Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY- Rear Fog Lights
      08-08-2006, 07:33 AM   #1
brianlay
Drives: 330i
US cars can have the rear foglights enabled by replacing the light switch with the Euro version. These are the same lamps already installed as adaptive brake lights. While the rear fogs are switched on, the adaptive brake light function is disabled.
Parts required- 61 31 6 932 796 Switch
Tools required- flat blade suitable for prying trim pieces
First remove the trim piece with AC vent directly above the light switch. I found it was easier to start on the inner end near the speedo. Here what it looks like after removal.
This shows the clips that hold the trim in place
Now pry out the light switch with its trim piece.
Remove the cable by rotating the connector clamp.
Remove the trim by pressing in on the clips and move the trim to the new switch.
Re-install the switch and trim pieces and you're ready to test.
The rear fogs can be switched on only when the fronts are on.
These lights are very bright (21 watt halogen) and can be very annoying to drivers behind you, especially at night in clear visibilty conditions.
Apparently BMWNA thought US drivers couldn't be trusted to use these lights responsibly. Let's prove them wrong.
      08-08-2006, 08:44 AM   #2
KL2DC
Moderator
KL2DC's Avatar
Drives: F36 428i,E90 328i, E85 Z4 3.0i
2015 F36 428i  [0.00]
2011 E90 328i  [0.00]
2006 E85 Z4 3.0i  [0.00]
Hang on, just to be clear...all we need to activate the rear fogs is just the switch? That's it? Is this part easily obtainable (not special order etc). GB anyone? So with the rear fogs off, we still have adaptive braking lights, right?
Could we have more pics of installing the actual switch, its not illustrated enough. Is it just plug in, plug out.
Awesome find! Awesome DIY!!
P.S. Admin please add to Master DIY list. Thanks
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call!
      08-08-2006, 09:12 AM   #3
Josh49
Drives: E90 325xi
Yeah this is awesome. I had the rear fog light on my A4, and thought it was a very good idea for dense fog. It definitely saved my ass several times. Literally... Called a bunch of dealers and this part is on backorder and not easily obtainable. If anyone has luck please contact me. Thanks..
E90 325XI, MYSTIC BLUE ON BLACK/ALUM, STEP, NAV, PDC, CWP, XENON, SIRIUS, ALARM, MUD GUARDS, CLEARBRA, CHROME GRILLS AND TIPS, VALENTINE 1 (HARDWIRED), HO CERAMIC 40%, 161'S, REAR FOG MOD, LUX 4.0, BLACKLINES, OEM PEDALS, MTEC FOGS, GRUPPE-M REP INTAKE. 156'S AND RUBBER MATS FOR THE WINTER.
      08-08-2006, 09:14 AM   #4
KL2DC
Moderator
KL2DC's Avatar
Josh: I am also interested in this mod for the reasons you mentioned. Do you know how much the part is? Maybe we can get some sort of GB going, it looks like a relatively easy euro mod....
      08-08-2006, 09:28 AM   #5
Josh49
Drives: E90 325xi
Part is $75. Availability is the hard part..
      08-08-2006, 09:50 AM   #6
KL2DC
Moderator
KL2DC's Avatar
Thanks Josh, gonna ask around, as well. $75 is not too bad, considering the safety value.
      08-08-2006, 10:05 AM   #7
CnoteMD
Commander in Chief
CnoteMD's Avatar
Drives: 2008 BMW 535i
2008 M5  [0.00]
2006 330i  [0.00]
Good work!
This is the first truly useful lighting modification I have seen on this site. I think the mods on my car will be limited to your DIY and a set of Euro taillights (I don't like the look of the blacklines).
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options
Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers
      08-08-2006, 11:26 AM   #8
longtran
longtran's Avatar
1429
Drives: E90 M3
2006 325i  [0.00]
i might get this...just to annoy the driver behind me..
