02-01-2009, 01:19 AM | #1 |
55
Rep 2,013
Installing the Remus Quad exhaust (56k killer)
As I got the Remus exhaust, I immediately noticed it was well packed. as I tore it open I was happy with the quality of the setup and the coating was excellent on the exhaust.
A few pics: The bag of Hardware included... opened... You will need for installation: -Drive Up ramps -Flashlight/ work light -Dremel -set of wrenches -set of sockets -needle nose pliers - Some type of lubricant (I had pool equipment lube around so I used that) -yourself -some beer (optional) Last edited by rcracer_tx; 02-01-2009 at 01:38 AM.. |
02-01-2009, 01:19 AM | #2 |
55
Rep 2,013
Start by removing the rear diffuser using this DIY:
http://www.1addicts.com/forums/showthread.php?t=209818 Once taking off the rear diffuser, you will see the mounting points on the muffler. Remove the mounting points as well as the line going to the muffler as pictured here, and put a box under the muffle to support the weight of the muffler Now go down under the car and remove the bolts connecting the exhaust to the resonator and the last mounting point under the car: Now remove the exhaust from the car: Last edited by rcracer_tx; 02-01-2009 at 01:43 AM.. |
02-01-2009, 01:20 AM | #3 |
55
Rep 2,013
Cut the Exhaust 2 inches from the muffler on the old exhaust using a dremel or or electric hacksaw and connect piping to the main Remus muffler:
Now it's time to add the mounting bracket for the other side of the exhaust. It simply bolts onto an existing bolt on the other side of the car, after attach the main exhaust by reversing the steps shown: Now attach the second side of the exhaust piping to the exhaust and tighten all hardware: Cut the rear diffuser by tracing over the original side of the exhaust and flipping the traced piece over and cutting with a dremel (sorry no pics, but it's pretty easy and self explanatory). Next a notch for the exhaust needs to be cut with a dremel in this piece (will take picture of notch cut, forgot when installing): Last edited by rcracer_tx; 02-01-2009 at 03:43 AM.. |
02-01-2009, 01:20 AM | #4 |
55
Rep 2,013
After completing all of these steps, replace the diffuser using the DIY posted at the beginning, Fire it up, and take a test drive to enjoy the sound, and check for exhaust leaks.
By this time the sun should be setting, so sit back,crack open a beer, and enjoy looking at your new exhaust... Last edited by rcracer_tx; 02-01-2009 at 02:06 AM.. |
02-01-2009, 07:15 AM | #5 |
Alpine Master
109
Rep 1,310
A+ man. Does it pretty dramatically change the sound or is it just a cosmetic mod?
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
02-01-2009, 02:32 PM | #7 |
55
Rep 2,013
Thanks for the compliments guys.
It is still very quiet, but the tone has changed significantly...Its much more aggressive and deeper now. I personally like a little bit louder exhaust so I am going to get a set of downpipes to pair with this. |
02-02-2009, 09:29 AM | #8 |
33
Rep 791
Great writeup RC, thanks!
A more centered look is close to impossible with the way the 135i's underbody is layed out. Major modifications of the underbody, the bumper, and the piping are necessary which involves too many variables to make it an affordable quad solution to the market. If you would like a quote on the 135i QUAD, please PM us! |
02-02-2009, 11:16 AM | #10 | |
55
Rep 2,013
From Remus...
02-06-2009, 08:22 PM | #13 |
59
Rep 1,859
i am interested in this but getting used to the tips- how long did this take you- ie how long would it take a shop to do it
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA |
02-07-2009, 06:59 PM | #14 |
55
Rep 2,013
It took me about 2hrs (including putting the DIY together) It shouldn't take a shop more than an hour for the exhaust and 20-30 minutes for the cutout (took my time and sanded it with a dremel as soon as I got close to the size it should be so it would be more precise)... MAX a shop should charge you is 2 hours.
06-22-2011, 02:55 PM | #15 |
Rep 8
what are you supposed to do with the vacuum line once you take it off?
*nevermind, i got it.
BMW 135i 08/grey/ m-sport package/red interior/matte black grilles/matte black emblem/BMS DCI/18'gunmetal forgestar f14 wheels/ Toyo T1rs/ bms jb3/bms can tool
LeMans 135i8.50 |
06-22-2011, 11:52 PM | #16 |
Rep 30
WOW Looks good!!
-- 2010 135i -- Alpine White -- Black interior -- ///M-Sport -- iPod --
|| Blacked out Grill || 20% tint all around || BMW Performance Spoiler || Maddad EuroSport Street Exhaust || CF Roof Wrap || Injen Dual Cone Intake || |
05-28-2013, 12:25 PM | #18 |
Rep 469
Drives: 2008 Bmw 130i E81
wow only saw it now! how much did this all cost you?
Fack i see the guy is banned.... damnit! this looks like the easiest quad exast setup to do! i want a video of how it sounds. i dont dig the tips but im sure u can do summin about that. i found the exaust! and it has waaaay better tips! There is a before and after sound clip on the website. Sounds pretty awsome i think. http://www.remususa.com/epages/remus.../0889081584CLR
Wishlist...
Bmw 135i Convertable White... Last edited by MaDoNiOn; 05-28-2013 at 12:33 PM.. |
05-28-2013, 03:24 PM | #19 |
European Editor
10528
Rep 22,992
IF you run a four pipe exhaust don't forget to use some heatshield material above the battery box area. I remember one poor guy here melted his charcoal cansiter near teh fuel tank. ~$1000 repair bill.
08-10-2013, 04:13 AM | #20 |
Rep 12
Remus Exhaust
Hi,
I have the same on my 2012 135i DCT M-Sport. I love the quad look. I installed a Catlass DP and the sound is just amazing.( Kinda loud when in non sport as its mostly in 7th gear) When in sport mode its kick ass sound. |
09-17-2013, 08:24 AM | #21 | |
Rep 469
Hey thats awsome! Do you have a video by any chance?
Wishlist...
Bmw 135i Convertable White... |
