06-22-2009, 04:18 PM | #1 |
Rep 2,431
FS/FT: 19" RAYS ITC 1 week old
Ok so this time around they are up for quick sale!! $950 I put them on my M and obviously the offsets were to small and I also have a deal for the wheels that I want. 1 small ding from mounting my wheels and letting them slam down off the hub Rays ITC euromesh SD 2 piece 19x8.5 et42 24 actual lbs 19x9.5 et 42 26 actual lbs the finish is a diamond cut finish in the middle and polished lip I have gotten nothing but compliments but I wish to go BBS CH black The offsets were actually for the 1 series...
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
06-22-2009, 08:32 PM | #2 |
Rep 2,335
Nice wheels! The rear offset is agressive for a 9.5" wheel, but the fronts will be fine. Someone could easily make them work with a little roll. They would look great on a 1 series... Good luck with the sale!!!
BSM ///M2cs, 6spd
06-22-2009, 08:34 PM | #3 |
58
Rep 1,859
wait wont these rub on a 1er?
E82 N54 6MT 6FL 668 KASW turned in
E92 Crimson/Cream N54 6MT, ZSP, ZPP, ZCW, Nav, Sat radio, HD Radio, Logic7, PDC, Active Steering, Active Cruise, 6FL, CA |
06-22-2009, 08:40 PM | #4 |
Rep 2,431
not according to these guys...these are sold as 1series wheels on their site
http://store.bimmerperformancestore....-itc-euro.aspx
06-22-2009, 10:24 PM | #5 | |
Rep 581
The front should work, not so sure about the rears though.... |
06-23-2009, 08:04 AM | #6 |
Rep 2,431
you can always shave the wheel if you don't want to roll the fenders or run a 235 tire...and you'll have quality nongeneric wheels that standout
07-07-2009, 02:28 AM | #7 |
Rep 2,127
Drives: E92
just wheels or tires too?
07-08-2009, 07:31 PM | #9 |
Rep 1,245
these offsets and width's are perfectly fine for a 1 series.
you dont want to roll your fender, then run stock sized tires. you dont mind rolling, then for with 225 / 255 setup gl w sale |
07-08-2009, 09:43 PM | #10 |
E30 Addict
38
Rep 590
Looking for wheels Ray?
There is no way you would fit these without a fender roll, unless you are on stock suspension. And I find it damn hard to run a 255 set up with that offset, that is not something that the normal DIYer would be able to do.
07-08-2009, 10:49 PM | #11 |
Rep 1,245
how is that hard to run a 255?
im on 9.5 et 45 and i have much more than 3mm of room to the fender and i never rub.. if you can roll the inside pretty flat (mine are cut) then it should be the same. |
07-08-2009, 11:06 PM | #12 | |
E30 Addict
38
Rep 590
I have cut fenders, -2.6 degrees of camber, 9.5 et45 wheels and 245 tires, with about 12mm of space between the tire and fender. Subtract 3 for the offset, and roughly 5 from the larger tire, and that leaves you with 4mm from the fender. Now take my camber into consideration, then account for that 4mm that I would have with that setup. I never said it was impossible, but I said it was hard, and not suitable for most people. Plus cutting the fenders will get you more room. It is very hard to roll the fenders on this car due to the glue they use to hold them together and whatnot
07-08-2009, 11:27 PM | #13 | |
Rep 1,245
i am slammed on kw v3 rears at lowest setting
didnt change the camber specs, so whatever camber i got from lowering yes, i know about the fenders, and the glue, you are supposed to heat it up scrape it all out then do a hard roll on it. however i went the cutting route because it is cleaner. im not trying to argue, but point is, it will fit and fender rolling is common i dont find that being a "hurdle" for most people,ive ran 5mm spacers on my 9.5 et 45 rims with 255. Quote:
07-09-2009, 12:17 AM | #14 | |
E30 Addict
38
Rep 590
07-23-2009, 12:28 AM | #15 |
Rep 2,127
Drives: E92
07-23-2009, 10:13 AM | #16 |
Rep 2,431
Hey guys,
just an update...I've put these wheels on my wifes 09 e90 and it looks great! she wont let me sell them so they are gone, but my little brother will end up w/ a 1series this week and I'll test fit just to squash some bad info on here and if they fit you can buy them for 1700 new
07-23-2009, 10:37 AM | #17 |
58
Rep 1,859
I hope they fit just so we can have the option of the wheels, post pics of the e90, I'd have tried them but I don't have the $ right now
