Breyton Race GTS-R Opinons for e92 montego blue
06-08-2009, 08:59 AM | #1 |
Rep 149
Need new wheels and it is between some CSL reps and these Breyton's. Lot's of info and pics for the CSL reps, but not much on here for these Breyton's. What's your opinons? Specs seem real good and reasonably priced for a staggered setup.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand http://www.tirerack.com/wheels/MiniW...d=true&sw=1680
Sold - 07 328Xi Montego Blue Coupe 6spd. Tinted, BMW SSK, BMW Perf. Exhaust, Aero Lip, painted grills.
2011 535Xi Sport |
06-08-2009, 09:03 AM | #2 |
Rep 2,335
I was looking at this same package before i got mine... I think it will look great(Matte Blk)... However, i did also read on there the Breytons dent easily.
06-08-2009, 10:02 PM | #3 |
Rep 149
I also heard they were durable. But they are very light for a fairly inexpensive wheel.
2011 535Xi Sport |
06-09-2009, 09:34 AM | #4 | |
Rep 3,553
less material, the weakest casting method (weaker than OEM), and from my experience, a very weak and brittle aluminum alloy... not a recipe for a durable wheel. if you live anywhere without glassy smooth roads, skip them. i bent/cracked 3 in about a month in NYC. gave up and wrote them off. got a set of VMR V715s. none of the same problems, and i havent moved out of NYC
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508 Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC |
06-09-2009, 12:47 PM | #5 |
Rep 149
Good info. Thanks!
2011 535Xi Sport |
06-09-2009, 05:32 PM | #6 |
Rep 3,553
for example:
BBS LM (forged) (18X8.5) Offset: 30mm Backspacing: 5.94" Bolt Pattern: 5-120 Rec. Tire Size:225/40-18 Weight: 23.0lbs. BBS RS-GT (forged) (18X8.5) Offset: 35mm Backspacing: 5.90" Bolt Pattern: 5-120 Rec. Tire Size: 225/40-18 Weight: 20.8lbs. Breyton Race GTS-R (gravity cast) (18X8.5) Offset: +37mm Backspacing: 6.14" Bolt Pattern: 5-120 Rec. Tire Size: 225/40-18 Weight: 19.8lbs. that should worry anyone....
