Rubbing with 275/30/19 on stock sport suspension - AluFelgen
05-30-2009, 10:08 AM | #1 |
Rep 83
Hi,
I installed my Alufelgen CS7 wheels today with 245/35/19 and 275/30/19 tires and I have rear rubbing issues. Wheels are Front 19x8.5 ET35 and Rear 19x9.5 ET30 Couple of members here run this setup with a dropped suspension and they don't rub...i'm a little bit disapointed Anyone else with this problem? Last edited by spy963; 05-30-2009 at 10:38 AM.. |
05-30-2009, 12:31 PM | #4 |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
I'm confused too, I run the same offset, and lowered, albeit on a E90. What tires are you running?
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
05-30-2009, 01:12 PM | #5 |
Rep 4,080
Are you sure it's not the front? That recipe, 35 ET and 245 with the soft stock springs caused rubbing on my e90. Also what kind of tires? Some are more square then others.
05-30-2009, 01:30 PM | #7 | |
171
Rep 2,057
Let us know |
05-30-2009, 01:53 PM | #8 |
Rep 3,865
Theres no way you can be rubbing in the rear if your not dropped...
I rubbed in the front on hard turns against the liner when i had 19"x8.5" iforged fronts with 245/35 tire and i wasnt dropped...you may be rubbing in that same place? |
05-30-2009, 01:58 PM | #9 |
MAUI BUILT
485
Rep 7,781
I thought you were a e92, with the e90, you should not be rubbing even if you are on square tires if your zsp is not dropped.
Do you rub only on big bumps, hard cornering, dips on the freeway, car loaded? Danny
05-30-2009, 05:43 PM | #10 |
Rep 1,029
spy963,
I will be receiving nearly the same wheel/tire set up from AluFelgen on Monday! Only difference is I'll be running 235/35-19 on the front. I also have E90 with bone stock Sport Suspension. Please advise WHERE it's rubbing? Right or left tire and where? How about some photos!?
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
05-30-2009, 06:17 PM | #12 |
Rep 83
Ok, I did a couple of tests...
I think you're right...I'm rubbing in front...mostly on passenger side. Here's the results: On big bumps : sure, i rub Dips on freeway : no Hard cornering: no Hard cornering with bumps : yes Hairpin turns : a little bit |
05-30-2009, 06:43 PM | #13 |
Rep 2,560
Drives: Rapidly from A to B
LCI??? It has a wider track allowing a less agressive offset.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
05-30-2009, 06:49 PM | #14 |
Rep 2,224
Is your camber correct? These cars are meant to run some slight neg camber (-0.5) as standard.
I'm pretty sure generals have a square sidewall too |
05-30-2009, 09:06 PM | #15 |
Rep 1,029
So, do you think it's the 245 size that's causing the rubbing issue? or offset? Plus I'd still like to see a photo of the car with those wheels...I can hardly wait!
05-30-2009, 09:20 PM | #16 |
7478
Rep 10,120
Since we're on the topic; I'm about to pick up some 19 inch rims for my 328i E90. Will the 19's fit fine? I'm just wondering because I heard people with 20s were having issues.
05-30-2009, 09:54 PM | #17 |
Rep 83
05-31-2009, 03:43 PM | #19 |
Rep 1,389
I promise with Stock Sport Suspension and a 30 offset you will rub with General 275's.
I have 33 offset with a 3mm spacer, and I ended up having to roll my fenders.
"SYONRA" is for sale! http://www.e90post.com/forums/showthread.php?t=366678 BSM '09 e92 335i | Performance: JB3, RR Catted DP's, INJEN DCI, Britalman Exhst, AA FMIC, FORGE DVs | Suspension: ST-V1 Coils, Hotchkis Chassis Brace & F/R Sways | Wheels: Bremmer Kraft BR03s, Brake Performance Rotors, Cool Carbon Pads, ECS Lines | Exterior: OEM Aero Lip/Rear, ****** CF Trunk Lid, BLUX5 Angels, M-Force M3 Sides | Interior: Passport 9500ci, Black Trim, M3 Wheel
05-31-2009, 05:37 PM | #20 |
Rep 83
05-31-2009, 06:14 PM | #21 |
Rep 1,029
Hey spy,
Looks great! Just so we're clear...the rear 275's are NOT an issue? It's the 245 on front that are rubbing on BIG bumps, during hard corning over bumps and when at full lock hairpins? Just curious, did you specify the offset or just advise AluFelgen what vehicle they were for and they sent you what you needed. Does anyone actually measure the offset to make sure they were shipped the right fitment? Are you just going to live with it, then switch down to a 235 on front next time? No ///M decals?
