anyone use cordless impact wrenches?
06-09-2009, 09:59 AM | #1 |
SUPERMAN
121
Rep 3,171
im looking for a impact wrench for my car since im starting to get lazy lol. anyone use them on the forum? if so pleasee show me which one you use, how you like it and where i can buy one.
thanks in advance
MODS: JB3 18ohm | AR Design Catlles Downpipes | CDV Delete | Clutch Masters FX400 | ZEX Nitrous Kit | Devils Own Methonal Kit | VMR V701 (Matte Black) | H&r Race Springs| BMW Perf Grilles|
06-09-2009, 10:11 AM | #2 | |
Rep 1,389
http://www.amazon.com/gp/product/B00..._ya_oh_product You can get this shipped for less than $25 right now. I have it and LOVE it. It's not really heavy duty, but for basic DIY-type stuff, it gets the job done.
"SYONRA" is for sale! http://www.e90post.com/forums/showthread.php?t=366678 BSM '09 e92 335i | Performance: JB3, RR Catted DP's, INJEN DCI, Britalman Exhst, AA FMIC, FORGE DVs | Suspension: ST-V1 Coils, Hotchkis Chassis Brace & F/R Sways | Wheels: Bremmer Kraft BR03s, Brake Performance Rotors, Cool Carbon Pads, ECS Lines | Exterior: OEM Aero Lip/Rear, ****** CF Trunk Lid, BLUX5 Angels, M-Force M3 Sides | Interior: Passport 9500ci, Black Trim, M3 Wheel
06-09-2009, 10:15 AM | #3 |
SUPERMAN
121
Rep 3,171
^ lmao im looking for a impact wrench that can change tires lol
but you know what i might buy this one too thanks
06-09-2009, 10:24 AM | #4 |
32
Rep 867
For just wheels, you dont need anything with much torque to get the bolts off and back on, unless you plan on using it to break the bolts loose too. Otherwise just about any cordless will work including a drill with a socket attachment+socket to get the bolts off and started back on.
06-09-2009, 10:29 AM | #5 | |
SUPERMAN
121
Rep 3,171
any way...any one know max tq for the lugs?
06-09-2009, 10:34 AM | #6 |
32
Rep 867
No, you can use a cheap Harbor Freight drill too...
If all you are interested in is getting the wheels off and on.. Get a cheap breaker bar to break the bolts loose on the ground. A simple drill with a socket attachment + 17mm socket to remove the bolts and put them back on. Get a torque wrench to tighten to spec once the bolt is seated on the wheel. |
06-09-2009, 10:43 AM | #7 |
SUPERMAN
121
Rep 3,171
but if i get a cordless impact will it meet the bmw tq standards?
06-09-2009, 10:50 AM | #8 |
Rep 2,575
Drives: '73 2002,'18 X5 35d,'17 328d T
yep. breaker bar, cordless Makita drill/driver with 1/2" socket adaptor, and cheap craftsman torque wrench.... four wheels in four mins
1988 E28 535is Euro Conversion --- sold 2009 E90 335 6MT --- sold 2003 E39 540iT Msport --- sold |
06-09-2009, 10:55 AM | #9 |
32
Rep 867
06-09-2009, 10:58 AM | #10 | |
656
Rep 10,587
I cant stress that enough. you already got other good suggestions. its easy, breaker bar plus extension and 17MM socket, then spin those suckers off. Only use the TQ wrench to tighten to 80-90 lb/ft. Dont use your TQ wrench to break your lugs free either, you will break it.
06-09-2009, 11:01 AM | #11 | |
SUPERMAN
121
Rep 3,171
but i guess that out of the question so i guess ill just pick up a breaker bar and tq wrench
06-09-2009, 11:07 AM | #12 |
32
Rep 867
The problem with using any impact wrench to tighten the bolts/lug nuts is that you cant effectively control the torque. More often then not you will overtighten. This will at best stretch the bolt out of spec and at worst shear it right off.
06-09-2009, 11:27 AM | #13 |
Rep 2,431
I have an air compressor setup in my garage and on my truck, but when I'm too lazy to reel the hose out I ....
~break loose the bolts with torque wrench ~use my 10v makita li-ion impact driver to remove/install the bolts ~torque wrench to torque it to spec(this process must be done even with air impact gun) IMO you just remove the first step by using the air compressor, but at the same time you have to wiggle the wheel so that it sets easier when you are using the 10 volt. Also I don't recommend using drills as they were not designed for torque load...10v makita drill and driver set is only 130 at home depot and it is all I use(I have alot more tools). Here are somethings I do with my 10v drill/driver set w/o the use of any other larger drill/driver Recently renovated my home (kitchen,garage) Change wheels/suspension w/the exception of use of TW to break bolts loose Maintain my restaurant(drill through stainless steel) Build a speaker box for my truck 1" mdf(definitely a little limited here but got it done) mount my LCD's ETC....you get the picture PS don't bother buying those pepboys cordless impact guns...they burn out and have less toque than my 10v. Stick w/ makita, dewalt, bosch and even ridgid for $70
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
06-09-2009, 02:10 PM | #14 |
BimmerPost Supporting Vendor
2042
Rep 25,989
Nothing is better then the old fashioned breaker bar and torque wrench. Majority of the time, impact wrenches always tend to scratch and damage wheels more then they do help.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
06-09-2009, 02:19 PM | #15 | |
32
Rep 867
http://www.harborfreight.com/cpi/cta...emnumber=40035 |
06-09-2009, 02:30 PM | #16 |
Rep 197
06-09-2009, 05:40 PM | #18 |
322
Rep 17,316
Drives: E92 M3, E30 325i
Here's what you can use to make the job a tad easier. Go get a cheap impact drill from Harbor Freight. There's one locally near where I live so I went and picked one up for $20. I also got my breaker bar there $9 and a torque wrench ($20). I also got the attachment bits that comes in a pack of 3 for a few more bucks. Just loosen the bolts/lugs with the breaker bar and then use the impact drill to take em out. And the torque wrench to put the bolts/lugs back in. Since it's a impact drill you won't be able to overtighten it and then use your torque wrench to torque it down. It does save time imo.
06-09-2009, 05:43 PM | #19 |
322
Rep 17,316
http://www.harborfreight.com/cpi/cta...emnumber=93440
this is the one i have. But i got it on sale for $19.99. Not the best quality but it'll get the job done. Worked fine when I used self tapping screw on metal as well. |
06-10-2009, 07:25 AM | #20 |
SUPERMAN
121
Rep 3,171
ok well i went with a breaker bar and tq wrench but is everyone sure i have to tighten it to 90 ibs of tq? that doesnt seem tight at all
06-10-2009, 08:50 AM | #21 |
32
Rep 867
06-10-2009, 11:13 AM | #22 |
Rep 197
?? Why not use that to lose up the nuts? I don't see a problem to use it to remove the nuts... Maybe I just didn't make it clear ... I don't use it to tighten the bolt, just for removeal...
