06-10-2009, 03:07 PM | #1 |
BimmerPost Supporting Vendor
8108
Rep 18,798
Drives: BMW
▀▄ eas - AP Racing Big Brake Kits now available for e9x M3
Professional teams choose AP Racing, with over 50 years of winning experience in Formula 1, Grand Am, American LeMans, World Rally Championship, Touring car and more across the globe. AP Racing brakes were the first to complete the 24 Hours of LeMans with no pad or disc change (1999 race winner - BMW V12 LMR). No matter which category AP Racing is involved in, the results are the same - winning!
Brake calipers produced by AP Racing use the latest in materials, post-treatments, coatings and manufacturing methods. One can be fooled by fancy charts and graphs of irrelevant room-temperature caliper deflection. The real test is in the driver’s seat, where no other calipers can compare. Available in 2, 4 and 6-piston variants, all come with dust seals and anti-rattle clips for real-world drivability in any climate and without pad knock. For better pedal feel, AP chooses a 2-piece aluminum design using high-strength steel bolts, which naturally has greater stiffness than typical road-going all-aluminum monoblock calipers. Finished off by hard anodizing and an extremely durable paint system, these calipers look great while doing the dirty work. AP Racing brake discs are made from the highest quality cast iron. Curved vane technology is used to shed internal heat, and the optimized cross-drilled and slotted face pattern is developed to increase pad bite and improve cooling. Each hole is radiused, not chamfered, to reduce noise and increase fatigue strength. Slotted-only faces are available for heavy track use and overweight or armored vehicles. AP Racing have tested brake pad compounds from the best friction manufacturers in the world to bring our customers the latest in stopping power, maximum operating temperature, lower disc wear and less dust and noise. Our newest compounds are the best we have ever tested in all categories: performance, rotor life, wear, noise and dust. AP Racing Front 6-piston calipers - Fits behind OE 18” & 19” wheels without spacers - Compatible with OE ABS, Traction Control and Stability systems and factory master cylinder. - High-strength, lightweight, pressure-cast aluminum alloy body - 2-piece design for maximum rigidity in a streetable caliper - Fixed radial mount for best pedal feel - 6 sequential pistons to minimize pad taper and maximize pad area - Anti-knock back features for a consistent, firm pedal - Dust seals for everyday driving - Available in red or black AP Racing Rear 4-piston calipers - Fits behind OE 18” & 19” wheels - Compatible with OE ABS, Traction Control and Stability systems and factory master cylinder. - High-strength, lightweight, pressure-cast aluminum alloy body - 2-piece design for maximum rigidity in a streetable caliper - Fixed radial mount for best pedal feel - Anti-knock back features for a consistent, firm pedal - Dust seals for everyday driving - Available in red or black - Retains OE Parking brake function AP Racing 2-Piece Disc Assemblies - 2-piece modular design to handle the heat - Fronts: Latest in Strap Drive disc technology (zero maintenance!) - Rears: Bolted fixing that retains the parking brake function - Directional curved-vane venting for maximum cooling - Cross-drilled AND slotted for aggressive pad bite and additional cooling - Slotted-only discs optional for heavy track use Brake Pads - Now featuring the ultimate in high-performance street and track day use - Virtually fade-free Mintex Xtreme Motorsport Pad Compound - Consistent coefficient of friction cold to over 1300F - Linear response and quick release - Easier on discs than many current “high-performance” compounds - Lowest noise - Competition compounds also available AP Racing - AP7100 6-piston Front Big Brake Kit for e9x M3 - 368mm BLACK http://www.europeanautosource.com/pr...oducts_id=2343 AP Racing - AP7100 6-piston Front Big Brake Kit for e9x M3 - 368mm RED http://www.europeanautosource.com/pr...oducts_id=2344 AP Racing - AP7150 4-piston Rear Big Brake Kit for e9x M3 - 356mm BLACK http://www.europeanautosource.com/pr...oducts_id=2346 AP Racing - AP7150 4-piston Rear Big Brake Kit for e9x M3 - 356mm RED http://www.europeanautosource.com/pr...oducts_id=2345 Slotted-only option also available for M3s that see heavy track day use.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 06-10-2009 at 05:42 PM.. |
06-10-2009, 03:08 PM | #2 |
8108
Rep 18,798
Drives: BMW
For a limited time, all AP Racing kits purchased with us will include 2 bottles of Motul 660 Competition Factory Line Brake Fluid:
Please mention offer at time of ordering.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
06-10-2009, 03:09 PM | #3 |
8108
Rep 18,798
Drives: BMW
AP Racing Strap Drive Systems
The Strap Drive System (Patent Pending) has been developed by AP Racing both for Road and Race applications. The standard fitment discs on many performance cars can suffer from brake vibrations caused by disc distortion. This generally occurs on fast road and track installations.
