The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > upgrading from 17's to 19's
      02-25-2009, 12:56 AM   #1
walsh
walsh's Avatar
Drives: F80 M3
Is this possible? I think theres no way to get the rolling diameter below 1% off unless you got really skinny wheels. It would suck if this is true. Thanks.
      02-25-2009, 06:06 AM   #2
JeffL
JeffL's Avatar
35
Drives: C63
yes. 235/30/19's and 265/30/19's. The main goal is to keep within the 1% diamater difference between front and rear wheels/tires. for non-staggered you could run 245/35/19's all around depending on wheel offset. That would be way more than a 1% difference than stock but all 4 are the same so you wouldn't have any issues.
no sig.
      02-25-2009, 01:59 PM   #3
walsh
walsh's Avatar
Drives: F80 M3
Thanks, my speedometer would be off by a lot though right? because there would def be a big diff from stock?
      02-25-2009, 05:32 PM   #4
louie_perm
Drives: *
A larger diameter wheel doesn't mean a larger diameter tire. A 245/30-19 is not as tall as a 235/40-18, for example, yet both of them can fit the e90. As the wheel's diameter gets larger, the tire's sidewall must get shorter. That's why the aspect ratio falls from 225/45 at 17" to 225/40 at 18" to 225/35 at 19". The tread widths are the same, the overall diameter of the tire is approximately the same, but the hole in the middle of the tire where the wheel goes is getting bigger as the tire sidewalls are getting shorter.
The point is not to keep the rolling diameter as close as possible to stock. Instead, the point is to keep the rolling diameter as close as possible across the 4 tires. The easiest way to do this is to go non-staggered (same tire on all 4 corners)--whether you use 225/35-19, 235/35-19, 245/30-19, or 255/30-19 doesn't matter, as long as the wheels have the right widths and offsets to keep the tires from rubbing.
If you want to go staggered with the Xi, then 225 (front) and 255 (back) are usually pretty close in rolling diameter, as well as 235/265.
      02-25-2009, 06:36 PM   #5
Nikolas
Drives: 996 TT
You mean 235/35/19's for the front. 235/30/19 and 265/30/19 is a bad match.
I have 235/35/19 and 275/30/19 which is nearly identical in diameter.
      02-26-2009, 02:41 PM   #6
JaysBlueE92
Mr. Monaco
JaysBlueE92's Avatar
Drives: Slow..
2007 E92  [5.00]
what's the best tire sizes to run on xi coupe with 20 inch wheels?
      02-26-2009, 08:20 PM   #7
walsh
walsh's Avatar
Drives: F80 M3
225/35/19 front and 255/30/19 rear is the correct sizing although other setups can work... i was comparing to the wrong stock size... that's where my confusion came from.
      02-26-2009, 08:22 PM   #8
walsh
walsh's Avatar
Drives: F80 M3
Good luck with that... I dont think you can even even do staggered 20's on an xi. You'd prob have to run 225/30/20 all the way around and i'm not even sure that would work.
      02-27-2009, 11:51 AM   #9
JaysBlueE92
Mr. Monaco
Drives: Slow..
2007 E92  [5.00]
good to know..thanks for the input. I guess it's gonna be 19's then
      02-27-2009, 02:13 PM   #10
JeffL
JeffL's Avatar
35
Drives: C63
yes 235/35/19. broke my right wrist and typing with a cast is challenging.
no sig.
