
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
This forum is the best E9x M3 resource there is. Anyone know how we can get all the info in all these forum pages into NotebookLM and make it query-able? Unfortunately NotebookLM does not have a web scraper...
      04-25-2026, 02:24 AM   #4
smokinjoe64
Naval Aviator
smokinjoe64's Avatar
Drives: e92 M3 6MT
2012 BMW M3  [9.75]
2025 Mazda MX-5  [0.00]
2003 BMW M5  [0.00]
2024 Ranger Raptor  [0.00]
Generally concur with sentiments noted.
As a long time Community member, my take - - AI is supplemental, not a forum replacement [at least for now ].
One key to keeping in mind with AI automotive diagnosis is knowing, reviewing 'sources sited'.
On occasion, find AI responses are not accurate with multi-variable, more in-depth troubleshooting analysis. Actually request AI sources for additional due diligence. Sometimes pose same inquiries with different agents as well...there are differences in results.
e92 M3 - Interlagos Blue | Recaro GTs w/Fox Red Extended |Carbon Leather
BPM Stage II; SuperSprint: header-back, catless, nonresonated, F1s; Infinity Design CF intake; Partee Racing CF plenum; do88 coolers; Bilstein B16 kit w/EDC, monoball links; Brembo BBK; AutoSolutions SSK
fe75651141.00
      04-25-2026, 02:34 AM   #5
smokinjoe64
Naval Aviator
Drives: e92 M3 6MT
2012 BMW M3  [9.75]
2003 BMW M5  [0.00]
thas an ole school approach...precisely one reason for generative AI to vastly improve search, access, data compilation, analysis etc
      04-25-2026, 03:58 AM   #6
fe7565
fe7565's Avatar
I am trying to get my 86 year old uncle to use more AI…. He says, “I don’t need AI…I have my wife”. (well, at least in essence that’s what he wants to say)
      04-25-2026, 07:44 AM   #7
Janjohn
Master Sergeant
Janjohn's Avatar
286
Drives: 2026 BMW X3 M50
Agree with everything said. A couple nit pics about the BMW AI available through the BMW App. I can’t highlight and copy the text in the answer. I have had to take multiple screenshots to view AI’s answer. That’s pretty lame.
There’s not a definitive list of English commands that the BMW Assistant understands. Really??? That’s inconvenient.
I most often use Google Gemini for searches, compar-os, and shopping. I use Grok for statistics that might have a political angle and ChatGPT for more image creation.
I’m certainly not afraid of AI, I’m hoping for significant technical advances to make my life easier. Right now, I’m left with the feeling “is that all there is”?
I’d rather ride a Pegasus than a Unicorn
Garage:
2026 BMW X3 M50 Tanzanite Metallic
2023 Dodge Challenger Hellcat Octane Red
2019 Ford F150 Lariat Blue Jeans
fe75651141.00
      04-25-2026, 09:02 AM   #8
jefe2000
jefe2000's Avatar
Drives: 2018 M2 6MT
2018 BMW M2  [10.00]
Awhile back, one of the members of the M2 sub-forum was testing a proof-of-concept AI chatbot that consumed all the M2 content. I don’t know if he trained the model on the content or used a RAG approach to feed the content in at query time.
It was pretty nice! I appreciated that it cited its sources (provided links to related threads) and gave confidence scores for its answers. However another forum member eventually came along and pointed out BIMMERPOST T&C’s about scraping content and copyright. Not wanting to run afoul of the T&C’s, the original member closed down access to the chatbot and that was that.
You can see more here:
https://www.bimmerpost.com/forums/sh...php?p=32071680
fe75651141.00
      04-25-2026, 11:52 AM   #9
fe7565
fe7565's Avatar
I think we are still in the infancy of AI, at least at the "free" causal user level that I am using. When it comes to certain things (non-BMW related), I am still "smarter" then the AI...which is proof that AI is still "learning" since I am certainly not a genius
But let's not forget that while rolling it out for the public to use in a casual way is just happening now in 2026, it was preceded by industry and GOV use, like Palantir over 15 years ago employing its early model(s) to locate Bin Laden.
      04-26-2026, 08:35 AM   #10
BMWGirlFL
BMWGirlFL's Avatar
8181
Drives: 2026 Z4 M40i
ChatGPT mod preview:
Name:  ChatGPT Image Apr 26, 2026, 09_00_20 AM.png
      04-26-2026, 10:19 AM   #11
fe7565
fe7565's Avatar
Originally Posted by BMWGirlFL View Post
I wonder what it would look like, if you change the chrome kidney-grill trims to "red satin chrome", like this, but a bit darker : https://www.amazon.com/dp/B00MJ807X6...sin_title&th=1
or this "red lava pearlizer" color : https://www.amazon.com/dp/B01J16X0Z0...fed_asin_title
I have black grills with chrome trims around, however used this same "red satin chrome" for the two crossbars inside, in front of the radiator and used the "red lava pearlizer" DIP spray for my brake calipers.
      04-26-2026, 10:40 AM   #12
BMWGirlFL
BMWGirlFL's Avatar
8181
Bottom is before and too black for me. Think I'll be happy with just frame swapped to cerium. ChatGPT will add red accent stripes if you want to play with yours.
      04-26-2026, 11:24 AM   #13
fe7565
fe7565's Avatar
Yea, I had all chrome OEM, but all black was too much for me, the BMW would lose too much "BMW". So went with black grills and chrome outer trims like yours.
      04-26-2026, 07:15 PM   #14
Redd
Any suggestions then how to get an LLM into this site without needing the admins to do anything?
