Defective SSTT
04-09-2009, 11:11 PM | #2 | |
Rep 184
Why are you redlining? I'm not saying you should expect a limp if you redline, but it's kind of pointless. Not sure what the SSTT boost levels are like, but you can assume there is no power after 6500 RPMs
04-10-2009, 05:36 AM | #3 |
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
i concur w/ akira42, stay away f/ REDLINING your BMW. save it for the track if you are so inclined.
04-10-2009, 05:59 AM | #4 |
Rep 2,108
something is wrong. either its the SSTT or ur diverter valves are not holding boost although i highly doubt that. did u get the codes scanned?
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
04-10-2009, 09:06 AM | #5 |
Rep 1,481
Drives: '11 M3 MW/FR - '12 M3 FO/SC
Garage List 2004 Honda Hornet [0.00]
2003 Chevrolet 2500 ... [0.00] 2011 BMW S1000RR [0.00] 2011 BMW E92 M3 [0.00] 2012 BMW E92 M3 [0.00] |
Scan codes before jumping to conclusions, post your codes here if you need help figuring them out. The SSTT is such a simple device it is unlikely that it is malfunctioning. In the event that an SSTT is not working properly you should get codes on startup indicating that the TMAP is not connected.
04-10-2009, 02:19 PM | #7 |
Rep 184
Will the car even start if the connection is no bueno? I would think that the car wouldn't allow you to run. With no connection or even a bad connection.
04-10-2009, 02:36 PM | #8 | |
One cam is enough
132
Rep 6,801
Weird. |
04-10-2009, 02:38 PM | #9 | |
Rep 2,014
The problem was fixed with a simple push of one of the connectors into the plug.. |
