Blow Off Valve (BOV) on a 335i Coupe
08-23-2006, 01:06 AM | #5 |
Rep 804
haha i asked this here too... on my post http://e90post.com/forums/showthread...&highlight=bov
i got a little more positive response but .... i think it will mess up the engine in the long run.. which would be all bad... but im pretty sure someone else will try it first... if it works then ill probably put one in too. otherwise you can always get this http://www.takakaira.co.jp/accessori...ightpager.html hahaha |
08-23-2006, 08:11 AM | #8 | |
Rep 6,750
08-23-2006, 08:20 AM | #9 | |
Rep 1,029
I need to install that on my 72' 2002 |
08-23-2006, 11:26 PM | #10 |
United States Marine
318
Rep 2,748
I believe Audi veh's use bypass valves (or diverter) which, instead of blowing off boost pressure to atmosphere, it just dumps it back in front of the turbo, allowing it to get reused.
Matt |
08-24-2006, 11:01 AM | #12 |
Rep 840
audi and vw aftermarket started using HYBRID bpv/bov so you get the noise like all the hot rodding evo's and STi's.
i think it's annoying after awhile, heck if you put an intake on the 335 you'll be able to hear the bpv "sneeze" when you let off throttle. |
09-13-2006, 01:16 AM | #13 |
Rep 876
It is going to be really funny when everyone has a bov on their 335. I am sure that all of the evo drivers will be pretty confused for a minute or two. lol
09-13-2006, 10:55 AM | #14 |
fresher den you
34
Rep 986
Drives: 2004 x3
the blow offs on the subarus sound like shit.
2004 x3, blue water metallic, sports pack, panoramic moonroof, xenon, hi-fi radio.
09-13-2006, 11:25 AM | #15 |
1736
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
FWIW, the 335i doesn't have a MAF senor. It uses MAP sensors instead. One in the intake manifold and one just before the throttle body in the IC charge pipe.
-shiv |
09-20-2006, 09:14 AM | #16 | |
Rep 4,095
Drives: F30 328i
09-20-2006, 09:32 AM | #17 | |
Rep 1,184
09-20-2006, 02:09 PM | #18 |
JDM Slut
141
Rep 4,233
Drives: 07 e90 335i
Garage List 2014 PORSCHE CAYMAN [10.00]
2013 BMW X1 [9.00] 2014 BMW X5 xDrive35i [9.00] 2013 PORSCHE 991 [10.00] 2007 BMW 335i [9.08] |
yup, if it uses maf sensors, it will basically expect air to get back into the intake from a dv. However, a BOV is atmospheric so thus no air goes back into the intake causing a loss of power because the engine expected more air than what is really there. With a MAP, you can run a BOV safely and what not. The hybrid ones you mention is both recirc and atomospheric. Until high loads (more PSI) it shoots into atmos and under low load, it shoots into the intake. Btw, what you said about the STi BOV sounding like shit is all subjective. It's the brand of the BOV that makes the unique sound not the car.
09-24-2006, 05:19 PM | #19 | |
Rep 830
Used a MAF sensor and had no problems whatsoever, no stalling, rough idling, no afterburn / backfire between shifts, etc. I would be suprised if the 335i doesnt have some sort of turbo protection for surges. But then again its wastegate is unlike what i've seen before - perhaps it accomplishes that in itself. |
11-14-2006, 02:09 AM | #20 | |
Rep 143