      04-26-2026, 07:26 PM   #15
smokinjoe64
Naval Aviator
Drives: e92 M3 6MT
2012 BMW M3  [9.75]
2003 BMW M5  [0.00]
Pretty certain question posed is already known, understood... right?
      04-26-2026, 08:03 PM   #16
PurpleZ
PurpleZ's Avatar
573
Drives: ‘21 M550, ‘26 Z4 HS
While AI is fun to play with in terms of pictures, I’d not trust anything in terms of advice or research. It gets just so much wrong. Here’s a recent vid on AI and one of my other hobbies guitar……
      04-28-2026, 03:28 PM   #17
fe7565
fe7565's Avatar
Yes, you must know enough about the subject you are researching or asking for help with not to be mislead by AI. And of course, common sense: not to use it for any safety, life-changing topic, health-risk, etc that you cannot confirm independently by an affirmed authority on that topic.
We are still in the early 1990s of the Internet's development when it comes to AI. On the average Joe-level at least, for public use. Companies, education research institutions , and GOVs have much more powerful and reliable verison(s).
      04-28-2026, 03:53 PM   #18
fe7565
fe7565's Avatar
I fixed your car! (I am actually pleased how well this AI works...will do my own car next)
BMWGirlFL8180.50
      04-28-2026, 03:56 PM   #19
Brandoch
Brandoch's Avatar
2001
Drives: 2009 E93 M3 DCT
I still have not (knowingly and willingly) used AI.
I learned in elementary and high school how to search the internet in the 90's and early 2000's. I was also taught to "never believe in things you see on the internet unless you can verify it your self". I was also taught about privacy and personal information.
I just have no practical use for it in day to day living. And I am not willing to use it for fun because of my own privacy concerns. This is my only form of social media.
I'm definitely feeling like the old guy shaking his cane at new things. But I'm OK with that.
fe75651141.00
BenFenner273.00
      04-28-2026, 04:18 PM   #20
fe7565
fe7565's Avatar
Yes, Brandoch, you are definitely a hard person to please as it became evident for me in my Valvoline R&P thread with your "marketing" after "marketing" opinions. Which is fine, I live in a free country and you live in Canada. I worked for three years in Ottawa for Uncle Sam...and I have great respect for Canadians who wear shorts and short sleeve polo shirt when doing quick shopping in -28C (-18F)
      04-29-2026, 04:06 AM   #21
zubobawud49
Drives: BMW
AI + DIY Diagnostics: Tool, Not Replacement
I think you’re landing in the right place: AI is a *force multiplier*, not a replacement for forums or hands-on experience.
What it’s really good at is removing that “dead stop” moment—when you don’t even know what to search for. For something like a BMW F30, that’s huge. You can feed it codes, symptoms, context, and it’ll give you a structured starting point instead of hours of scattered threads.
But your warning is spot on: it’s only as good as your ability to **sanity-check it**. If you already know the system basics, AI feels almost like having a second opinion that’s fast and wide-ranging. If you don’t, it can absolutely send you chasing the wrong fix.
Where forums still win (and probably will for a while):
* **Edge cases & weird failures** that only show up in real-world use
* **“I’ve seen this exact issue before”** experience
* Accountability — people push back, correct each other, refine answers
Where AI shines:
* Translating error codes into **possible root causes + next steps**
* Aggregating info into a **clear diagnostic path**
* Helping you **iterate faster** when you’re stuck
So instead of “AI vs forum,” it’s more like:
1. Use AI to get in the ballpark and build a plan
2. Cross-check with forum knowledge and real experiences
3. Execute and adjust
If anything, the people who benefit most are the ones already doing what you described—DIYers with enough knowledge to filter signal from noise.
fe75651141.00
jefe20001423.00
      04-29-2026, 11:00 AM   #22
fe7565
fe7565's Avatar
Originally Posted by zubobawud49 View Post
....people who benefit most are the ones already doing what you described—DIYers with enough knowledge to filter signal from noise.
Spot on! At this point in time, they get the most benefit as long as they are able to "ballpark" if the AI takes them in the right direction.
At the same time, comes the dilemma for those who are genuinely clueless about a subject, but otherwise are intelligent enough in general terms. The Forum can help them dial in terminologies/basics and then they can go to AI and get the detailed/more specific potential path to solve the issue. Less likely to be mislead by AI and not even knowing about it.
Then come those who are clueless about a subject and are also clueless about generally everything. AI can become a huge help, and a definite improvement in life-decisions and solving everyday problems. The problem comes with "garbage in...garbage out" when they turn to AI for help.
I am sure most heard about the Dunning-Kruger Effect. In essence: stupid people lack the ability to evaluate that they are stupid. As a consequence, they consistently overestimate their own abilities. I still believe that such people also benefit from AI with some safeguards (from AI): obviously AI should not give them (or anyone) "life-saving" "life-threatening", etc advice...or not without caveats that are understood by an 8 year old.
Imagine the life-changing advice AI can give you, if you have been paying your monthly credit card bill's minimum balance for the last 10 years with your balance being still the same or more? Imagine the help AI can be explaining the "magic" of compound interests when you were 20 years old? Imagine AI explaining that buying an $80k car requires maintenance, and not running the car with the same oil/filter for 25k miles, the paint needs some protection at least every 5 years so the paint will not peel/flake, or that you do not run the brakes into the metal, etc. I see many people around who love a flashy car, but it's not in their culture to maintain it...as their vallet cannot afford it and/or they are clueless.
Imagine going to the auto repair shop/dealer and able to use AI to assess the validity of their proposed charges/actions and the associated "fair" pricing". And many many more opportunities like these...
