Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - Southwest > Installing BOV
      06-22-2009, 10:47 PM   #1
Advan
Advan's Avatar
Drives: Stillen tuned 370Z
Installing BOV
Hey guys anyone in Dallas (Lewisville/Carrollton) can help me install BOV? Lunch and beer will be provided :-)
Just ordered http://www.e90post.com/forums/showthread.php?t=258856
Terrance28 is willing to help, but I will not go down to Killen for next few months and wanting to get it installed..
Any help will be greatly appreciate it
      06-22-2009, 11:28 PM   #2
M335iTT
Drives: 2009 335i M-Sport
i can help out. I just put forge dvs on mine and it was easy. Just give me a pm
      06-23-2009, 12:54 AM   #3
iamvietness
Drives: 2015 M3
was this from ******? or is he selling someone's product?
      06-23-2009, 02:03 AM   #4
Advan
Advan's Avatar
purchased from JBSPEED
      06-23-2009, 09:56 AM   #5
iamvietness
Drives: 2015 M3
oh ok good. bullet dodged
      07-13-2009, 12:47 AM   #6
Tulsadriven335
Vorstiener
Tulsadriven335's Avatar
Drives: 07' e90 335
2007 e90 335i  [8.00]
Exclamation caution
be extra careful with the plastic intake manifold vacuum line nipple, as it has broken on people before.
| 2007 335 e90 | KW V3 | AR DP | ICONZ | AFE | JB3 | VORSTIENER | MTEC | 3D DESIGN | SNOWS | STETT | FORGED DV | VANGUARD | GODSPEED FMIC |
      07-13-2009, 03:49 PM   #7
Advan
Advan's Avatar
hmm... I just ordered mine, finally back from vacation.. I hope it's decently quality. I heard the piping itself is worth it... I'll prob ride on the ****** bov until I can find greddy type s somewhere in craigs or ebay
      07-19-2009, 11:36 PM   #8
Advan
Advan's Avatar
Exclamation
I'm like wth, I'm going to install this myself; I got instruction on how to and I'm bit confused on this part.
I don't know why there are two tubes... I don't know what "46" is
      07-20-2009, 03:18 PM   #9
Advan
Advan's Avatar
nvm guys, installation was long, but not too hard.
Terrance28 or iamvietness : If you see the thread, check on picture #3, I left that open, that should be ok right?
      07-20-2009, 05:31 PM   #10
Tulsadriven335
Vorstiener
Drives: 07' e90 335
46 is the dreaded Intake manifold vacuum line that i warned you about, the tube in your hand looks like the return tube for the DV's you need to take both those off and cap'em. Im sure you already did that though. I did see that you BOV tension screw is almost all the way screwed down, double check with ****** but from my understanding, that might cause you some problems people complain about potential boost leaks and what not.
BTW on the AA Bov we dont not connect anything to the back nipple on the Valve itself, just one vacuum line is connected to the front of the BOV, hope this helps
      07-20-2009, 06:10 PM   #11
Advan
Advan's Avatar
I capped the rear nipple, and ran the "front" to intake vacuum -- so far so good, everything seems fine, idle seems to be ok.... I'm going to install them DCI soon and most likely replace the bov with GReddy or HKS. The piping is awesome... so it's worth the money just for the piping alone.
      07-20-2009, 11:35 PM   #12
Tulsadriven335
Vorstiener
Drives: 07' e90 335
hey just wondering, at idle, does the valve inside your BOV stay shut or stay open.
there have been many arguments on if it should or should not be open during idle. Mine stays open about a half inch until i rev and spool up, then it closes.
Some people say it should be closed or else your losing some boost, Im not exactly sure though. and AA said it should be open a little.
      07-20-2009, 11:47 PM   #13
Advan
Advan's Avatar
I'll check that tomorrow
      07-21-2009, 12:16 AM   #14
Terrance28
Terrance28's Avatar
Drives: Crimson Red E92
Yeah man no need to run the rear nipple. I found out when I didn't use it the bov sounded better to me. Don't follow the instructionsprovided remove both dvs and cap off the intake pipe and run the one line from the top of the nipple.
Mods list got too long, lets just say more than enough.
      07-21-2009, 12:23 AM   #15
Terrance28
Terrance28's Avatar
It stays open like you have been seeing thats the way it should be. High vacuum and boost slams it and holds it shut. You won't lose any boost cause it only opens on idle thats how its designed to work. The vacuum line on top of the bov is what works the bov.
      07-22-2009, 06:05 PM   #16
possible335i2008
Drives: 335i
is this on an auto?
      07-23-2009, 08:32 AM   #17
Advan
Advan's Avatar
yea on idle it says open, but I was installing my scoop and added better clamps for the BOV pipe yesterday and found this laying around -- I guess it came loose; I don't know if this is normal, I just twisted back on, but should I like super glue or JB weld it on ?? or contact vendor??
Don't mind the electrical tape lol, that was removed and clamp was added
      07-23-2009, 10:10 AM   #18
Terrance28
Terrance28's Avatar
Just screw it back on tightly, thats only there to amplify the blow off sound to make it sound better, and go and get some better hoses instead of using the orange ones.
      07-23-2009, 10:44 AM   #19
Advan
Advan's Avatar
Where did you get yours? Dude I spent like hours looking for a better one, couldn't find any. Autozone, O'Riley, Home Depot ----
      07-23-2009, 11:54 AM   #20
Terrance28
Terrance28's Avatar
I had some left over from my turbo rx8, do you have a performance shop near you?
      07-23-2009, 12:30 PM   #21
Advan
Advan's Avatar
There are couple of shops near me..
      08-10-2009, 11:30 AM   #22
AlbinoSnail
n00bie
AlbinoSnail's Avatar
Drives: three.thirty.five.i.
Sooo... how's the BOV treatin ya?
The SNAIL: Alpine White | Beige Dakota | 6MT | ZMP | ZZP | Navi | Logic7 | CA R.I.P The TANK '96-'09