      08-08-2006, 11:28 AM   #9
KL2DC
Moderator
KL2DC's Avatar
I have a feeling, not only are you getting this mod, but you'd probably upgrade the bulbs to true HID or something sick like that...all in true Longtran fashion
      08-08-2006, 12:17 PM   #10
oneshare325
oneshare325's Avatar
Drives: E90 325i, E82 135i
2018 BMW M3  [0.00]
2006 325i  [0.00]
Sweet, if you guys get a GB together I am down for that! I am really big on Lighting mods! Lights change the WHOLE look of a car!
      08-08-2006, 12:58 PM   #11
Asiann
Got Seoul?
Drives: 2012 535i MSport
2012 BMW 535i  [0.00]
2008 750Li  [0.00]
2006 BMW  [0.00]
Scroll down to see differences. I used yellow as an example but you can do more colors. And yes mine are still white. http://www.e90post.com/forums/showth...=pics+door+led
Can you say Alooooha?
[SIGPIC][/SIGPIC]
      08-08-2006, 01:07 PM   #12
oneshare325
2018 BMW M3  [0.00]
2006 325i  [0.00]
Yea, I saw that, i saw driving with them on too...I like the stock color though, and I think driving with them on looks stupid. Brighter might be cool! Great work though!
      08-08-2006, 02:02 PM   #13
bavarian19
bavarian19's Avatar
Drives: Car
Are there supposed to be pictures with the DIY??? I dont see them if they are...
I would also like to do this mod if we can find the part. Let me just make sure of something as well... If this mod is done, does that mean that adaptive braking is not available all together, or just not when the rear fogs are in use???
      08-08-2006, 02:06 PM   #14
KL2DC
Moderator
KL2DC's Avatar
AJ,
this is what brianlay posted in his other rear fog light thread:
"it uses the same lamps as the adaptive brake lights so the look is the same. also, when they are on it overides adaptive brake lights...so says the manual."
So whadya say, another group install?
      08-08-2006, 02:07 PM   #15
Asiann
Got Seoul?
2008 750Li  [0.00]
2006 BMW  [0.00]
I would only be interested if they could blink when you use the turn signals.
[SIGPIC][/SIGPIC]
      08-08-2006, 03:20 PM   #16
bavarian19
bavarian19's Avatar
Drives: Car
AJ,
Sounds good to me... I just dont want to lose functionality of the adaptive brake lights when they are not on...
      08-08-2006, 03:22 PM   #17
KL2DC
Moderator
KL2DC's Avatar
AJ, could you do some groundwork and check your usual supply sources for that part? Maybe get a small local GB going? Then we can do a group install...looks sorta doable...
      08-08-2006, 03:33 PM   #18
bavarian19
bavarian19's Avatar
Drives: Car
I still dont see those pictures...
Do we have a PN??? I can do some investigative research, and use my cca discount to get us a decent deal... BMW of Sterling Parts Department knows me by name now...
      08-08-2006, 06:24 PM   #19
zamboni
I want to drive a Zamboni
zamboni's Avatar
Drives: 13 E93 M3 18 F80 M3 16 K71
16 K71 F800GT  [10.00]
2018 F80 M3  [10.00]
2013 BMW E93 M3  [10.00]
Nice write up Brian, I will send the request to Morristown BMW for a quote and will keep everyone posted.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue
13 E93 M3 Melbourne Red
2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3
My next vehicle would be a Zamboni
      08-08-2006, 07:09 PM   #20
Josh49
Drives: E90 325xi
Part number in 1st post..
Josh
      08-08-2006, 07:44 PM   #21
BMW_E90
BMW_E90's Avatar
57
Drives: 325i
sorry for the noob question but i have to ask can some1 tell me about the adaptive brake lights.. never heard of it.... sorry guys lol
      08-08-2006, 07:48 PM   #22
KL2DC
Moderator
KL2DC's Avatar
In a nutshell, do you see the lighted part of the taillamp cluster, in this case illustrating the rear fog lights. Well in the event of sudden/abrupt/emergency braking (car determines when/how), that part lights up together with the normal rear brake lights. So more brake light to go with more urgent braking hence adaptive brake lights. Its a safety feature to communicate to the person behind you that you're freaking out up ahead