On many performance cars the typical standard disc will be a heavy duty ventilated single piece casting. Couple this type of rigid disc to a standard hub and wheel bearing and the result is any hub distortion / run out will transfer onto the disc brake faces. This eventually results in brake vibrations, usually picked up through the steering wheel. The strap drive system offers a new take on the floating systems already in the market place. Strap drive uses a series of stainless steel straps to locate the disc to the mounting bell, producing a flexible coupling between the hub and the disc faces. This allows the disc to run true in the caliper under all conditions and also permits the disc to expand and contract without being restricted. Some current replacement discs in the market place have evolved from Motorsport applications, they typically use a drive bobbin to provide some disc float and were devised to reduce pad knock off on race cars. This system can work on a road application but there are some major drawbacks that the Strap Drive has overcome with its simplicity. Bobbin float discs rely on a series of drive bobbins moving freely in drive slots. This movement can create wear during service and promote noise. The slots can fill up with road / brake debris causing them to seize. AP Racings strap couplings can't suffer from any of these drawbacks. Therefore Service life, brake noise and also brake pedal travel are all improved. AP Racing has also introduced the strap drive system into a number of our current brake kit range.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 06-10-2009 at 03:56 PM.. |
06-10-2009, 03:09 PM | #4 |
8108
Rep 18,798
Drives: BMW
A few other M3s running AP brakes
M3 GT4 BMW Rahal Letterman Racing Team We received the first set of APs AP7100R and AP7150R in North America for our M3 project, debuting at Bimmerfest '09: Other vehicles running AP The AP Racing engineers are the same ones who manufacture the OE brakes for Ascari, Aston Martin, Bugatti, Caparo, Farbio, GTA, Holden HSV, Koenigsegg, Lotus, McLaren, Morgan, Noble, Pagani, Rossion, Seat, Spyker, Tramontana, Ultima, Zolfe and other limited, high-end exotic supercars.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 06-10-2009 at 03:58 PM.. |
06-10-2009, 03:10 PM | #5 |
8108
Rep 18,798
Drives: BMW
AP Racing Builds Components for Formula 1 Race Cars
Watch this video showing how AP Racing has been pushing the envelope, tweaking its high-performance clutch and brake system designs for race cars and motorcycles, sport cars, and specialty vehicles. Also seen is how AP Racing uses SolidWorks and its amazing 3-D graphics capabilities in its design process:
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 09-28-2009 at 11:39 PM.. |
06-10-2009, 03:10 PM | #6 |
8108
Rep 18,798
Drives: BMW
reserved 4
06-10-2009, 03:11 PM | #7 |
8108
Rep 18,798
Drives: BMW
reserved 5
06-10-2009, 03:12 PM | #8 |
8108
Rep 18,798
Drives: BMW
reserved 6
06-15-2009, 05:56 PM | #9 |
8108
Rep 18,798
Drives: BMW
All inquiries replied.
06-28-2009, 07:59 AM | #14 |
n1smo
97
Rep 1,483
Drives: E92 M3
AP Brakes How much for the black kit, front and rear?
06-29-2009, 11:42 AM | #15 | |
254
Rep 4,048
06-30-2009, 08:12 PM | #17 |
Bulldog
482
Rep 3,355
Please send me PM for price for:
AP Racing - AP7100 6-piston Front Big Brake Kit for e9x M3 - 368mm RED and AP Racing - AP7150 4-piston Rear Big Brake Kit for e9x M3 - 356mm RED. Also, please let me know if you do custom colors and how much custom colors would cost. Thank You,
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS |
06-30-2009, 08:16 PM | #18 | |
516
Rep 3,613
07-01-2009, 01:01 PM | #19 |
8108
Rep 18,798
Drives: BMW
Customer sent for feedback after his first track day:
“In OTHER news, I ran the AP fronts/Mintex pads with my factory rears/Pagid RS19 pads at a track day last week. Mission Raceway Park is a 1.6 mile road course with 9 turns and is murder on brakes. The morning was in heavy rain and the afternoon was clear and dry. Handling, braking, brake balance etc. were excellent throughout and the new rotors developed a lovely blue color on the exposed edges and faces. The Mintex pads worked fine, didn’t fade and modulation was excellent.“
